Question about Compaq HP 2Button Optical Carbon USB Mouse
Mouse Problem The left button of my mouse is giving problems. I need to press it really hard to make it work...is there a way i can fix this? Or do i hv 2 purchase a new mouse? I hv used it for 2 years only!
  • 39 Answers
What you are experiencing is normal wear and tear of the mouse button that is used the most. This is a common issue with mice made for computer manufacturers. Most likely issue is that after 2 years of clicking, the depress switch was actually pushed into the plastic molding below. A new mouse would really be the most effective use of time and resources. I would recommend a high quality mouse from logitech (a g5 or g7) would significantly increase hand comfort, response and posture. Their warranty period is also top notch. Hope this helps.
Posted on Aug 01, 2007
SOURCE:
ASUS 1000 left mouse button not working
Yes! get a can of compressed air and attach supplied straw, now with your fingernail lift up the left mouse button and give a few good blasts in the crevice, this will clear out any buildup of dirt and grime that has collected, repeat as required. If this fails it will involve laptop service.
Jul 04, 2012 | ASUS Eee PC 1000 Notebook
I have a technika wm110bl wireless mouse which I think needs resetting .Unfortuneately it looks like the original packing has been dumped ...... I could do with a little instruction on how to reset the...
1] unplug the dongle 2] press Windows Key and PAUSE'BREAK together This brings up a window ... click the device manager
3] Watch the screen 4] plug in the base station Under Mice and other pointing devices, HID_compliant mouse should now be displayed. 5] Underneath the dongle is a small button ... press it The blue light flashes about twice a second 6] Underneath the mouse there is a hidden small button- directly under left button -- press this 7] the dongle will flash really rapidly 8] soon the mouse/dongle start to "talk" to eachother, then settle down
Your mouse should work now
Regards
Steve H
Mar 28, 2011 | Computers & Internet
My HP Optical mouse Left Mouse Button has stopped working. The RMB still performs its function (so batteries on mouse still OK etc). I have tried shfitng the USB port etc but nothing seems to fix the...
Similar problem which I resolved today.
I have a hp wireless mouse model no. 5189URF. I bought this in hp online in April 2009. It needs 2 x AA Alkaline batteries.
Steps I did to resolve.
1. Removed battery cover.
2. Removed batteries below which 2 screws exist.
3. Remove 2 screws and remove the top casing of mouse.
4. You can see 2 very small square push button corresponding to left and right clicks in mouse.
5. try to press the left button and make sure its free. The issue seem to be that this button becomes rusty internally and lost contact. Therefore clicks are not recognized. You may need to press it repeatedly and also with a slight thrust circumferentially.
6. You can test your mouse in WIndows Help & support option linked with HP hardware diagnostics tool.
Oct 31, 2010 | HP Wireless Optical Mouse
Dropped wireless mouse and wheel shifted & buttons hard to push
I had a similar problem and was able to fix it. The left mousebutton was clickable, but needed extra force.
After opening the mouse I found that at the side of the mousewheel there was notch pointing upwards, preventing free movement of the left mousebutton. I was able to rotate the ring with the notch back into horizontal position after gently pushing the housing surrounding the mouse wheel wider.
Apr 25, 2010 | Logitech Cordless Mouse
The right button of the mouse is very hard to press.Any ideas how to fix this problem
Hi there, You feel hard because its broken from the inside. i guess if you press the right button from the end side( back side end of pressing location ) then some time it will work. Ok just turn back and open the small screw by screw driver. Then remove the casing. you should find 2 button look like small tap with black head or you can say its a radio button. press both button, if its working perfect and sound like a " tik tak" then you confirm that the button is ok. After that check the mouse casing press button. There you found a small plastic "dot" which is attached back side, with left & right side pressing button. If right side is missing then the "dot" button is broken, that's why you can't press the key. And some time its dislocate So if you do not find that "dot" plastic then i suggest you buy a new mouse or if its dislocate then try to fix it.
Thanks & waiting for your feedback.
Feb 15, 2010 | Logitech MX620 Mouse
Left wireless mouse button doesn't work hard to push
This is a mechanical problem for sure. If you have to press hard to get a click, pop the mouse open and carefully look at where the mouse button is supposed to touch the micro switch. It might have been damaged by a heavy finger, etc. Any hobby-minded person can cook up a solution to restore this plastic finger so it will aim and hit the micro switch correctly
Nov 23, 2009 | Dell XPS 400 PC Desktop
Left button on wireless 5000 laser mouse not working, please help it feels as if the entire mouse is loose and I have to press really hard to get the left click
it sounds like you might have spilt liquid on your mouse. if so there isn't anything i can think of to do other then buy a new mouse
Jun 09, 2009 | Microsoft Wireless Laser Mouse 5000
Dynex wireless mouse..DX-WLMSE..Left click does not work properly...unless you Press Really HARD...???? What's wrong???
It is the problem of the Hard ware( Mouse). The contact is not get activated on soft clicks. dismantle the mouse. clean the contact points and put the click button properly might solve the problem. if not it should be replaced.
Mar 25, 2009 | Dynex Wireless Optical Mouse
Unable to sync Belkin wireless travel mouse
Hate to say this without sounded silly.. but we had these problems, and could not sync mouse with PC. THEN.. I read directions slowly, again.. and figured out.. it is the BOTTOM of the mouse we were not doing. There is a button UNDER the mouse you push.. not the bottons on top. (BOTTOM LEFT side it says). We were clicking the top, bottom of the button. Anyway.. just make sure you turn mouse over. :)
Nov 20, 2008 | Belkin Mini Wireless Optical Mouse...
Connecting wireless keyboard for L3600
There is a button on the bluetooth dongle that needs pressing to get the mouse & keyboard operating, I think I got them to work when the little long blue light on the dongle (there is one) it flashes for a brief time when pressed. I think if the mouse or keyboard button is pressed while its flashing it picks them up. Good luck, it was very tedious, I agree.
Nov 09, 2007 | Acer Wireless WIL-152 91.84R07.152...
Compaq HP 2Button Optical Carbon USB Mouse Logo
94 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
