JVC L-A10 Turntable won't turn on
As I said it power won't come on. The belt is broken, I don't know if that would prevent the turntable from activating. All wires look good, however I have not looked inside at the circuit boards, any help would be appreciated.
  • BenRecords Feb 03, 2009
    Thanks for very quick reply, I was wondering what to look for if its defective? This turntable has been in storage probably for 15 years or more. I know it needs a new belt, I already replaced the needle. I hope the circuit board is not fried out.
    Problem Solver:
  • 15 Answers
There should be a fuse on the circuit board close to where the power cord connects, check to see if its good
Posted on Feb 03, 2009
How to remove Platter on JVC L-A120 Turntable
Hi Jeff...
The platter on the JVC LA-10 does not come off as most turntable platters do. It is attached to the spindle with a Philips head screw.
Here are the steps:
Remove dust cover from turntable. Unscrew hinges and lift.
00.jpg" alt="Remove dustcover at hinges.">Remove dustcover at hinges.
  • Secure tonearm to prevent stylus damage.
    00.jpg" alt="Secure the tonearm.">Secure the tonearm.
  • Remove slipmat from platter.
    00.jpg" alt="Remove slipmat.">Remove slipmat.
  • Turn the turntable on its side and remove screws that hold the top to its base. Remove platter by unscrewing the bottom plate from the turntable. The spindle bearing is held in place with a Philips head screw. Loosen it and the platter will separate easily from the spindle.
    00.jpg" alt="Separate the spindle from the platter by loosening with a Philips head screwdriver.">Separate the spindle from the platter by loosening with a Philips head screwdriver.
  • Loop replacement band around the pulley cylinder in the motor. Replace platter and bottom plate. Tighten spindle screw. Test the new belt by turning the platter clockwise two or three rotations. Belt should fit snugly and turn with little resistance.
    00.jpg" alt="Test the replacement belt by turning the platter clockwise.">Test the replacement belt by turning the platter clockwise.
  • Feb 05, 2016 | JVC Audio Players & Recorders
    AL-A1 turntable won t turn
    take the platter & belt back off, then check to see if the motor spins, if it does the belts the wrong size or put on wrong, if it doesn't spin then you better get your butter & jam out, to put on your toast.
    Jan 19, 2014 | JVC Audio Players & Recorders
    Locked won t turn
    The belt has stretched from age.
    Jan 03, 2014 | Technics Audio Players & Recorders
    It won't turn
    If the platter doesn't spin then check the belt has not fallen off. It will be seen in a hole under the turntable matt.
    Jul 19, 2013 | Pyle PLTTB3U Turntable
    Table does no rotate
    If it is belt-driven the belt may be broken or fallen off.  Lift the turntable to check underneath.  There may be a spring clip near the center of the turntable that you have to remove to lift it.
    May 18, 2009 | Audio Players & Recorders
    My KD-291RC has power but my turntable wont turn. I touch the needle and I can hear its on and when I move the arm towards the record or set it on it it will not turn. Help?
    Your turntable is belt-driven, it's likely that the belt just fell off. The belt lives under the turntable. On my turntable (a totally different model) the turntable lifts off.
    Apr 13, 2009 | Kenwood KD-291RC Turntable
    Jvc turntable
    hi, please check first your fuse inside your turntable, replace it if possible
    Apr 04, 2009 | JVC AL A158BK Turntable
    JVC L-A10 won't turn on
    the two issues are unrelated. a few turntables won't show life until the tonearm is moved over to the record area. at this point the motor should start turning wether it has a belt or not.
    Feb 03, 2009 | JVC TH-A10 System
    Hi!
    Without any other information (and assuming you've checked to make sure there is power to the turntable and that it is turned on), the likely culprit is the belt drive of your turntable. Most, but not all, turntables have a "belt" that looks like a big rubber band on the underside of the turntable that connects the turntable itself to the drive motor. If the band has slipped out of place, stretched too far from age or usage, or broken, the turntable won't turn. To find out if this is your problem, gently lift the "platter" straight up (it should easily slide back into place) and visually see if the "rubber band" is in place. If it is stretched too far or broken, a new one should be availble form Teac or your local electronics supplier. If, by chance, you have a direct-drive turntable (unlikely), the problem will probably need professional work.
    Good luck and please let me know if this helps!
    Bob
    Oct 09, 2008 | Teac Audio Players & Recorders
    JVC turntable LA10
    The trick is to lift up on the platter (tothat metal on metal feel that you had) while simtaneously "lightly" tapping on the top of the shaft with a hammer. Trust me it will work as just changed my belt.
    Hope that helps.
    Mar 16, 2008 | Audio Players & Recorders
    567 people viewed this question
     Grubhead
    Grubhead
