Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
WATER LINE 90 DEGREE ELBOW LEAKING FRONT LEFT
WHIRLPOOL GOLD 2008 MODEL # GS6NBEXRB02. WHITE ELBOW WITH BLUE WASHERS, LINE HAD TO BE REMOVED TO GET IN THE HOUSE, PULLED THE LINE OUT OF ELBOW ( DIDNT KNOW BETTER AT THE TIME) ALL I NEED IS A NEW ELBOW. CANT FIND ONE ANYWHERE. PLEASE HELP!
  • 410 Answers
Did you actually break the elbow? you may be able to cut the tubing back and get a new surface for the elbow to push back into. if not a 5/16" push in connector is what you need you may be able to find this at a water condition store such as culligan.
Posted on Feb 03, 2009
Where is the water filter in my Refrigerator?
Look for a round part in the grille that covers the refrigerator under the doors If it's there that is the filter. Give it a 90 degree twist (after you shut off the water supply) and pull out. It may be hard to pull since there are 2 o ring gaskets that haven't moved in a while.
Jul 16, 2014 | Whirlpool Gold White-on-White 21.9 cu. ft....
Leaking rear white valve at lower back of whirlpool fridge.
Hello is the valve leaking where the water line comes to the top of the valve?
Sep 27, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
1999 Pontiac Sunfire Leaking water in Passenger Interior
The evaporator drain is plugged with debris and filling up the heater case. Remove the 90 degree elbow and clear the drain hole at the case.(pencil or piece of wire) You will know that's it when it dumps out a half gallon on the floor. Be sure to reinstall the elbow to keep out rain/ road spray.
Feb 23, 2010 | 1999 Pontiac Sunfire
Leaking black and decker under counter coffee pot
the 90 degree red elbow has worn away of hot water temps and will leak some but all hot water to the bottom of machine. needs to be replaced or retrofit one
Jan 03, 2010 | Black & Decker SpaceMaker ODC440B 12-Cup...
Un hook the water line from door on whirlpool fridge gold..has elbow from door to main unit.
Push in on the end ring , pulling the tubing out at the same time . If you have the blue connector with white end rings , Push in on the ring oan pull out the tubing at the same time .
Oct 02, 2009 | Whirlpool ES5FHAXS Side by Side...
My hydrant is leaking water from the top and sounds like it is.
the little rubber gasket under the plastic cap is broken remove the plastic cp pull out the little white plastic piece flip it over remove the o ring and put in a new oen then put it back togeather.
Mar 15, 2009 | Halex Liquid Tight 90 Degree Elbow, 3/4"
Hookup at water supply
I do believe so.  Check your installation guide for more info.  If you purchased a water line designed for dishwashers, it should have the 90º elbow included.
Apr 02, 2008 | LG LDF8812 Stainless Steel Built-in...
Whirlpool dishwasher leaks everywhere
CHECK YOUR HOSES FOR CRACKS. BE SURE THEY ARE ATTACHED SECURELY TO THE PUMP OULET.
THERE IS ALSO A BLACK HOSE FROM THE VALVE THAT GOES UP THE LEFT SIDE TO A VACUUM BREAK ON THE SIDE OF THE TUB. BE SURE THE HOSE HASN'T BEEN DAMAGED OR DISCONNECTED. IF THERE IS SUFFICIENT SUPPLY HOSE, PULL THE DISHWASHER OUT OF IT'S INSTALLATION AND TURN IT ON. WATCH FOR WATER DRIPPING ON THE FLOOR AND TRACE IT BACK TO FIND THE PROBLEM.
Mar 25, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Connecting the hot water line to a new dishwasher.
use teflon tape on the elbow if you did the back it off put some more on it and stop when its snugged facing the right direction now ive torqued them things pretty tight my self they don't strip that easy
Feb 16, 2008 | Dishwashers
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
296 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
