I have been given a gestetner c7416 printer. How do you load paper in it?
You're kidding right? pull open the drawer, and place the paper in, close the drawer...Ta-daaaa!
Don't forget to plug it in, turn it on, install the drivers on your computer.....on second thought......
Posted on Feb 19, 2009
DSm725 paper misfeed error
try cleaning the feed wheel in the paper tray cause that will not be picking up paper works for me .try using a damp cloth
Aug 20, 2013 | Gestetner DSm725 All-In-One Laser Printer
How to change paper setting on tray 1 for a gestetner DSm627sp?
press the counter key.
tap the system settings on the screen
select tray settings and select the type of paper you prefer and tap on the ok .
After this open the tray and set the tray settings to the paper size.
All the best of luck .
Jan 04, 2013 | Gestetner DSm627sp All-In-One Laser...
Gestetner 6123 paper jaming feeding section copy printer
nrg 6123 copy printer after make stencil line on copy soulition
Jun 15, 2012 | Gestetner - AO40 Wide Format Copier Copier
My gestetner c7526dn says to open front cover A to remove paper, but there is no paper stuck in there. Is there a temporary override? Is there a sensor that could be de-sensitized until I can get someone...
Sometimes my laser printer gives me a false report of stuck paper. Try turning printer off for 20 seconds, also open paper try, check paper and slide tray back in firm. Those might work, mine's done that several times over a few years.
Jan 15, 2011 | Gestetner C7526dn Laser Printer
Can't find paper jam. Looked and looked. Its a
hi if u cant find any bit of paper in paper path may be any path sensor out of order or may be dusty sensor just clean the all paper path sensors
thanks
May 13, 2010 | Gestetner DSm618d Copier
Help my A045 Gestetner will not load paper after several short beeps
If you are changing a paper roll, make sure you can advance the paper through the "throat" using the green knob and then manually trim it. If you are loading paper in the cassette tray, make sure you adjust the green sizing guides to match the paper dimension (8.5x11", 11x17), etc.
Mar 27, 2009 | Gestetner A045 Wide Format Copier
I am totally lost on how to add more toner to the
You can go here and download the manual. Even though it's a Gestetner...it cross references to a Ricoh Aficio CL2000. Ricoh builds all of their machines. Look for it under "printers"..."color":
http://www.ricoh-usa.com/downloads/manuals.asp?tsn=Ricoh-USA
I don't know if this will solve the "blue ink everywhere" problem
*Please rate me :)
Mar 14, 2009 | Gestetner Office Equipment & Supplies
Cannot print from Tray 1 in Gestetner 6002
First make sure that the machine is reading/ seeing the paper size of the paper that is in the tray ( select tray 1 from the touch screen and see what the paper size reads). If the machine sees a different size then that in the tray, use the 'user tools' and change the paper for that tray. Also, go into your printer settings on/in your computer and make sure that the proper paper size is selected ( the size that is in the tray you want to print from). If the orientation of the paper size is different from the tray -- will not print and give you the error.
May 06, 2008 | Gestetner - 6002 Digital Imaging System...
k24674
jasbo
jasbo
