How I run a diagnostics
SOURCE: Whirlpool Duet Front Loading Washer Won't Turn On
mains filter blown door lock fail main pcd fail appliance doctor
SOURCE: Whirlpool Duet Front Load Washer
WHAT IS WRONG WITH YOUR WASHING MACHINE?
For a detailed Washing Machine illustration, click below.
Top Load Maytag Style
Top Load Whirlpool Style
Top Load GE Style
Front Load Maytag Style
Front Load Frigidaire/GE/Kenmore Style
Warning!
To avoid personal injury or even death, always disconnect your
appliance from its power source--that is, unplug it or break the
connection at the circuit breaker or fuse box--before you do any
troubleshooting or repair work on your appliance. Also, because some
components may have sharp edges, use caution while working on your
appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
DON'T FORGET TO RATE:
SOURCE: Whirlpool 9400 Front Loader Washer Control Button Locked
There it was, the directions printed right there on the front of the washer. So simple, who would have looked?? Thanks for you help. mine is the GHW9300P
SOURCE: whirlpool duet washer: cycle light blinks, won't run
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!$@%#^
SOURCE: Whirlpool Duet Washer will not start
The washer must be empty and the control must be in the OFF
state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
? Close the door.
? Push CONTROL/ON (if present on this model).
? Select the DRAIN/SPIN cycle.
? Select NO SPIN by pressing the SPIN SPEED touch-pad.
? Push PREWASH OPTION four times within five seconds. (If
PREWASH OPTION is not present on this model, press EXTRA
RINSE four times within five seconds.) C:00 will light up on the
display.
If the Starting procedure fails, push the PAUSE/CANCEL touch-pad,
then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push
PREWASH OPTION touch-pad two times. If PREWASH OPTION is not
present on this model, press EXTRA RINSE two times.
Read more: Whirlpool
Duet Washer 'Control Locked' - The Laundry Appliance Repair Forum -
Do-It-Yourself Appliance Repair Help - ApplianceGuru.com: The Samurai
Appliance Repair Forums http://applianceguru.com/forum2/1540.html#ixzz1AbBWB73c
Get appliance parts at http://parts.fixitnow.com
