Question about Maytag Neptune MDG9700A Gas Dryer
Thud sound, once per rotation
I have a Neptune MDG9700AWW. 2005. I makes a once-per revolution thud. Very annoying. I took the top off to find that the weld seam of the drum is flaking apart at one end, at the location of the thud sound. That is, when a roller hits the open seam, the drum sinks and rises, making a 2-toned dah-dum sort of thud. One can watch the sound and weld seam location synchronize.
My question: Is this covered by a Maytag warranty? The seam gap is nor rusted, by simply gone, with wavy metallic edging and no hope of re-overlap and solder/weld. One can see light from inside the dryer.
  • 1 more comment
  • ron1342 Feb 04, 2009
    onthejob5130,
    You're the man. I never thought of the stainless steel drum angle.
    I'm working it. Many thanks
    In the meantime, I may try the short term vent sheet metal and duct taper so I can avoid the thud.
  • Anonymous Mar 26, 2009
    I HAVE A MAYTAG NEPTUNE DRYER AND THE SAME THING HAS HAPPENED. I STARTED HEARING A THUD WHEN THE DRYER WAS RUNNING AND I TOOK THE TOP OFF TO FIND THAT THE METAL SEAM INSIDE THE DRYER DRUM IS CRACKED, THIS IS NOT YOUR NORMAL WEAR AND TEAR, THIS IS A BIG MANUFACTURING PROBLEM. I CALLED TO FIND OUT IF THIS COULD BE REPLACED FOR FREE-AND YOU GUESSED IT -THIS IS NOT A PART THAT IS UNDER WARRANTY.
  • Anonymous Apr 04, 2009
    I have the same thud problem and recently I noticed the dryer is taking longer to dry clothes, I just noticed tonight that there is a crack in the drum, rather large. Will this be covered under warranty?
  • 640 Answers
That do fall under defective workmanship...but you have to look in your owner manual,,under your warranty page...i know if its stainless your covered..onthejob
Posted on Feb 04, 2009
  • onthethejob1
    onthethejob1 Feb 04, 2009
    ok sounds good,,but if you get it dont for get to change your rollers while your in there,,a couple of bucks,,good investment,,in case drue damage them....keep me posted onthejob
Clicking in the engine
here are few components that can cause such problem.Its advisable to click the link below and follow the troubleshooting to correct the problem.
Engine makes noise? http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Chirping sound coming from engine? http://technoanswers.blogspot.in/2012/01/chirping-sound-coming-from-engine.html
--------- Vehicle making Clunk Thump Thud noise? http://howtobyme.blogspot.in/2012/03/vehicle-making-clunk-thump-thud-noise.html
Car Engine Overhaul Tips? http://vwrepairhelp.blogspot.com/2011/11/car-engine-overhaul-tips.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
Rattle noise from engine? http://whatisbyme.blogspot.in/2012/05/2005-toyota-corolla-rattle-noise-from.html
These will help.
Thanks.
Jul 21, 2012 | 1999 Ford Explorer
2006 Chevy Trailblazer makes THUD when accelerating
Check your coolant level, low coolant or air in your cooling system will make a "thud"noise in your heater core when the engine is under load from acceleration. The coolant rushes in to the heater core where the air pocket is trapped and then your hear the noise.
Start with the simple and make sure your coolant level is correct and then try to purge the system to remove the air out for your coolant system.
Thank you for using fixya and good luck
Jun 15, 2010 | 2006 Chevrolet Trailblazer
There is a thud thud thud nin the front end of the
Cant rule that out. If car has ever been in an accident you want want to check the engine mounts also. This sometimes sounds just like a transmission going out of a vehicle.
Nov 09, 2009 | 2002 Kia Sedona
''thud'' sound when starting
Is the "thud" sound after start then put in gear or a "thud" just after starting. If "thud" after in gear, could be a CV joint wearing out
Oct 15, 2009 | 1997 Toyota Previa
Hyundai Tucson 2.0L Year 2006
Sounds like bad CV (constant velocity) joints in the front half shafts.
They make the most noise at a full wheel cut.
Aug 06, 2008 | 2006 Hyundai Tucson
Maytag Neptune MDG9700A Gas Dryer Logo
378 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
