Question about Whirlpool GEW9250 Electric Dryer
TESTING A DOOR SWITCH
HOW DO YOU BENCH TEST A DOOR SWITCH WITH 3 WIRES?
  • 29 Answers
Knowing which wire goes to what is required. Then you may ohm it out changing the switches position. when the door closes then one set of contacts are opened and the other set is closed. Best described as one hot to a parallel switch. One allows the the light to come on and the other is a permissible circuit loop that will allow the unit to function when the door is closed. :?) DRRXR
Posted on Feb 04, 2009
  • 640 Answers
Its a switch ,,1 is hot and the other 2 are poles...unit just check for contnunity..,,onthejob
Posted on Feb 03, 2009
Unit is nearly new but does not run cord is fine but dont know where test point are to test switch with an ohm meter
No specific test points are provided. The unit will need dismantling to expose the internal wiring for testing purposes.
Dec 02, 2015 | Grinders
Troubleshoot a Kenmore dryer motor pt. # 20065212
DO U HAVE THE SCHEMATIC? U HAVE TO FIND THE WIRES FROM THE DOOR SWITCH USUALLY YELLOW OR PINK? AND THE WIRE FROM THE START PUSH BUTTON, THEN FOLLOW THEM TO UR MOTOR AND CONNECT UR POWER TEST LEADS TO THEM , U CAN START IT WITH THE BELT AND DRUM CONNECTED JUST TO SEE IF IT RUNS/
Feb 28, 2015 | Kenmore Dryers
Power door locks wont work on chevy colorado 2005
I really doubt one loose door latch will keep all the door locks from working . There are a lot of thing's involved in the power door locks ,relay's , wiring , master control switch etc..... Viewing wiring diagrams , testing electrical circuit's , PWR LOCKS 20A fuse etc....Are the power door locks and the driver power window inoperative?
Did you review the Power Door Locks Description and Operation?
YES - Go to Step 2
NO - Go to Symptoms - Doors
Verify that the power door locks are inoperative.
Do the power door locks operate normally?
YES - Go to Testing for Intermittent Conditions and Poor Connections in Wiring System
NO - Go to Step 3
YES - Go to Step 7
NO - Go to Step 4
Are the power door locks inoperative from a single door lock switch?
YES - Go to Step 5
NO - Go to Step 6
5
Is the driver door lock switch the inoperative switch?
YES - Go to Step 8
NO - Go to Step 9
6
Is the driver door lock actuator the inoperative actuator?
Test the battery positive voltage circuit of the drivers switch assembly for a short to ground or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 21
Go to Step 8
8
Test the ground circuit of the drivers switch assembly for an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 21
Go to Step 13
9
Test the passenger door lock switch control circuits for an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 21
Go to Step 12
10
Test the driver door lock actuator unlock control circuit for an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 21
Go to Step 14
11
Test the door lock actuator control circuits for an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 21
Go to Step 15
12
Test the passenger door lock switch ground circuit for an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 21
Go to Step 16
13
Inspect for poor connections at the harness connector of the drivers switch assembly. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 21
Go to Step 17
14
Inspect for poor connections at the harness connector of the driver door lock actuator. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 21
Go to Step 18
15
Inspect for poor connections at the harness connector of the appropriate passenger door lock actuator. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 21
Go to Step 19
16
Inspect for poor connections at the harness connector of the passenger door lock switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 21
Go to Step 20
17
Replace the driver switch assembly. Refer to Door Lock and Side Window and Outside Rearview Mirror Remote Control Switch Replacement .
Did you complete the repair?
Go to Step 21
18
Replace the driver door lock actuator. Refer to Front Side Door Lock Replacement .
Go to Step 21
19
Replace the appropriate passenger door lock actuator. Refer to Front Side Door Lock Replacement or Rear Door Lock Replacement .
Go to Step 21
20
Replace the passenger door lock switch. Refer to Door Lock and Side Window and Outside Rearview Mirror Remote Control Switch Replacement .
