Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune dryer overheating
Dryer got real hot and shut the motor down. I replaced the thermal fuse on the heater element. That worked for about 40 minutes and it overheated again and shut down. Would the high-limit thermostat be the cause?
  • 750 Answers
Hello
Welcome to Fixya
My name is Huum,
Yes, I agree it is the high limit thermostat, or the motor is bad!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Posted on Feb 03, 2009
Neptune dryer 5500 no power
This dryer has 2 thermal fuses. One next to the control stat on the blower housing and another on the heater element. You could quite possibly have a bad blower wheel or simply a lint build up cauing over heating. To get inside this dryer you remove the door first. The you can remove the front. Once that is removed you can pop the top and get the front shroud off. You cannot work from behind.
Sep 17, 2012 | Maytag Neptune MDE5500AY Electric Dryer
My maytag neptune dryer doesn't blow any hot air
on top of the heating element on the left side there is a white 2connector part, that is the heater thermal fuse. disconnect the dryer power cord and one wire of the thermal fuse and use a meter to find out if you have continuity to it. if not replace it. also check for burn wires at heating element. also test heating element by disconnecting one wire and using an ohm meter test it at 2 therminals. it shoul measure 10-12 ohms.
Feb 14, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Dryer shuts off after about 10 minutes. Motor feels hot, real hot. I think it is overheating and shutting off. The lower the setting the longer it will run. Is it the Thermal fuse or thermostat?
There might be a problem with the bushing of the dryer motor that causes the rotor to become shorted with the magnetic field and that's the reason why it becomes too hot. It is also the reason why the thermostat shuts off the motor when it becomes too hot to avoid overheating. Replace the bushing of your motor.
Nov 10, 2010 | Kenmore 63942 Dryer
Only buzzes when trying to start my LDE7304ACE Maytag electric dryer. the drum spins freely.
Verify and indicate in which part where the buzz is coming from. It's the timer motor if it's coming from behind the timer knob; otherwise, it is the dryer motor at the base of the dryer.
The drum belt has slipped off if the dryer motor is the one that buzzes and the dryer blows out hot air. Otherwise, the dryer motor (part number Y303358) is stuck; replace it.
Check the continuity of thermal fuses, one on the blower housing and one on the heater enclosure, if the buzzing sound is coming from the timer motor. These thermal fuses are wired in series with the dryer motor and will make it inoperable should any of the thermal fuses fail. Replace also the cycling thermostat should the thermal fuse (part number 306604) on the blower housing has failed and the high-limit thermostat should the thermal fuse (part number 307473) on the heater enclosure has failed.
May 24, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer overheating
have u replace heating sensor
Oct 22, 2009 | Maytag PYE2200 Dryer
Maytag electric dryer keeps shutting off.Dryer gets hot. Repairman replaced the motor but still having the same problem.Could it be a sensor?
Generally if the motor shuts off it is because of the overprotector on the motor opening up to save the motor.When the motor cools down the overload will close and the motor will work again.
If the unit is getting so warm the motor is shutting off check to make sure the rollers are working properly and moving freely.
Sep 15, 2009 | Dryers
Kenmore Heater continues to run when motor has stopped
It sounds like you have a grounded heating element. If the dryer can be turned off but the heating element continues to get hot, that indicates a grounded heating element. Be Very Careful. There could be power running thru the dryer case. I would unplug the machine and check out the heating element. Hope this helped and best wishes.
Aug 22, 2009 | Kenmore 63942 Dryer
Maytag Performa PYE2200AYW Dryer Heats intermittently
i had the same problem with my dryer and i installed the wrong thermal fuse for gas dryer which calls for a pink thermal fuse in which i installed and it works fine also check the lint in the front of your dryer. also my dryer which is the same make as yours seems will run on the fluff cycle until i replaced the right thermal fuse. my dryer run exceptionally hot and eventally shut down and it only run on the fluff cycle for any length of time.
Aug 03, 2009 | Maytag Dryers
Maytag dryer not starting
You must replace the hi limit thermostat and the thermal fuse.
They come as a set and must both be replaced.
They are located on the heating element.
Feb 21, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
457 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
