When my printer prints a paper it is make a dark shade behind everything, how can i fix this?
  • 797 Answers
Hi jevance2012:
If the printer is a laser, you need a new cartridge, more than likely.
If you would give the make and model, it sure would help.
Your printer setup page may need to be reset.
If your printer is an ink jet, then the problem is not in the cartridges.
Anyway, hope it helps.
Posted on Feb 03, 2009
Hp design jet 5500ps prints dark. whenever we have a dark color printing, it darkens everything around it, even when it is set to high quality. our posters are coming out extremely dark. could it be a...
It could be a paper issue. Make sure the paper you are printing on is the type paper you told the printer you installed in the paper type setting (Plain Paper, Bright White Injket Paper, etc.)
Aug 02, 2011 | HP DesignJet 5500PS InkJet Printer
DARK LINES/SHADES APPEARING ON BACK OF PRINTS
when the print-out shows lines or streaks on the back of the paper when printing single sidedly, this usually means that the fusing unit is dirty or broken. another possible broken part may be the photoconductor unit.
Apr 20, 2010 | Canon iR 2016i Black and White Copier
Dark Background on the paper
replace the drum unit (toner) your drum is weak causing dark background
Nov 21, 2009 | HP LaserJet 4 plus Printer
How to clear paper jam at the back of Kyocera Mita FS 1000+. Paper stuck up in the middle, with dark shade on top of page. Is this printer capable of 2-sided printing?
if paper is stuck in the back... then you have to take the machine apart... its messy but its just how it is... as for two sided printing... I would call kyocera support... they could best advize you on that... and they are quite friendly...
Mar 06, 2009 | Kyocera Mita FS 1000+N Laser Printer
Very Light Print
What you need to do is adjust shading. That recalabrates the scanner. To enter the machine into the tech mode you press " menu, # 1934" then you will be in the tech mode, a T should appear on the machine screen. You then go to machine setup and maintenance, then scroll to adjust shading or just shading, depending on how your specific firmware states it.
Then place 5 sheets of white paper on the glass, 5 pieces of paper think not spread out, then press start, if it askes you DO you want to asjust press start and let it run through the setup.
Once you have cleaned the scanner you really need to adjust teh shading. A better way to say it would be scanner calabration.
Oct 17, 2008 | Xerox WorkCentre PE120 All-In-One Laser...
PRINTING IS DARK
Dark copies (whole pages) are usually a result of poor charge of the drum. Drum is that green thing (usually, seen blue ones too). You get text and graphics in places, where the drum has been discharged (light discharges drum). So if everything is dark - the drum is discharged fully, or not charged at all. Look for bent, dirty or missing connector plates, springs, paper covering contacts. If you get lines it could also be the fuser (hot thing) - needs replacing. Everything depends on how the copy looks like, I would have to see it. Hope this is helpful somehow ;-)
Aug 28, 2008 | Brother HL 5140 Laser Printer
Dark lines on printer paper
Possible.... other possible solution is a dirty drum... try changing the toner cartridge and cleaning the drum
Mar 11, 2008 | Samsung CLP 300 Laser Printer
Prints have a dark shade
Test page printed properly. Don't know what to look for in the test page or the applications. the cartridge was changed recently
Feb 24, 2008 | Brother MFC 9700 All-In-One Laser Printer
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
