Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Will not spin or drain.
The washer goes through the was cycle fine. Will not go into spin cycle and will not drain. When the rinse cycles end it just shuts off.The lid strike has already been checked and seems fine. Also I noticed that the knob does not spin when the cycle is going. I'm assuming that maybe I have a switch problem?
  • Anonymous Feb 11, 2009
    will not drain or spin. lid switch was checked. has mind of its own. any solutions?
  • JayPUPULE Feb 14, 2009
    Wow, same problem! Washing stopped on spin cycle towards end of wash. I took everything out and flipped washer on side. I noticed that when I try the spin cycle, I can hear the motor and can see it tries tio turn... that's it. Played with the lid switch.. seems to be working... Need help,, can't afford service rep that said will cost around $150 up to check on fix... maybe more. New washer is $449 down the street w/ warranty.
  • 150 Answers
Sounds like the cycle timer has a defect and needs to be replaced,sometimes you can get a used one at a used appliance store. there not that hard to replace.
Posted on Feb 17, 2009
My Kenmore washer drains after the rinse cycle but won't spin at the end of it's cycle. If I manually set it to the spin cycle, it spins just fine. Desperate!!! The lid switch was just replaced about
Possible there is problem with the timer controller unit. It seems that the stepper motor is not moving to the next cycle until you manually move it to the spin. You can use some contact cleaners on the switch and also carefully try to see if the timer moves within , replacement is a costly issue and must be debated
Nov 20, 2013 | Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
Maytag SAV5910aww will not always drain. Fills and agitates fine but will go through entire cycle without draining. Will sometimes give end of cycle buzz sometimes not. If I am in the room and lift the lid...
"I have found spinning the timer back to begining of rinse cycle first helps". The timer only rotates clockwise; counterclockwise rotation can destroy it.
May 18, 2017 | Maytag SAV5910 Top Load Washer
Maytag Atlantis MAV7200 doesnt drain at end of rinse goes to OFF
It sounds like it may be the lid switch. It may be as simple as adjusting or tightening. But ultimately it may need replacement.. Hope this helps
Apr 04, 2009 | Maytag Atlantis MAV7000
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
56 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
