Question about Dewalt Drills
Dewalt 988 wierd trigger action
First lost variable speed then intermitent power now dead
  • 360 Answers
You will need a new trigger switch, parts are available at this link
thanks for using Fix Ya
Please take the time to rate this solution.
Posted on Feb 03, 2009
My dewalt 18 volt Dc988 XRP will not engage when you squeeze the trigger all the time. It goes in streaks or is intermittent. Also the variable speed is not working. it only goes one speed.
Your switch is having a problem it can be caused by excessive load on the motor.
The motor must be sounds not shrill and must have power , the most people think on the batteries but in more case by switch problems its the motor there is a field effect transistor inside the switch behind the cooling brass plate thats shorted and that is for the variable rpm .
Replace switch and if the motor sounds good then the problem should solved. if also the motor is bad go for a new replacement body ask your dealer.
May 09, 2017 | Dewalt Drills
I have a Bosch 1/2"
Sounds as though you are on the right track. I would take it apart, and see if the trigger could have some dirt or other material causing it to stick, or is it worn to the point that it needs to be replaced. Good luck!
May 30, 2017 | Bosch Tools 8.0 Amp Corded Hammer Drill,...
18 v Driver. Need trigger switch
Google ryobi stores. I'm in az and they have them here. Or ryobi repair and your location. I went to the dewalt replacement shop got a trigger for my angle grinder for under 2 dollars.
Jun 15, 2010 | Ryobi 18v Variable Speed Impact Driver...
Dewalt cordless drill dc988- drill motor works intermitantly when trigger is pulled. Works a little better as it warms up. Im thinking vsr switch, brushes, or motor/armature. please help...
Test the brushes by catching it in a stalled condition when you have it triggered, then rotate it slightly. If it takes off suspect the brushes or a dead segment on the comutator.
If it doesn't respond to this, then consider the VSR trigger... open it and test by bypassing it when in stalled condition...
Mar 20, 2010 | Dewalt 18 Volt Dc988 Hammer Drill,dc825...
DeWalt DW972 cordless drill has intermittent variable speed trigger. (Battery is fine, recently replaced) How can I clean the variable resistor in the trigger or must replace the whole trigger module?
have to replace whole trigger assembly.
worn brushes in the motor can also cause intermittent function, if you havent already checked those. i'd replace those first if they have never been replaced or look worn, broken, cracked, or if springs seem worn.
Dec 14, 2009 | Dewalt DC727KA 3/8" 12v Cordless...
Drilling slowly
If the battery is OK then the problem will be in the variable speed trigger switch.
Sep 24, 2009 | Dewalt DW999K 7/8" Cordless SDS Rotary...
Dewalt dc 988 cordless drill the same problem with those Chinese batteries and find that this problem is quite wide spread with many brands using these batteries. I'm speaking from experience with our battery factories. No quality control!
May 04, 2008 | Dewalt 18 Volt Compact Drill Kit
Drills Logo
614 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
