Question about Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13 In
Hilti TE 92 hammer problem
This TE 92 has worked fine for years. When drill is cold(30F or less) it would take a minute of operating before hammer was active. Lately it only hammers when drill is started or stopped. I thought that the floating piston was sticking in the advanced position or TDC(top dead centre). I dismantled drill,cleaned and lubed with a light machine oil. It still operates the same. At initial start the drill hammers fine then quits.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, possibilities are:
  • partial leak on the compression are of the drive piston;
  • loose striker piston assembly;
  • worn o-ring;
  • worn/enlarge inner diameter of the pressure ring.
A way to check is to wipe clean from the o-ring, striker piston, retainer ring to the pressure ring. Apply/coat liberally with colored oil (blue like those used as 2T oil for 2 stroke engines) the crown of the drive piston, assemble and test run. Dis-assemble again and note until which component the oil has been forced to. Anything in between then has a leak since it allowed the oil to transfer from the piston crown to that point.
Good luck and thank you for using FixYa.
Posted on Feb 19, 2009
    Brigadier General:
  • 3,614 Answers
Have you check the hammer switch could be faulty.
How to put drill bit in a hilti te 92
pull straight out on the fitting and push drill in
May 21, 2015 | Hilti Drills
Reset service light on hilti te 706
I have one Hilti Mechie , TE 706 Avr, Now Red Light Only Blinking ,Mechine Not Working
Jun 12, 2012 | Hilti TE 70 Hammer Drill Performance...
Need on/off switch for Hilti TE 17 Hammer Drill
Parts for the TE17 have been discontinued for over 15 years. The switches and the oilite bearings for the motor were the first to run out.
Jan 07, 2011 | Hilti Hammer Drill, 8.4 Lb 3 Mode, Te 16 C
Hilti TE 17. Hammer doesnt work. Rotary does.
Most likely the O-rings are worn - tool has no compression to move the hammers inside.
Less likely: the connecting rod for the piston is broken so piston isn't moving - or 2nd hammer is broken into pieces.
I would open it up & check the orings first
Jul 31, 2010 | Hilti Drills
Te70 hilti hammer drill
The TE-70 is permantly lubricated. You would only add lubricant if you took the tool apart. You can add a small amount of grease to the end of your bit occasionally before putting in the chuck. This keeps the chuck parts lubed.
Jul 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Will the bits from the te-c3x fit my te-17
Yes. New bits will fit old Hilti drills. Old Hilti bits do not fit the new (last 15 years) Hilti drills.
Apr 07, 2010 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
Hilti TE 12. It will not hammer.
the rotory cam has been broken inside if not producing the hammer effect
Mar 11, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
NEED PARTS FOR HILTI TE 17
hi i have a 30 year old hilti te17, yes i know but its great but i need the bit holder ( chuck i think its called, the thing that hold the drill bit in for this hammer drill, otherwise its works perfect, built to lasst these things, but parts are hard to come by in aystralia, anyone help me if you can please
lulu
Mar 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti TE 10 drill. It doesn't seem to hold the
Probably a missing ball problem---contact Hilti website.
Feb 27, 2010 | Hilti Hammer Drill, 8.4 Lb 3 Mode, Te 16 C
Drills but dont hammer te 74
Hilti no longer carries parts for the 74. However most of the TE75 parts will interchange with the 74
Jan 31, 2010 | Hilti Drills
Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13 In Logo
1,462 people viewed this question
Top Hilti Drills Experts
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
