Question about Fisher Paykel EcoSmart GWL15
No power washer will not work
Fisher&Paykel GWL15
I loaded the washer, pushed the power button and there were sparks under the control panal, and the washer will not work. No power at all...
  • 3 Answers
Sounds like a control board failure, sparks are never a good thing. Better to get a serviceman look at it unless you are an electrician and can do an insulation test after working on it.
Posted on Feb 09, 2009
Replaced water pump and control panel, have power, but just beeps.
Fisher and Paykel GWL11 Top Loading Washer
ths.gardenweb.com > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... 4) (Rinse Phase) Drain the water, then lock the lid for spin. ..... I plug the power cord in and I have nothing on the control panel. ..... As the controller was only replaced early in January, I've flicked F&P NZ an email to see if it's still under ...
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesI removed the pump and control panel, found no blockage in the pump, so far ... Ihave just tried to fill my F/P machine but the water is just dripping in. ... I have aFisher Paykel washer have replaced the control module and now it .... washing machine MW612, stopped working and displayed beeping sound every second.
Jan 16, 2016 | Fisher and Paykel GWL11 Top Load Washer
Fisher paykel GWL11 will not power on (yes the circuit is on)
Check the water pump under the machine. These pumps fail, but are easy to replace. Ours was short circuited and actually sparked when the power button was pushed. Same no lights, no power. We had a GWL10 model, but I'm sure the GWL11 is similar.
Aug 13, 2014 | Fisher and Paykel GWL11 Top Load Washer
Power button on GWL15 has issues
You will need to get a new tac switch installed into the display board
and put some clear packing tape over the crack on the decal to stop water getting in again and wetting the new switch.
Dec 06, 2012 | Fisher Paykel EcoSmart GWL15
My fisher gwl15 washer won't power up, any help
This is usually a sign the controller module has expired.
Jun 05, 2011 | Fisher Paykel EcoSmart GWL15
Fisher Paykel washer dripping after wash is complete
replace your water inlet valve can order from Repairclinic.com
Mar 01, 2010 | Fisher and Paykel IWL12 Top Load Washer
Our gwl11 fisher paykel washer will start to fill for about 5 seconds then stops
This is either your lid switch not working or your out of balance switch the latter being located under the large motor controller board under the controll panel.That should fix it.Kind Regards Stefan.
Jul 08, 2009 | Fisher Paykel EcoSmart GWL15
Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Apr 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fischer Paykell 7.5kg Smart Drive top load washer
Have you checked the lid micro switch under the motor controller which activates when you close the lid to start the machine?
Jul 24, 2008 | Fisher Paykel EcoSmart GWL15
Getting inside the Fisher-Paykel GWL15 washer
thats it , remove those 2 screws and the top will flip back, the new "clothes guard"( neck ring), will snap right into place, be sure to rehook the spring to hte left front susension rod!
Mar 25, 2008 | Fisher Paykel EcoSmart GWL15
Fisher Paykel EcoSmart GWL15 Logo
146 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
