Question about GE 25881EE3 Phone
Menu button not working
Model # is 7c28861FE2-A not the one above
Menu button won't allow me to do anything.
Apparently the speaker button had been pushed and that seem to have caused the problem.Fixed now.
Posted on Feb 03, 2009
RCA LCD TV locked up.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  1. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Aug 12, 2012 | RCA RCR312W Remote Control
Tip
Broken Screen Delete Messages Nokia 3109 3109c 2323 2323c
This works for the Nokia 3109/c and also the 2323/c which have a Nokia menu like in the picture. If you have the same menu then it should work. The handsets have a central navigation button which allows you to move up, down, left and right through the menus.
Delete Inbox Messages Blind Nokia Broken Screen
Press Central Navigation Button to get Menu
Press left once
Press up once - Message Menu
Press Central Nav Button
Press up twice - Delete Messages
Press down once - By Folder
Press Central Nav Button - Inbox
Press Central Nav Button - Confirm Delete
Press Button above call end several times to exit from the menu
Note on the 2323 (not sure about the other models) you have an option to keep unread messages. If you still want everything deleted then swap confirm delete step above for
Press Left hand button set above green call button - confirm delete all messages
Delete Sent Messages Blind Nokia Broken Screen
Press left once
press down three times - Sent Items
Press Central Nav Button - Confirm delete
on Aug 06, 2010 | Cell Phones
Tip
Saving contacts to SIM with Broken Screen Nokia 3109 3109c 2323 2323/c and...
Save Contacts to SIM blind. Nokia Broken Screen
Press Up once - Contact Menu
Press Up once - Copy Contacts Menu
Press Central Nav Button - From phone to SIM card
Press Central Nav Button - Confirm copy
Leave for a few minutes depending on how many contacts you have to copy
I accidently locked my TV. I have no idea what the code is. When I switch on the TV there is a blue screen with lock written on it. The remote control is CHUNGHOP RM-441e Universal PLZ do help. The Whole...
Hello
You can unlock the FPA lock of your RCA TV. But, you must ahve its original remote control to perform the proceedings. if you haven't it original remote cntrol with you now, just try to buy a new one, of just borrow it from any of your friends or relatives who owns the same model Tv.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
One amoung the above process will surely unlock your RCA TV. OK.
Sep 20, 2011 | RCA TruFlat 27F520T 27" TV
ON CHANNEL LOOK CANT GET OFF OF IT
Hello
You must have its original remote control to unlock your RCA Tv. If you haven't one, just borrow it from any of your friends or relatives, who own the same model TV; just to unlock it. After unlock you can use universal remote.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Any one amoung the above process will unlock your GE TV. After unlock, you have to do the Vchip-Set.
OK
Jun 19, 2011 | RCA TruFlat 27F520T 27" TV
Power button stays depressed and does not start power menu. power is on, drum light is lit.
You will need to replace the control panel. The button is pressed in the down position and won't allow you to do anything else till this part is replaced.
Jun 12, 2011 | LG DLE2514 Electric Dryer
Somehow the parental lock was put on so I can only watch pg rated movies. How do I unlock it???
Hello
OK
May 10, 2011 | RCA 20F610TD TruFlat TV/DVD
My TV 13GP341 access code calls me, what should I do?
Hello
OK
Apr 26, 2011 | GE 13GP341 13" TV
Master reset on motorola rzr 2
HI again,
1st let me tell u. U have to give a frequent try to it.
Its a tricky.
1) The two buttons work as menu buttons. One is in the center of directional keys and second is above the directional keys. U hv to press the second menu button above the directional keys.
2) While holding menu button, a message appears "shortcut not allowed for this item". The change of 4-digits slot to 6-digits slot may be after u do it also. At this time, type 000000 (six zero). Anyway, try it holding menu for 3-4 seconds or by holding it for a little long time.
Looking for ur kind feedback. Dont forget to Rate my solution too.
Be sure to post a clarification request after ur problem is solved.
SAJAN(sajwhat@hotmail.com/sajwhat_2003@yahoo.com)
May 08, 2008 | Motorola Mobility RAZR V3
GE 25881EE3 Phone Logo
42 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
