I have a goodman heat pump model# PC036-1B REV E what is th age of the unit seer # and tonnage please help me I need to replace it
  • wbhudson81 Feb 03, 2009
    the serial # is 9605017287
  • 96 Answers
Without the serial # can not give year but is likely a 10 seer unit and a 3 ton
Posted on Feb 03, 2009
What seer and tonnage is a Bryant condenser unit model # 561CJ048 and serial # 4598E06708?
According to the specifications here: http://dms.hvacpartners.com/docs/1009/public/01/pds561c.18.10.pdf , all Bryant 561C air conditioners are 10 SEER. The 048 model has a 4 ton nominal cooling capacity.
I hope this helps.
May 04, 2017 | Bryant Heating & Cooling
2002 need model number to answer tonnage
Aug 25, 2014 | Goodman Heating & Cooling
I was just trying to find information on this model such as seer rating and how many tons it is
Check the model of you unit. Normally Maximum manufacturers shows the tonnage in the modewl itself. e.g........ xyz 018 means 1.5 Tr .. abc.....cor24 mni... 2TR.
Normally 12000 BTU means 1 TR. which shows as 012 or 12 like this.........
And also with amphs you can find out thew tonnage. Amphs for 1 TR under 220 vts will be maximum 4.8 amphs. If it's 1.5 TR........ 8.5 amphs
Dec 05, 2010 | Goodman Heating & Cooling
How do we use the model number to figure out the tonnage and seer rating? The model number is CKJ60-1C and the brand is Goodman
this is a 5 ton i would need more info to tell you the seer i want to say it is 10 seer due to the ckj but so many brands makes it hard to remember call 865/588-0521 ask for counter sales give that model they may ask for serial # too they will tell you all this
Sep 12, 2010 | Goodman Heating & Cooling
I HAVE A GOODMAN MODEL CKL36-1D I'M TRYING TO FIND OUT THE SEER RATING ON THIS MODEL.CAN ANYONE HELP?
Your going to need to know the age of the unit. If its less than 5 years old, its most likely a 13 SEER. If its anything more than 5 years old, its most likely a 10 SEER. If its anything over 10 years old, its most likely an 8 or 6 SEER.
Remember, that a unit will loose an average of 1-2 SEER for every full year of operation. This is just due to age, wear and tear, and usage.
So, if its a 10 SEER unit that is 7 years old, you could say that it is about as efficient as something in the 4-6 SEER range.
Jul 12, 2010 | Goodman CKL36AR36 Air Conditioner
Can I mix brands/tons when installing AC unit to existing coils?
First off - the 'rule of thumb' is 600' per ton of Air Conditioning. In other words your old unit is a 2 ton unit. So - 2 tons x 600' = 1200'. As you can see if you install the 2.5 ton unit - you will be installing a AC that 'could' cool a 1500 sq ft house (2.5 x 600' =1500 sq ft.). Slightly more than what you need; and the 3.5 ton unit is 'way to big,' (3.5 x 600' = 2100 sq ft.).
Note: fyi - many in the AC business will sometimes refer to tonnage in btu's, i.e. 1 ton = 12000 btu - hence a '2 ton unit' can also be referred to as a 24000 btu unit and vice versa.
So... from the above - you can easily see that "2 tons" of Air conditioning is what is required to cool the 'average' home of 1100 sq ft. "roughly speaking."
Note: it is always best to have a professional 'size' your cooling/heating needs.
One of your questions was could you 'mix tonnage?'
The answer is 'usually you don't mix the tonnage of your outside/inside units.' However, professionals sometimes do (mix the tonnage) in certain situations, and installing a 2.5 ton outside unit with an existing 2 ton inside unit is often done, however, there are some 'tech issues' here and - I would "again" recommend that you call a Service Tech to help you with the sizing/mixing of your cooling/heating needs.
hope this has helped
Jun 20, 2010 | Carrier 38CKC036 Air Conditioner
Heil Heat pump model # NHP218AKC2, I need the specs to replace an old unit in the other side of my duplex
I can help you on part of your question, the system that you listed above is a 1.5 ton unit, if I had the serial number I could give you the age of the unit. If it is a late 1990 model, then it is probably a 10 SEER unit, maybe a 12 SEER, if it is older than 1994 it will be a 8 to 10 SEER, but due to new federal rules, all new heat pump or air conditioners are at least 13 SEER. If you just replace the outdoor unit and leave the coil indoors, it will be mismatched and cause the unit to be less effeciant, and some problem in adjusting the Freon levels.
Ideal is to change the outdoor unit and indoor coil.
I hope this helps, I am new to this site, so I am still trying to get to the point, and yet give you the details that you need.
Sincerely,
Paul Gibson
Mar 29, 2010 | Goodman Heating & Cooling
I HAVE A GOODMAN FURNACE GMS8 WHAT IS THE LARGEST SEER RATED AIR CONDENSER WILL WORK WITH THIS UNIT.
seer is not a problem....18 would be fine.depending on the size of the blower,you may have limitations on tonnage of the ac.
Sep 10, 2008 | Heating & Cooling
Someone has an Intertherm outside 3.5 ton a/c unit for sale but doesn't know anything about it Model 5SQD-042KA Serial S5A070500546 Can you tell me how many SEER, heat pump or not,...
There should be a square sticker or metal plate that tells you the model # the #'s that comes close to the multiplecation of 12 =to tonnage,example ( asbv036g-1 the 36 = 3 tons 12x3=36 (gdhe420-1 = ==3-1/2 tons cooling 12x3 plus 6-1/2 ton = 3-1/2 tons the serial # tells the year it was made.....080808 , the first 4-#'s tells you the month--- for 4 #'s this is aug.- year 08 !
Sep 05, 2008 | Intertherm Heating & Cooling
Heating & Cooling Logo
223 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
