Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool washer leaks
My Whirlpool washer model LA5668XSN1 on the bottom right side mainly while using the permanent press cycle. What could this be? How do I remove the top pane to see if the vent is leaking?
  • 2 more comments
  • jerry23 Feb 07, 2009
    egraber,
    As soon as I moved the clamp on the drain hose (the one that goes to the back of the machine) water was leaking out. What could this indicate?
    Jerry23
  • jerry23 Feb 14, 2009
    Egraber,
    I had more time to observe the washer today and it is dripping from the right side as you face the machine. It drips when the tub is filling and almost to the top right before it starts to agitate. It is in large load mode. As soon as it is done washing I will tip it up to see if I can trace where the water is coming from.
    Jerry23
    Egraber,
    I noticed that there is water near the center, by a bracket around the semi clear white plastic tub area.
    Jerry23
  • mikeandapril Mar 14, 2009
    mine is leaking also. i figured it would be the pump so i took the back off to see. hooked everything back up and running it through the cycles. now that i have it apart i cant get it to leak.going to try and put it back together and see what happens now.
  • 530 Answers
Do not remove the top panel. First tip the washer back. NOT ALL THE WAY. just enoough to see under it. you will see a pump. it is attached by 2 hoses. one to the tub and one to the drain. take the 2 clips off with the hoses still attached. tip it downward. Is water leaking oout of it? let me know thanks
Posted on Feb 03, 2009
  • 2 more comments
  • erica graber Feb 09, 2009
    do you see a hole in the pump. like a black bubble? yes, water will come out if you take the clamp off. what you want to see is a hole in the pump it's either on the shaft side or usually on the front side where you would see the black bubble with a hole where the water will leak out. let me know if the pump has a leak with the hoses still attached? if the pump has a hole in it or is leaking out of the side where the motor attaches(shaft side) then you need to replace your pump. You say it is leaking from the left side. Another way to find out where it is truely leaking from is to turn the washer on. get on the floor and shine a light under it and see where the drips are comeing from and follow the stream. let me know how it goes
    the whole cabinet does come off. I can tell you how it comes off if it is not leaking from the pump.
  • erica graber Feb 15, 2009
    you probably have a bad fill valve.it's on the right side. you need to take the cabinet off. swome units have hidden clips under the consol on the left and right side you would need a putty knife and push under consol and pull consol up it's kind of tricky. there are also models that have 2 screws onthe back side of the consol left/right side you would need to remove the screws and pull consol topward you and up. next you will see 2 gold clips you need to take those off get a flat screw driver push down and out. don't forget to remove the door switch. make sure the power is turned off. the whole cabinet should come off now. you will be able to see where the water is l;eaking from now. let me know how it goes
    that plastic piece is apart of the tub. it's called the air dome. it sends a signal to the pressure swich when it is full of water. Do you have a mouse? because sometimes i see mice get into washers and chew the hoses looking for water. this also might be your problem.
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
It says "Control Locked".
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Maytag washer leaking between cycles or if stopped during fill
lift the top up on the washer and see if the fill hose is crack or broke,hose on right side
Jun 18, 2009 | Whirlpool LSN1000LW Top Load Washer
ULTIMATE CARE II WASHER - MODEL LSQB520JQ0 IS LEAKING
you can tip this unit back, the bottom is open and then oyull be able to see where the leak is coming from, any part wharehouse(online stores as well) will stock the pump if needed.. most common cause of leaking pump is fron center shaft youll see the water line
Mar 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer fills during spin cycle
Replace the timer, you can find the product name model and serial number on two place. Either the back panel or on the lid underneath. Please rate if this helped thank you
Feb 12, 2009 | Whirlpool LTE5243D Top Load Stacked...
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
Regarding those Cabrio washers that are leaking, while I own the WTW6600 model and have never experienced any leaking, I was told by the service repairman who came out yesterday that there was a flash bulletin sent out by Whirlpool that the fix is in the form of a new inner plastic section. I don't know the technical terms but I saw the bulletin on his computer screen. He mentioned that some people had reported that water was on the left side front of the floor and was being caused by when the water flows through the top section where you pour the liquid detergent, on some models, the water would splash over. He was able to show me the redesigned piece that was being put in to replace those that have the problem. If you are experiencing a problem with water leaking from the unit, and it appears to be in the front, left side area, this could be something covered under that service bulletin.
Sep 01, 2007 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
227 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