Go to Step 21
21
Operate the system in order to verify the repair.
System OK
Go to Step 2
Jul 17, 2012 | Chevrolet Colorado Cars & Trucks
2002 Taurus bench tested fuel pump and motor works then connected to wire harnes it doesn't work, why?
Did you check the fuses or relays..If so check the inertia fuel shut off switch..The owners manual will show you where its located
Apr 30, 2012 | 2002 Ford Taurus
I own a 2003 f-150 heritage edition The windows worked just fine this morning I go to role them up tonight they will not work. I checked every fuse none bad. They light up and locks and power mirror...
Check the power to the power window switch on the driver's side.
Std & SuperCab Engine compartment fuse panel, Fuse # 110 -> Accessory delay relay -> Light Blue w/ Black stripe wire.
If you do not have power at the light blue w/ black stripe wire with the key in the accy or run positions, next would be to pull the accessory delay relay from the cab fuse panel, and bench test it to make sure when power & ground are connected to the coil, that the normally open terminals close. Easy test, power & ground to terminal 85 & 86, ohm meter on terminals 30 & 87.
If the accessory delay relay bench tests good, check for continuity on terminal 87 to the light blue w/ black stripe wire at the window switch.
Another easy route is to install a jumper in the relay socket ( with the relay removed ) as shown in the diagram above, red line. This should have power at the power windows regardless of the key position. If not, the fuse is not good or the wire is broken, most likely in the rubber boot from the a pillar to the driver's door.
Aug 22, 2011 | 2003 Ford F150 Regular Cab
Have a kenmore stove, and a code of F93 is coming up. What is the solution?
F90
F91
F92
F93
F94
F95
If lock motor runs:
1. Test continuity of wiring between EOC and lock switch on lock motor assy. Repair if needed.
2. Advance motor until cam depresses the plunger on lock motor switch. Test continuity of switch contacts. If
switch is open replace lock motor assy.
3. If motor runs and switch contacts and wiring harness test good, replace the EOC.
If lock motor does not run:
1. Test continuity of lock motor windings. Replace lock motor assembly if windings are open.
2. Test lock motor operation by using a test cord to apply voltage. If motor does not operate replace lock motor
assy.
3. If motor runs with test cord check continuity of wire harness to lock motor terminals. If harness is good replace
the EOC.
Door lock motor or latch
circuit failure
AS YOU SEE THE F93 CODE REFERES TO THE DOOR LATCH MOTOR
Jul 19, 2011 | Kenmore Ovens
Interior light / electric locks chattering with no key in switch
Yes, you are missing something. The days of removing the battery cable ended with Generators. An Alternator will self destruct if you do that. Be certain to remove it and get it bench tested. Usually kills diodes and often regulator.
the doors clicking sounds like a problem in the door lock circuit, often in the door jamb. If you inspect and find broken wires in the door jamb, do not repair there, you need to replace the entire length. All repairs fail quickly. The wired need to be new and flexible.
On the no start with new battery, be sure to test the neutral safety switch.
Mar 11, 2010 | 1997 Buick Skylark
Wont start--pulled starter bench tested ok
check your ignition did one of these before changed 3 starters before finding out it was ignition switch not making connection in switch good luck
Feb 07, 2010 | 1997 GMC Jimmy
Have an old sears craftsman 1/4 hp grinder model 397.19501 wires have been disconnected. I want to rewire and test. Does anyone know how to connect the wires? There are 2 copper tabs under the on/off...
the two copper tabs under the on off switch are to break the power source.connect incoming power to one of these(black) then a short piece of wire from the other tab under switch to one of the three tabs under plate that is marked hot or l1 is probably #2 but you need to be sure. the white is the nuetral or l2 which is most likely #3 and the green is the ground most likely #4 I would definately look online for a wiring diagram to be sure if they are not marked with L1 L2 and GND
Oct 10, 2009 | Black & Decker 3/4 Hp, 8" 205MM, Heavy...
Whirlpool GEW9250 Electric Dryer Logo
102 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
