Question about Maytag Performa PAV2200
Washer walks across floor no matter what problem.
Our Maytag Performa walks across the floor even with sheets in it. Not sure what to do any more. It is always out of balance.
  • Aussieq Feb 15, 2009
    I have a PAV3300 which walks across the floor and vibrates violently, even with the smallest of loads.
    We have had it serviced but that has not stopped it walking and shaking.
    I have never seen this before in a washing machine. It is the first time I have ever used a Mayatg.
    Problem Solver:
  • 15 Answers
FIRST OF ALL SCREW THE FRONT LEGS ALL THE WAY DOWN THEN TILT THE MACHINE UP FROM THE BACK MEANING THE BACK SIDE UP SET DOWN FIRMLY THIS WILL AUTOMATICLY SELF LEVEL THE BACK LEGS THEN UNSCREW THE FRONT LEGS TO MAKE LEVEL WITH YOUR FLOOR THIS SCHOULD FIX YOUR PROBLEM THANKS GLAD TO BE OF SERVICE
Posted on Feb 04, 2009
Maytag washing machine walks across floor during spin cycle
Did you set the back feet before leveling? On most units to set and lock the back feet you need to pull the top towards you so that the back is raised off the floor, then set it down again, this will release the feet and lock then down. The you level the two front feet. After this is done you must make sure your load is balanced. Distribute the items as evenly as you can in the tub. Once it gets to the spin cycle if its walking or shaking a lot, stop it and redistribute the items more evenly in the tub. Also try not to overload the unit or combining many heavy items with few light ones. If this is a new machine, did you remove the shipping locks from the back before using it? They have plastic strips attached to them, make sure they have all been removed, as well as any shipping bolts.
Feb 17, 2015 | Maytag Neptune MAH6700A Front Load Washer
Maytag performa walks all over the floor during the spin cycle what to do?
Make sure the feet are level and that the plastic caps on the feet are in place. Sometimes they are left off during installation.
May 02, 2010 | Maytag Performa PAV2200
Maytag pav2300 spin cycle spins unbalanced and walks
I have the same problem from day one........... help
Dec 16, 2009 | Maytag PAV2300 Top Load Washer
Maytag performa washer walks across floor when it spins. How do I remove outer cver to see if I can find problem?
Try levelling / stabilising first , pack underneath wherever it wobbles when off.
Nov 11, 2009 | Washing Machines
Goes of balance. even with small load. it walks across the floor. clothes seem to gather to one side.i have leveled this machine, but no luck
There are 8 springs in the bottom tube to hold on the chassis. If some of them broken, it may cause this problem.
Jul 02, 2009 | Maytag Performa PAV2200
PAV3300 ( Australia )
there is a plastic piece between the base and the gearbox assembly. it needs replacing as do the springs that go from the base to the washing drum. also make sure the floor is level
Feb 15, 2009 | Maytag Performa PAV3200
Unbalanced washing machine
there may be shipping bolts that you have to remove.read your instructions 2 see
Jan 02, 2009 | Maytag Performa PAV2200
Maytag Washer MDE7400AYW goes off balance while spinning about half the time. Walks across room. Springs are OK. Tub seems very easy to move from side to side by hand.
Typically when the drum spins and walks the washer, it is a loading issue.
As the clothes spin, they collect on 1 side, due to cintrifical force acting upon an uneven load.
THis is especially prevalent in loads that are:
1. small,
2. contain lots of towels and
3. anything else that really holds water and is very heavy when wet (like comfortors, pillows)
These will very quickly throw the load off-balance.
When it happens, pull out some of the itmes, and re-load the laundry more evenly around the drum. Be sure to circle the post with towels and sheets, etc.
If you continue to run the machine off-balance for an extended time, the bearings and seals will wear quickly. Unfortunately, you will only know this when the washer begins to leak out under the machine onto the floor.
Hopefully this will fix-ya....if not let me know please!
Nov 07, 2008 | Maytag Washing Machines
Neptune washer walking across the floor
Need to know how old your machine is and if it is on a pedestal. What type of floor is the machine sitting on ?
Jan 25, 2008 | Maytag Neptune MAH6700A Front Load Washer
Washing Machines Logo
720 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
