Question about Microwave Ovens
Mounting problems I need to find the bolts that mount the microwave to the cabinet above. Where can I find them? I have checked the internet with no luck.
  • William Miller
    William Miller May 11, 2010
    Please reply back with your brand and model number so we can help you.
  • 4 Answers
You may be looking for this Flathead 1/4 x 28 threaded bolt that is about 4" long. The tip of the bolt does not have threads, which aids in locating the threaded hole in the top of the microwave:
GE # WB01X10180 (or AP3205964 or 942461 as listed on some repair parts sites
or a set of three
GE # WB01X10125 (or AP3185225 or 910236 as listed on some repair parts sites)
Posted on Apr 27, 2009
Over range microwave doesn't fit in the space outlined by the installation template
You missed something while reading the installation directions but that won't fix it. since you already drilled holes in the wall lower the mount down as needed then drill new holes in the mount to match the holes you drilled in the wall. The problem would have been worse if you were off left or right... up and down is easier. Remember you maybe just not dropping the microwave low enough to fit in the slot at the bottom of the wall mount before you tilt the micro up.. check it one more time...including the directions before you re-drill
Sep 26, 2015 | Bosch 30" 500 Series Over-The-Range...
Tip
How to replace the bulb of a microwave oven
Replacing a Built-in Microwave Oven
  1. Step 1 Locate the cabinet above the built-in microwavemag-glass_10x10.gif oven. Find two screwed-in bolts. Unscrew the bolts while someone holds the microwave steady.
  2. Step 2 Unplug the electrical cord from the cabinet above and snake the wire down the hole towards the microwave oven. Continue having someone hold the microwave steady.
  3. Step 3 Roll microwave to left or right to set it free from the mounting bracket in the back. The microwave oven should now be unlocked from its position and can be removed completely from the area.
  4. Step 4 Install the mounting bracket on the new microwave that was included in the package.
  5. Step 5 Snake the electrical cord of the new microwave through the hole in the above cabinet. Plug in the electrical cord.
  6. Step 6 Lift the microwave and rest it to line up with the existing mounting plate on the wall. Roll it until the microwave is locked in place.
  7. Step 7 Use a screwdriver or electric drill to screw in bolts above cabinet into the microwave mounting bracket. This will keep the microwave securely and tightly in place. Your new microwave is ready to use.
on Apr 04, 2010 | Microwave Ovens
How do I remove a 1991 Roper over the range microwave. There are no cabinets above it that it would be screwed into.
If it is not mounted above, it is most likely attached to a mounting bracket behind the microwave. I would start with removing the vent cover (if there is one) and check for access to screws or bolts on the back side of the microwave. Make sure that you have a friend helping!
Some other tips:
http://www.ehow.com/how_4452966_remove-wall-mounted-microwave-oven.html
Jul 25, 2014 | Microwave Ovens
Trying to remove 1874 Microwave from 05 Dynasty. Mounted in slideout
Dynasty, There 2 long bolts toward the front floor of your overhead cupboard, could be under false floor of same. The lower underside will possibly be secured to mounting plate at back. Be sure to remove these screws otherwise you may bend your mounting plate.
Feb 15, 2012 | Sharp R-1874 Convection/Microwave Oven
What size bolts do i need in order to mount it under the cabinet. the bolt that comes from the cabinet into the micro
mcdevito75 here, Best Bet bring the mounting bracket and bolts recieved with the unit to your local hardware store. they will give you the correct bolts need to mount undera cabinet.
Jun 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a whirlpool cabinet mount microwave model gh5176xpq-0 I need to remove from the cabinet. I have removed the top mounting bolts but there seems to be something else holding it.
IS THERE A PLATE HOOKED TO THE WALL IT IS RESTING ON. TRY PUSHING UP THEN OUT. IF THERE IS A CABINET ABOVE IT YOU MAY HAVE TO LOOSEN IT ALSO
Mar 06, 2010 | Whirlpool Microwave Ovens
How do i take microwave off wall i took 2 bolts off in cupboard above microwave and microwave did not budge at akk.
There should be two or three bolts inside of the cabinet above the microwave. Remove all bolts and then pull top edge of microwave forward (away from wall). It pivots on a mounting plate which is secured on the wall. Pivot forward and lift microwave up a little bit off of the ledge of the rear mounting plate.
Make sure to feed the electric wire (plug) through the hole in the cabinet as you pivot and remove the microwave. Sometimes cooking grease will make the microwave stick to the cabinet. So after removing the bolts use gentle force when pulling on the microwave.fce1346.jpg
I hope this helps and good Luck!
Feb 16, 2010 | Magic Chef CMV1000B Microwave Oven
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
Mounting OTR microwave oven under a penisula cabinet
We put false doors on the back of the peninsula, mounted the wall mounts on the inside of these doors and then connected it to the top.
Mar 24, 2017 | GE Profile Spacemaker Over-the-Range...
Kenmore galaxy model 721 microwave hood combination
You put a mounting plate on the wall behind where the unit will be mounted. Then the microwave hooks onto the bottom of the mounting plate and you swing it up to the cabinet above it. Then you must screw 2 mounting screws through the floor of the cabinet above into the bracket on top of the microwave.
Jul 01, 2008 | Microwave Ovens
Microwave Ovens Logo
161 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
