No puedo desarmarlo quito 4 uñas pero queda atorado por la mitad de ambos costados
There are only 4 screws at the back. one of it is covered by the serial bar code sticker.
after you removed the screws, you have to use a pen knife to slice along the aluminum surface.
after you slice the aluminum surface, then just pry a bit, you will actually find 4 plastic snap on clip, 2 on each side. You will need to use a flat screw driver to dislodged them.
Then follow to pry gently at around towards the top and bottom. Pls be advise try to pry using a unwanted credit card or atm card in order to pervent damage of out look. The whole device is actually using mainly one way plastic clips. you may break them if you are not careful during the process of opening.
