Question about HP Officejet Pro L7680 All-In-One Printer
Top document feeder needs to hand fed
It seems i need to hand feed the first few documents into the top feeder. after a dozen or so , it may start feeding by itself. it seems to start to feed then nat get picked up by a second set of rollers
it is too bad hp has become such junk. it used to be the most reliable equipment in labs at engineering school.
now all my new hp printers have problems
    Scholar:
  • 169 Answers
Well u need toclean the adf rollers with a cloth .if ot does not work align the cartridges and then try a reset using the # and the number 6 buttons on the front panel.Hold down these keys and then plug in the power cord.
If you want any further support a technician can help you online for free.You can find free online technical support at http://tinyurl.com/m7ghqz
Posted on Jun 19, 2009
When we feed documents through the document feeder the copies come out blurred. We do not have that problem when we place the documents directly on the glass plate.
When paper is fed through the document feeder it scans the whole page on a little strip of glass about an inch wide and about 12 inches long. That strip has dirt on it that needs cleaned off. Lay the bad copy on the glass (face up) and you can line it up with that little glass and see where the lines match up. Clean that little glass with alcohol or glass cleaner and it will be fixed :)
Mar 31, 2015 | Office Equipment & Supplies
Cannot clear error message "Document
Hi nigel_lester,
This error message "Document in ADF" that you are getting means that you need to remove foreign object from the Automatic Document Feeder (ADF). Kindly follow the procedure below in clearing document jams:
Document jams in the ADF (Document Tray)
1. First, press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF. 3. Then, open the Feeder Cover.
4. From under the roller to the Feeder Cover side, remove the jammed page.
5. If a document is not jammed, check the document feed area if there's foreign material. If there's any, carefully remove it.
6. Close the Feeder Cover.
NOTE:
  • If documents remain in the ADF after pressing during scanning, [Document in ADF] will appear on the LCD. Press so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (inner side)
1. Press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
4. Open the Document Cover and pull out the document from the inner side.
5. Close the Document Cover.
Note: When rescanning the document after clearing the error, rescan it from the first page.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Canon Office Equipment & Supplies
I have a Cannon Pixma MX320 all in one printer and I cant get it to stop saying document in ADF
Issue: ERROR LCD: DOCUMENT IN ADF
Solution: Remove foreign object from the Automatic Document Feeder (ADF) - MX310
Check the Automatic Document Feeder (ADF) for obstructions
Follow this procedure to check the ADF for obstructions. You do not need to turn off the power when clearing document jams.
  1. Press <Stop/Reset>.
  3. Remove the jammed page from under the roller to the Feeder Cover side.
  4. Pull out the jammed document from the ADF. If the document cannot be easily pulled out, proceed to section Document jams in the ADF (inner side).
  5. After removing the jammed document or if a document is not jammed, check the document feed area to make sure there is no foreign material. If you find foreign material, carefully remove it.
    Note : If documents remain in the ADF after pressing the Stop/Reset button during scanning, "DOCUMENT IN ADF" appears on the LCD. Press the OK button so that the remaining document is automatically fed out.
    Note: The document may not feed properly depending on the media type, or your environment, such as when the temperature and humidity are either too high or too low.
    In this case, reduce the number of document pages to approximately half of the loading capacity. Another alternative is to scan from the platen glass
  • If documents remain in the ADF after pressing <Stop/Reset> during scanning, [Document in ADF] will appear on the LCD. Press <OK> so that the remaining document is automatically fed out.
Document jams in the ADF (Document Output Slot)
If the document is jammed in the Document Output Slot, pull it out.
pulloutofslot.gif Note: When rescanning the document after clearing the error, rescan it from the first page.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Canon PIXMA MX310 All-In-One Printer
Original document fed into top feed tray of mfc 7440N model come out with few thin black lines on the mid left of the scanned file. Scanning file from glass has no issue.
