Question about Lexmark X1270 All-In-One InkJet Printer
Lexmark all in one 2600 cannot scan...software re-installed
Printing normal, but scanner doesn't seem to be working
  • 2 more comments
  • Anonymous Feb 24, 2009
    i dont have the install disk
  • buckzo Feb 24, 2009
    i dont have the install disk for lexmark 2600 3-1
  • Anonymous Apr 10, 2009
    the printer prints it will scan a photo but only to print it will not scan and send to my Pc..I have uninstalled and reinstallled the software several times. I have un plugged and re plugged both cables. I am at a loss.
  • Anonymous Apr 14, 2009
    scans and prints but doesnt scan on PC. unplugged and replugged everything still nothing
  • Lexmark Master
  • 19,396 Answers
Try first a replacement USB cable.
If it was not a cable problem then you have to reinstall printer software from disk.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printerdoes not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Posted on Feb 04, 2009
2 Suggested Answers
malcolm_m932
  • 33 Answers
SOURCE: scan drivers for lxmark 2600 not found
Try contacting Lexmark Technical support by e-mail or phone. From my experience, the technicians are very helpful.
Go to: http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN_US&productCode=LEXMARK_X2600#1
Or phone : 1-800-539-6275
Posted on Nov 25, 2011
I tried to connect my Canoscan lide 90: when I try to scan: my computer doesn t seem to connect to the scanner: try the cable, connection and turn the scanner on. The connections seem to work... how do I...
Hi ,
The driver is probably missing . You can download and install it from here :http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide90#DriversAndSoftware
Best regards .
Aug 04, 2014 | Canon CanoScan LiDE 90 Flatbed Scanner
HP C309a will not scan on Mac 10.7.5
So, why would that surprise you? Mac is much different than Windows!
May 12, 2017 | HP Photosmart Premium C309A All-In-One...
Lexmark X4550 Scanner not working
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 05, 2012 | Lexmark X4550 Multifunction Wireless Color...
Scanner bulb warming up keeps cycling, seems like the scanner is not working and can not print or copy. Sounds like the movement across the scanner doesn't happen.
Optical scanner assembly faulty, its avil replace it if not open the unit gently remove the cover clean reflecting mirroes with ears buds to aviod scratches, refix and try.. best of luck
Sep 08, 2011 | HP LaserJet 3330 All-In-One Printer
My computer's tower turns on but it doesn't display on the monitor, the monitor shows the normal Self test box so the monitor doesn't seem to be the problem. Also when I press the power off...
Make sure that the cable is connected from your computer to the monitor, and if it is wiggle it and push it in all the way. If it has screws, screw them in. If that does not work, check that your monitor is on the correct input (if it has multiple) then see if anything comes on the monitor. If nothing happens you should buy a new cable from the store. If all of those steps do not work your computer or your monitor might have a more serious problem.
Jul 29, 2011 | Computers & Internet
Have a Samsung SCX 4521F printer scanner machine. Toner is full but won't print when trying to photocopy....will print if something is faxed. The bulb doesn't seem to come on when it starts to...
push menu and # 1943
the fax will go in service mode
push menu again and scrolle until you get new cartrige
push ok
then swich the machine of and on
and it will work
Jul 13, 2011 | Samsung SCX 4521F All-In-One Laser Printer
I have updated my computer to a Windows 7 version and my PrimaScan Colorado 2600u driver does not seem to be compatible
Hello, I've looked around on the website and there doesn't seem to be a driver for this device to work on Windows 7. It doesn't support this operating system, sorry.
You can either downgrade to Windows XP or get a new barcode scanner.
Jul 09, 2011 | Visioneer PrimaScan Colorado 2600u Flatbed...
I had lost the driver CD of Xerox workcentre 3119,after down load the driver and scanner from Xerox website,the printing was back to normal,but can't scanning due to scanner icon doesn't appear at...
erm your best bet is to find where you installed the scan software and find the icon there. Once you fond it create a shortcut to that icon on the desktop.
May 10, 2011 | Xerox Office Equipment & Supplies
My printer doesn`t react
Hi there, " Unplug the printer cable from the computer. " Unistall the printer drivers from Device manager and also unistall the all the printer appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the printer. " then you can connect the printer and and try to Print the test page.
Scanner: Hi there, " Unplug the Scanner cable from the computer. " Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the Scanner. " then you can connect the Scanner and and try to Scan.
Aug 19, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Lexmark X1270 All-In-One InkJet Printer Logo
2,716 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
