Question about OKI MICROLINE® ML390 Matrix Printer
I need to connect my printer ml390 with a serial port rs232 DB25
I have a printer MiroLine turbo 390 with a serial port RS232 DB25, and a converter RS-232 to RS-422/485 model 485DRCI. I need to connect the printer DB25, with the serial port RS-232 DB9 of the converter.
Wich is the pinout taht I have apply to make the cable connection?
4 Suggested Answers
SOURCE: there is a serial port besides the parallel. how can i make it work with serial cable?
I know this is dreadfully old, but when using a Parallel-to-USB adapter with a non-USB printer, once the drivers have been installed for both the printer AND the USB adapter, you often have to point the printer driver to the correct port. Do this by going into the properties for the printer in the Printers folder (right-click, select properties). Select the Ports tab, then scroll down the list until you see the entry for the USB adapter - something like 'USB001 - Virtual USB Printer Port' or similar. Select this, hit 'OK' and give the test print a whirl.
Posted on May 30, 2008
ginko
  • 19396 Answers
SOURCE: I need to know how to print a test page on a Oki
Try Select, or Shift and Select, or Shift and Print.
See reference manual in here.
Posted on May 18, 2009
  • 71 Answers
SOURCE: converting printer from parallel to serial connection
There is a Parallel to Serial converter cable that you can use. You may find it on a computer store.
Posted on Jun 18, 2009
Why cant I get my computer to accept it
you might have to set up the serial port settings with speed (baud rate) number of stop bits, even or odd parity. suggest google how to set up serial port on whatever operating system you have. does the p.c even have an rs232 port may need a usb to rs232 adapter device.
Apr 20, 2015 | Honeywell MS5145 Eclipse with Codegate...
RS422 or RS232
As far as I know ALL Panasonic Toughbook
(which have a bult-in serial port)
the serial ports (DB9) are RS232.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Jul 06, 2014 | Panasonic Toughbook CF-52 (CF-52ELNBDAM)...
USB TO SERIAL WIRING
You can not directly wire USB to rs232 serial via wires. They are different protocols with different voltages, speed, communications, etc.
You require an active electric converter which contains circuitry to transform the protocol.
USB to serial converters are pretty cheap. They will automatically show up as a com port on windows or as /dev/ttySx on Linux.
May 21, 2014 | Olivetti PR2E Matrix Printer
My notebook computer only has USB plug and it does not has serial port plug (RS232). I bought a USB converter cable for the RS232 plug. The notebook computer reconciles the USB converter cable and not...
Tthe Capshare only works with XP or Windows 7 Ultimate which has a virtual XP inside it ( a retrofit for outdated software).. I will not work with VIsta.
Feb 13, 2011 | HP CapShare 920 Handheld Scanner
Kids gave me a printer/scanner Epson model number c171a. Need the cable to it. AN oldie but looks like a pretty nice printer. Can you help??
The cable you need depends on the unit. I am not aware of a C171a model from Epson. I have seen it listed as a version of the RX500. In that case you need a USB cable with A/B male ends.
Otherwise, most printers (from about 1997 on) will use a USB cable. This has two male ends - a square end goes into the printer and a rectangular end that goes to the computer (called A/B). For older printers (there may be multiple ports or just one), you may see a parallel port (the cable has a wide rectangular plug on both sides with 36 pins) or serial port (the cable may have DB9 (9 pin), DB25 (25 pin) or both). Often it is called a RS-232 port. For a parallel port connection, you would need one that is designed for scanners and bi-directional communication (USB to parallel adapters are available to connect this to a new computer but you still need the bi-directional version). Similarly, USB to serial adapters are available.
Generally you can tell what cable you need by looking at the back of the unit where the ports are. (Although some all-in ones have the USB cables in other places - routed through the side of the unit but the plug is near where the ink cartridges go.) Then the size and pin counts for parallel or serial tell you what cable to get. There is usually a symbol indicating the cable type as well near each port. USB cables are usually indicated by a tree like symbol with curved branches.
I hope this helps.
Jul 25, 2010 | Epson Office Equipment & Supplies
How to connect my laptop via RS232 to my NEC XN120 telephone exchange using the PC Pro telephone system software in order to programme the exchange?
I connect mine with the RS-232 cable in the side of my laptop. It's a Toshiba rinning Windows XP (nee Vista).
Since you're asking the question, I guess you don't have an RS-232 port. For my Vista machines without serial ports, I own a USB to RS-232 adapter cable. On our side of the pond, they carry names like Iogear GC-232. Here's a U.K. search result http://www.amazon.co.uk/USB-RS232-Converter-Cable/dp/B00077DJIQ
Sometimes, you have to go into the device manager and change the port assignment of these adapters to something in the 1-4 serial port range. That was common with the old software.
Carl
Feb 22, 2010 | NEC Lands Phones
I need a 15 pin serial cable to USB adapter. Having trouble locating one :)
Here: http://images.google.com/imgres?imgurl=http://www.uxsight.com/product/images/c/en/usb-rs232-db9-9pin-serial-cable-db25-25pin-parallel-adapter-com-xs0065090316c.jpg&imgrefurl=http://www.uxsight.com/product/29236/usb-rs232-db9-9pin-serial-cable-db25-25pin-parallel-adapter-com.html&usg=__WqWw10iNkCZ7AwioDUW5DOvnHwI=&h=286&w=594&sz=37&hl=en&start=4&sig2=SqUqch5MFMdtlYcPZgGOkg&um=1&itbs=1&tbnid=MtLIazQSQfuOUM:&tbnh=65&tbnw=135&prev=/images%3Fq%3D15%2Bpin%2Bserial%2Bcable%2Bto%2Busb%26um%3D1%26hl%3Den%26client%3Dfirefox-a%26sa%3DN%26rls%3Dorg.mozilla:en-US:official%26tbs%3Disch:1&ei=j7CJS4zBFIaVtgeDxIyZDw
Feb 15, 2010 | Logitech WingMan Extreme Digital 3D...
Hi I'm Kandy When I try and load a card stitch I keep getting the following error message: PCDWIN22 Caused a General Protection Fault in Module PCD_WIN.EXE at 0005:38F6. The software then shuts down. I...
I replaced my USB/Serial RS232 port adapter with a genuine RS232 serial port on the PC. THis solved the problem. Further reasearch on the net indicated that USB to RS232 - serial port converters do often have problems. I previously had not had a problem running on Windows XP and this is what alerted me to the possibility of the USB/RS232 port adapter as a possible reason for the "new" problem.
Oct 24, 2009 | PfaFF Creative 7570
My adapter DB9 FEMALE TO DB25 FEMALE doesnt allow me to see my Printer
Are you tring to run a parallel printer from a serial port? If so then it will not work at all. You would need a serial to prallel adaptor that also has the software drivers needed to convert the signal.
Jun 13, 2009 | Parallel 25 Foot DB9 Female to DB25 Male...
OKI MICROLINE® ML390 Matrix Printer Logo
63 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
