Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Dishwasher not draining water all the way
I have a used portable kenmore dishwasher that is not draining all the water out of it or cleaning dishes well. I have checked with a online help that say it is probably either hose problem or pump. It is a older dishwasher so I don't have manual to look at so not sure I would even begin to look for pump
  • Kenmore Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
kkjl
Posted on Sep 29, 2010
Dishes come out dirty like trap needs tobe cleaned kenmore 565
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Kenmore Dishwashers
Kenmore Dishwasher takes excesive amount of time to run, and dishes are not that clean and dosent seem to dry very well
Hi
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Mar 22, 2011 | Kenmore 24 in. 17362 / 17364 / 17369...
Dishwasher not cleaning - want to clean drain
We have a Kenmore 665.17702k600 Portable dishwasher with a similar problem. What we did was pop off the drain cover (turns out the one screw wasn't doing anything and just pushed down into the unit when screwdriver was applied). We popped it off by shimmying a screwdriver under the panel, and applying torque on the long end. It just popped right off. Then there was this nasty stale water, and not much obvious debri. We used a wet vac to slurp all that up. So that's the solution we took -- haven't tried it yet, so not sure if it will actually fix the problem...
Nov 02, 2009 | Kenmore Dishwashers
I have a Kenmore Quietguard dishwasher, only a few years old, and it won't drain. I pulled it out and checked the drain hose, could not find a clog. I took the basket and sprayer out, couldn't find any...
I have a Kenmore Quietguard portable that won't stay connected to my kitchen sink faucet. Checked all I can and continues to spray the wall and me without staying attached securely to the faucet adapter. Help!! Any ideas?
Jun 17, 2009 | Kenmore 24 in. 15162 Built-in Dishwasher
Dishes not clean enough. as if rinsing in dirty
If your dishwasher drains it's water to a garbage disposal, give the disposal a spin while the dishwasher is pumping out. Check around the bottom of the dishwasher to make sure something is not clogging the drain.
May 01, 2009 | Kenmore Dishwashers
Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Not draining may either need new drain motor. or something is blocking the drain pipe.
Spots on dishes means you are using to much detergent or the wrong kind of detergent.
Your owners manuel should tell you what type to use.
Nov 18, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 18inch Portable Dishwasher
how is the water flow at your sink this is a portable right un screw the connector at the sinkand check the screen 2 your fill hose could be kinking up when you pull it out take a light and look down into the washer see if you can see it kinked we will go from there
Dec 31, 2007 | Dishwashers
Older portable dishwasher
nothing it needs a switching kit or drain solenoid kit rather
Dec 30, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Kenmore built in dishwasher model # 665.16831792
timer is ordering draining. or solenoid is on and it drains non stop.
Oct 31, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Water draining is premature
In my case, I had the same problem until I realized the drain hose was not looped high enough. Once I looped the drain hose higher than the dishwasher, the problem went away and it washes dishes perfectly.
When the drain hose is installed too low, the water in the machine will only stay as high as the hose is installed because of the laws of physics.
The same applies to laundry machines - that is why the drain hose is set to drain from a higher point than the drum of the washer.
Good luck and Blessings!
Apr 26, 2017 | Kenmore 17252 Free-standing Dishwasher
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
