Question about JVC TH-A10 System
JVC L-A10 won't turn on
As I said the turntable won't turn on, now the belt is broken as well, would that cause the unit not to turn on? I can replace the belt but I was wondering if this means a hardware malfunction.
Thanks
  • 104 Answers
The two issues are unrelated. a few turntables won't show life until the tonearm is moved over to the record area. at this point the motor should start turning wether it has a belt or not.
Posted on Feb 12, 2009
How to remove Platter on JVC L-A120 Turntable
Hi Jeff...
The platter on the JVC LA-10 does not come off as most turntable platters do. It is attached to the spindle with a Philips head screw.
Here are the steps:
Remove dust cover from turntable. Unscrew hinges and lift.
00.jpg" alt="Remove dustcover at hinges.">Remove dustcover at hinges.
  • Secure tonearm to prevent stylus damage.
    00.jpg" alt="Secure the tonearm.">Secure the tonearm.
  • Remove slipmat from platter.
    00.jpg" alt="Remove slipmat.">Remove slipmat.
  • Turn the turntable on its side and remove screws that hold the top to its base. Remove platter by unscrewing the bottom plate from the turntable. The spindle bearing is held in place with a Philips head screw. Loosen it and the platter will separate easily from the spindle.
    00.jpg" alt="Separate the spindle from the platter by loosening with a Philips head screwdriver.">Separate the spindle from the platter by loosening with a Philips head screwdriver.
  • Loop replacement band around the pulley cylinder in the motor. Replace platter and bottom plate. Tighten spindle screw. Test the new belt by turning the platter clockwise two or three rotations. Belt should fit snugly and turn with little resistance.
    00.jpg" alt="Test the replacement belt by turning the platter clockwise.">Test the replacement belt by turning the platter clockwise.
  • Feb 05, 2016 | JVC Audio Players & Recorders
    Turntable not rotating. What should I do?
    HI, lift the platter off and check belt. If it is broken or stretched you will need to replace it. To test belt for over stretch simply place it on the platter pulley then flip platter over the right way up. If belt stays put it is ok, if it falls off it needs replacing. Keep em spinnin, John Stylus City.
    Jun 20, 2014 | JVC AL A158BK Turntable
    AL-A1 turntable won t turn
    take the platter & belt back off, then check to see if the motor spins, if it does the belts the wrong size or put on wrong, if it doesn't spin then you better get your butter & jam out, to put on your toast.
    Jan 19, 2014 | JVC Audio Players & Recorders
    Locked won t turn
    The belt has stretched from age.
    Jan 03, 2014 | Technics Audio Players & Recorders
    How do I change a drive belt on my JVC L-A11 Turntable
    Lift felt on platter and and lift the platter section off the unit by putting your thumb and forefinger through the two large holes and pull upwards.There should not be any special routing for the belt and should go directly onto the spindle motor to your platter. Place the belt around the inside rim of the platter while it is still off the unit. Now replace the platter and move the platter around until you see the spindle motor through one of the holes. Use some tweezers to manouvre the belt onto the spindle motor. On some units you will have to lay the belt out inside the unit, replace the platter and manouvre the belt onto the platter. Hope this helps
    Dec 15, 2009 | JVC AL A158BK Turntable
    How to replace the belt on jvc l-f130 turntable
    You will have to lift the platter section off the unit itself. Check for the spindle motor turing the table and lay the belt out around the spindle motor. Refit the platter and work the belt around the inside of the platter through the two large holes in the tray.
    Nov 22, 2009 | JVC AL A158BK Turntable
    Table does no rotate
    If it is belt-driven the belt may be broken or fallen off.  Lift the turntable to check underneath.  There may be a spring clip near the center of the turntable that you have to remove to lift it.
    May 18, 2009 | Audio Players & Recorders
    Jvc turntable
    hi, please check first your fuse inside your turntable, replace it if possible
    Apr 04, 2009 | JVC AL A158BK Turntable
    JVC L-A10 Turntable won't turn on
    there should be a fuse on the circuit board close to where the power cord connects, check to see if its good
    Feb 03, 2009 | Audio Players & Recorders
    JVC turntable LA10
    The trick is to lift up on the platter (tothat metal on metal feel that you had) while simtaneously "lightly" tapping on the top of the shaft with a hammer. Trust me it will work as just changed my belt.
    Hope that helps.
    Mar 16, 2008 | Audio Players & Recorders
    JVC TH-A10 System Logo
    234 people viewed this question
    Top JVC Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Henry  Thomas
    Henry Thomas
    Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
