Question about Apple iPod nano
IPod Display-Frozen-Folder I have a iPod Mini. I dropped it while in the gym. Now, the display is stuck with a little folder and a 'caution' sign. While holding down the Menu and Center Wheel, an Apple logo displays momentarily, and then it goes right back to the above state. While plugged into my Dell PC, it doesn't recognize it as being connected. I just installed a new battery, but the new battery worked fine. I think this problem is surely associated with the drop at the gym. (I've dropped it before and nothing's happened.) Now what?
    Genius:
  • 1,061 Answers
Yes the drop was not good.But try this..leave it on until the battery runs down.turn off and plug in to charge,Allow it to fully recharge.Turn on and it should have reset itsself.If this does not help get back to me here.Please vote.RICHARDM69
Posted on Feb 07, 2009
Is there a way to transfer songs from an Ipod classic into itunes in 2016.
iPod users will find that when they connect their iPod to computer, the computer will recognize their iPod but won't display the music file in the window. Actually, the music files are just hidden by the computer, and the users only need simple steps to unveil the music files. Then they are allowed to transfer music from iPod to iTunes.
1. Plug iPod into computer via USB cable, then the computer will show iPod in "Computer".
2. Go to "Tools > Folder Options", and then choose "View" in the pop-up dialog.
3. Check "Display hidden files and folders" in the drop-down menu.
Then you will find a folder called "iPod_Control".
4. Open that folder and you will get the "Music" folder which includes all of your iPod music files.
You are able to copy and paste the files from iPod to your computer, but you will find that the music files are saved in a random order. At this moment, you can launch iTunes, and go to "Add > Add Files to Library", and then add the music files into your iTunes library. iTunes will sort the music files by a certain order. Now, the music files you have chosen will be stored in iTunes.
3 Ways to Transfer Music from iPod to iTunes Library
Jan 02, 2017 | Audio Players & Recorders
Tip
Shortcuts you can use with Windows Explorer
Display the bottom of the active window. END
Display the top of the active window. HOME
Display all subfolders under the selected folder. NUM LOCK+ASTERISK on numeric keypad (*)
Display the contents of the selected folder. NUM LOCK+PLUS SIGN on numeric keypad (+)
Collapse the selected folder. NUM LOCK+MINUS SIGN on numeric keypad (-)
Collapse current selection if it's expanded, or select parent folder. LEFT ARROW
Display current selection if it's collapsed, or select first subfolder. RIGHT ARROW
on Apr 04, 2011 | Computers & Internet
Tip
Acessability shortcuts
Right SHIFT for eight seconds........ Switch FilterKeys on and off.
Left ALT +left SHIFT +PRINT SCREEN....... Switch High Contrast on and off.
Left ALT +left SHIFT +NUM LOCK....... Switch MouseKeys on and off.
SHIFT....... five times Switch StickyKeys on and off.
NUM LOCK...... for five seconds Switch ToggleKeys on and off.
explorer shortcuts
END....... Display the bottom of the active window.
HOME....... Display the top of the active window.
NUM LOCK+ASTERISK....... on numeric keypad (*) Display all subfolders under the selected folder.
NUM LOCK+PLUS SIGN....... on numeric keypad (+) Display the contents of the selected folder.
NUM LOCK+MINUS SIGN....... on numeric keypad (-) Collapse the selected folder.
LEFT ARROW...... Collapse current selection if it's expanded, or select parent folder.
RIGHT ARROW....... Display current selection if it's collapsed, or select first subfolder.
I was not knowing how to copy songs in my ipod,plz solve my problem..
Connect your ipod to the system, it wil detect and shown as a mass storage device, just copy the songs from your system and paste it in to the device..
May 13, 2011 | Computers & Internet
My navman s45 seems to be frozen or just stuck on the same route also after i have reset it it still goes back to the same route which is stuck on and cant be cleared and the touch screen buttons dont work...
1. Connect Navman GPS to PC via mini-USB cable.
2. Go to 'Start'
3. Go to 'My Computer'
4. Open the Navman Unit
5. Open the 'Navman' folder
6. Open the 'Database' folder
7. Delete the following file only - 'dababase.db'
8. Close the folders
9. Disconnect the mini-USB cable then restart the Navman GPS by sliding the switch to 'Restart' then back to 'On' after 10 seconds.
The database.db file will be generated automatically once the folder is closed.
Nov 04, 2010 | GPS
Tip
How to copy songs from your iPod to your PC
1. Connect the iPod to your PC. If iTunes starts syncing (ie erasing) your music automatically, hit the X in the upper right hand corner of iTunes display, to the left of the search box, to stop it.
2. In Control Panel, Portable Media Devices, double-click your iPod.
3. Navigate to the Music folder.
4. Select all the music folders, and drag and drop them into a folder on your hard drive, or directly into iTunes.
on Oct 09, 2010 | iPhone Apps
Problem about uploading pictures
First, make sure the pictures are in jpg format, and put the ones that you want on the iPod into a specific folder - you can even call it "iPod photos folder" if you want.
Then conenct the iPod to the computer, and then open up iTunes.
Left-click on the tab that says iPod Nano, if it doesn't come up automatically, and then select the Photos tab.
Select the drop down next to the line that says "Sync Photos from," and locate the folder that the photos are stored in.
It will add all photos that are in that folder to your iPod - may take several minutes depending on how many photos you are addding.
Once this option is selected, any photos that you add to this folder from here on out will be automatically added to the iPod whenever you connect the iPod to the computer.
On the iPod Nano, horizontally-biased photos display the best - wil ltake up the full screen of your Nano; but vertically-biased photos wil lstill show up.
-Tha Mp3 Doctor
Mar 22, 2009 | Apple iPod nano
IPod Nano A1137 with disk mode message
I have a iPod Mini. I dropped it while in the gym. Now,...
Feb 05, 2009 | Apple iPod nano
Dowloading audio files onto my computer..
I have an Olympus recorder. I don't know if the software is similar but their software has a way of copying the files to folders in the software. These files can then be used in other audio programs such as ITunes if you want to transfer it to your Ipod or audio recording software so that you can drag and drop them into one file.
If you look in the folder where your voice manage software is, is there a folder where the audio files are being stored within the program?
Jul 16, 2008 | RCA RP5010 Digital Voice Recorder
Apple iPod nano Logo
54 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