You need to clean the narrow glass strip on the left side of the machine when you open the cover. There is likely lint or something on this glass. This is where the auto document feeder pages are "imaged".
May 20, 2010 | Brother MFC-7440N Laser Printer
My printer says "close document feeder cover". I don't know where this is
It is talking about the flap that is on the very top just above where one puts in an original to auto feed on to the glass, this access cover is required to be open and closed by the machine because it feels something is holding it open or its switch that tells it such is stuck. Maybe a jam from last original fed into it..
The cover once open check around for paper fragment and inspect little levers that hang down, one is stuck or there is paper stuck in Document feeder
I have found that often label bits, paper clips, punch bits and small corners of paper often get in the path, I use a piece of laminate cut so it has a v or a point and feed it in the document feeder, manually inserting it in the direction a piece of paper normal travels in it.
Push it all the way threw not pulling back (bad for it) to do so poke the point threw, you will need the top cover open and lift off the glass, so you can grap the point and pull the laminate threw.
Nov 04, 2009 | HP OfficeJet d145 InkJet Printer
Scanning a legal size document
Move the document feeder front guide towards the rear of input tray, line up with 8 1/2" marking. This should inform the machine to register for 8 1/2 x 11 or 8 1/2 x 14 originals>fed lengthwise.
Jun 01, 2009 | Canon iR 2022i Printer
Document Feeder Jamming.
The feed rollers may be worn out and need to be replaced, you can try cleaning the rollers with some alcohol, this may also make it feed better. but if it starts to act up again it might be time for new rollers.
Hope this is of some help.
Ed
Apr 30, 2009 | Office Equipment & Supplies
Check document message
you will almost certainly have a torn piece of paper ( or small document) in the document feeder sitting over a sensor.It doesn't need to be very big to be detected.Open ALL covers on the feeder, check particularly at the edges of the feed area where you may have torn a corner off.Sometimes you can hand feed a piece of card through by turning the belt or rollers and push any obstruction out..........
Jul 28, 2008 | Canon imageRUNNER 1023iF Black and White...
ADF for MP530 does not work
Welp, I pulled out my screwdriver and fiddled around just a bit and got documents to feed again (yay!). I do not believe this is a permanent fix, though, but it was enough to get my document scanned in without me having to feed each sheet manually.
Step 1: Open the document feeder cover. Easy to do, you just stick your hand under it and lift up. It has a little pressure because of the latch but it is designed to give way when you lift hard enough. Once it's open, pull out the little black plastic piece that keeps the cover from swinging all the way open.
Step 2: Unscrew the ADF motor/gear assembly cover. There's a single screw holding it in. Once you unscrew it, you'll need to pull up on the left side of the cover until it pops upward, then you need to push the cover towards the left until it is freed up from the rest of the cover. This one was a little tricky. Several times I thought I might break it (before I realized that I needed to push the cover towards the left) so try not to apply unreasonable force while you're doing this.
Step 3: Close the document feeder cover, put your documents in the feeder and start your scan. Use your fingers to fiddle with the gears while the ADF motor is running and trying to feed documents. I'm not sure if I flicked the little gear upward or downward to get the documents to feed, but one of those ways got the documents to start feeding. Once it started feeding the first page, it seemed to work well for the rest of the pages without me having to fiddle with it anymore.
I am guessing that there is some level that controls the location of the middle gear that needs to be oiled, but I didn't go any further to try and make that happen. Hence this is probably just a temporary fix for now.
Putting it back together is pretty straightforward. Just do the reverse of what you did to get it open.
Hope this helps someone!
Jan 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Document Sheet Feeder
hi im jules_09,check the pick up,bottom plate and feedout motor then the rollers,then the fed belt,also try lobricating the gears,check all parts first before replcing it save you time and money.
Nov 08, 2007 | Ricoh Aficio 450 Copier
HP Officejet Pro L7680 All-In-One Printer Logo
126 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
