Question about Sony KV-27FV16 TV
I have a Sony Trinitron (analog) TV. Works well with a Digital Adapter Box. Yesterday I was switching between DVDplayer and TV and must have hit something wrong. The TV shows "No Signal" sign (no sound of course). I tried using TV button, tried re-scanning for the channels, switched off and on -- nothing works. Today is the second day in a row -- shows NO SIGNAL (I do not have cable or dish). Program usually comes fine through internal rabbit-ear antenna and I have fixed the adapter box several months back and it worked fine.
5 Suggested Answers
SOURCE:
SOURCE: Is the Sony FD Trinitron WEGA KV-36FV27 36" TV a digital TV
This is an Analog TV - you will require converter box.
go here to order it: https://www.dtv2009.gov/ApplyCoupon.aspx
jl
Posted on Feb 19, 2008
  • 360 Answers
SOURCE: Sanyo model HT27547 installed to Dishnetwork satellite.
the model you listed will receive digital rf signals without the need for a converter box. the link below is a link to the owners manual for your set, in it you will see what to do to get your local station once the television signals switch to all digital broadcasts.
http://www.sanyotv.com/HT27547%20(E)%200255A-.pdf
Please take the time to rate this solution.
Posted on Jan 29, 2009
ansilgregory
  • 4 Answers
SOURCE: My analog color TV,Sony 20S10, 14 years old, has
are there screw terminals that it connects too? if not but the wire is exposed like you said splice into it add in one of the transformers that has the rf end on the end of it. i would recomend some strain relief
ed
Posted on Mar 12, 2009
SOURCE: Hook up old tv antenna to converter box
You need one of these: http://www.tvconverterboxstore.com/servlet/the-271/digital-analog-converter-tv/Detail
Posted on Jun 12, 2009
I need code for digital stream box for a trinatron tv
Faq - digital stream technology, Inc. ( digital stream ...
www.dsconverter.com/index.php?p=5
Can I use my Universal Remote Control to operate the converter box? ... Do I need a special antenna to receive digital or high-definition TV? .... Note: If you want to reset the remote back to the beginning of the TV code list, clear the memory by ...
Installation - digital stream technology, Inc. ( digital stream ...
dsconverter.com/index.php?p=3
Connecting the DTV Converter Box to your Analog TV Set with RF cable · - Connecting the DTV Converter Box to your Analog TV Set with Audio/Video cable
Digital Stream Analog Pass-through DTV Converter Box
www.amazon.com/Digital-Stream.../B001TO3L8Y
Amazon.com, Inc.
Rating: 3.4 - ‎131 reviews
Digital Stream Converter Box Remote DTX9950 ... RCA DTA-800B1 Digital To Analog Pass-through TV Converter Box ... I think the bad capacitor is something like a 16 Volt capacitor, and you have to replace it with a ... remote(I was able to find the code for my old JC Penny TV), a seperate button for channel signal strength, ...
Amazon.com: Customer Reviews: Digital Stream Analog ...
Amazon.com, Inc.Digital Stream Analog Pass-through DTV Converter Box ... the code for my old JC Penny TV), a seperate button for channel signal strength, ... My brother somehow found out that there have been many of these Digital Stream boxes that were .... button that you can program into your tv (mine is a 1990's 11" Sony Trinitron).
Jan 14, 2016 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Will our Sony Television Model No KD-28-~DX 40U work after the switchoverjanetgrant226@btinternet.com
No,as a tv alone only for recieving a free AIR DTV signal broadcasting signal tv channels.This tv is an analoge tv.U must hookup to any analoge tvs to a box that called a Digital Converter box to used to recieving free AIR DTV broadcasting signal for channels.U still can used it for any analoge tvs if u have a pay tv signal broadcasting channels services.
Sep 04, 2011 | Sony FD Trinitron KV-28FQ75 28" TV
Is the sony trinitron 32"
U have pay cable or satalite service tv incomming broadcasting signal.Yes,than ur tv no need for a DTV converter.Those pay boxes will revert back to analog signal for ur analog tv.If u planning to get free over the air broadcasting,than u need a converter box to convert digital signal to a analog tv.
Mar 21, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Do I need a converter box for a Sony KD-27FS170?
When a TV hasn't digital tuner, it's necessary to add it a digital to analog channels converter box, but your TV already has digital tuner, you can switch between digital and analog tuning by pressing the digital/analog botton on the remote control.
Feb 24, 2011 | Sony FD Trinitron WEGA KD-27FS170 TV
Is this TV a digital tuner? or will I need a converter box
Hi, If you have an outside antenna you will need a converter box as this tv has an NTSC tuner which is analog.
Feb 02, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Hi, Sorry this tv has an NTSC tuner which is analog. But it will work if you have cable or satellite.
Feb 02, 2009 | Sanyo DS24424 24" TV
No colour when digital set top box attached
Ensure the set top box is set to the correct video out. Probably RGB if scart lead or CVBS if coax lead.
Jun 10, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KD-36FS130 Digital Set-Up?
I did not know that the Sony FS series has digital capability. This is supposed to be the most basic model of CRT flat screen TV that Sony made.
You can get a digital cable or satellite box that outputs analog baseband or component analog video and analog audio. You can then connect this box in to the TV set. The TV will then display the analog signal from the digital box.
If your cable or sat box is able to tune in standard channels, but cannot tune in the ones that are on digital service, then the fault is with the box, or the cable or sat system. This you should address to the TV service provider.
Jerry G.
Apr 19, 2008 | Sony FD Trinitron WEGA KD-36FS130 36" TV
jl
Nov 26, 2007 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Sony KV-27FV16 TV Logo
56 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
