Question about GPX HI2817 Shelf System
HI2817 cd player won't work
Car CD player won't work!!
If you CLEAN your CD READER with a Special CD that you can get from Walmart of any of those places, you have a 75% chance of getting your CD Player to work,... your CD HEAD is not able to read Reference 0 on your Disc
If you have a failure inside your Player (which happens 25% of the time), then you have to replace it to play CD's
Not what you wanted to hear but this is the truth of the situation
Apr 10, 2013 | Car Audio & Video
Vizio DVD/bluray player won't work
not clear in the video the detailed problem. ok if dvd player won't read cd tried to insert other cd's which not the same region. if still won't read you can use a disc cleaner to clean the laser lens which too dirty or sticky .
Oct 06, 2012 | Televison & Video
1999 toyota 4runner radio works but cd player won't read cd
I am having the same issue! How did you resolve your problem?! ANY advise would be greatly appreciated!
Jun 02, 2012 | 1999 Toyota 4Runner
Have a 1996 Toyota Camery. Installed a KDG140 JVC stereo/CD player but the stereo won't work. CD player works great.
If "stereo won't work" refers to you not being able to get radio stations; try your antenna connection behind the radio. The vehicle may also have a power antenna connection(blue wire at the stereo).
Jul 28, 2011 | Car Audio & Video
Whenever we get our truck serviced, the cd player to our sony xr-c8220 won't work. It say's "goodbye" and to push reset. We tried that and it still won't work.
The CD player is malfuntioning. Either the wiring is incorrect (A short, etc.) or just a heat problem. Good Luck to ya!
Jun 27, 2011 | Sony XR-C8220 CD Changer
Cd player won't work
in what way does it not work?
unit completely dead?
or is there an error message?
what is happening that shouldnt?
darren
May 28, 2011 | Bose 32023 CD Player
My Craig ESP 60S Portable CD Player won't work. It starts spinning then stops. I have tried mode and program, but nothing helps. This is my second Craig CD player to do this.
sounds like it has a faulty laser and it wont read so the player stops the cd spin motor. try cleaning it and see if it works
Good Luck!
May 11, 2011 | Craig Personal CD Player
2003 silverado CD player
HI. you will need to replace the loading dock motor. once this replacement is done, you will have no problem loading and unloading your media. This repair will need to be initiated by Bose unfortunately. you will need to send it to Bose.
Jun 05, 2009 | Bose 32023 CD Player
GPX HI2817 Shelf System Logo
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
