Computers & Internet Logo
Posted on Feb 02, 2009
I had more hard drive space added to my computer. I had PrintMaster Greeting Cards deluxe software that I bought a few years ago. We reinstalled it and now it just gives me messages with a big X in red circle that say WebReg and Pgcd. What does this mean and how can I get my card program to work again? [email protected]
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 03, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
39
Points
I can't register my copy of of Print Shop Deluxe 20
I can't install my old verson of print shop on my new laptop.
WLAN Config Service can't start.
time to back it up and replace the hard drive. the hard drive is good for about 2 years and if you got more then that out ofthe hear drive you did good
I had Printmaster 10 installed on my computer, but recently had to reload, I saved my invoice files to a disc, but they will not open up unless I reinstall Printmaster 10. I have Windows XP, and the disc...
I suspect that when you re-installed 10 it corrupted in some way and did not install properly. If you are using the same computer as before and the same software disc as before, then unless you had an update, which changed printmaster 10, it should be the same as before.
The only updates to Printmaster 10, would have been around a few years after it came out. There are no software updates for any software that still works only on XP as the system is now redundant.
Try re-installing Printmaster 10.
My wife has been using Printmaster for years and has created thousands of projects. Her latest version is 18. We got a new computer with Windows 7 and it said that version 18 is not compatible. So we...
Installing PrintMaster 18 on any computer requires .NET Framework 1.1 to be installed on the hard drive. If NET Framework 1.1 is not installed, it will be installed from thePrintMaster 18 install disk before PrintMaster 18 is installed. If possible download .NET framework 1.1 If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant" in Windows 7 will display this message.To continue with the installation, select "Run Program".
2answers
Is there a program out there like Greetings 99 for vista?
Art Explosion Greeting Card Factory Deluxe 7.0 - This version of Greeting Card Factory from Nova Development adds another 10,000 graphics (90,000+) and almost double the number of project templates from earlier versions (24,000+). Create all kinds of projects from greeting cards and calendars to stationery and certificates. Some of the kinds of cards include Thank You notes, Pop-Up Cards, Note Cards, and Photo CD Greeting Cards. Helpful tools: Photo Editor, Card Browser, and Drag and Drop Text Effects. It's also Windows Vista certified. This is a very good program and works with Vista. Hope this helps you.
Cannot uninstall
I will think you are using a PC and not Mac. Here is a program jv16 PowerTools that yo can get from the net. I've used it for a few years and it can do wonders for the price. One of the areas allows it to remove programs from that aren't even listed on the "uninstall programs" part of Win OS. It can also do awesome repairs and cleanup of the registry. I've tried a few, but this dog will fetch.
I hope this helps. If not. please let me know
Ed
Problem installing,deluxe version 7,greeting card
insert disk
click on MYCOMPUTER and then RIGHT-CLICK on the drive and then click or EXPLORE
This should open a folder for the disk. somewhere in there should be an EXE file with SETUP in the title.
if the folder doesn't display the contents you may have a bad disk
if it does and you cant find a setup program let me know.
is this the only disk you have had trouble with lately?
1helpful
I have Printmaster 10 and 17. On 10, I can print to the edges of the labels and others things, on 17 I can't. I know that I reconfigured 10 to do this, but it was years ago and I can't remember the step...
Custom Paper Wizard PrintMaster® 17 Gold and Platinum include a Custom Paper Wizard that allows you to add new or unsupported paper stock to PrintMaster® for printing labels, stickers, envelopes, half-fold greeting cards, note cards, business cards and postcards. The remainder of this note describes how to use the Custom Paper Wizard. Follow the procedure below to add a new or unsupported paper stock to PrintMaster® 17 Gold or Platinum using the Custom Paper Wizard.
NOTE: The options that appear in the Custom Paper Wizard vary depending on the project type for which you are creating new paper stock.
  1. In the PrintMaster® Design Workspace, click Tools from the menu bar, select Custom Paper Wizard and click New Custom Paper. The Custom Paper Wizard window will open.
  2. In the Select Stock Type: list box, select the appropriate project type (Label, Sticker, Business Card, Envelope, 1/2-Fold Greeting Card, Note Card or Postcard) and click Next.
  3. If creating a Label or Sticker paper stock, select the label type. An example of the selected label type will appear on the right.
  4. Click Next.
  5. In the screen that appears, select the similar stock type and enter the paper height, width and margins (if instructed to do so).
    NOTE: The Example box at the bottom of the Custom Paper Wizard window will explain what information is needed for the selected field (e.g., Paper Width, Left Margin, etc.) with both text and a diagram. The Example box on the left side of the Custom Paper Wizard window will show an example of the new paper stock as the fields are completed.
  6. Depending on the paper stock, the "Contains mid-page perforation" box may be active. If the paper stock that is added has a mid-page perforation, click once in the empty box to check it.
  7. Enter a Name for the new paper stock in the Name of stock: field and click Next. This name will identify the added stock type and will appear when creating a new project (e.g., Label, 1/2-Fold Greeting Card, etc.).
    NOTE: If adding a new paper stock for an Envelope project type, click Finish. A message will appear indicating that the new stock has been added. Click OK. The new envelope paper stock can be used when creating a new Envelope project.
  8. The next screen or screens that show will depend on the project type for which the new paper stock is added. Enter the needed information and click Finish. A message will appear stating that the new paper stock has been added.
  9. Click OK.
  10. To access the new paper stock, create a new project that uses the stock type (Label, 1/2-Fold Greeting Card, etc.) and select the name of the new stock entered in Step 7 (above) from the available stock list.
NOTE: If the paper stock that is added does not display in the list, click or go to Custom Paper Stock Does Not Display (Technical Note ID: 43399) for additional information.
Using the Custom Paper Wizard Tutorial
Consult the "Using the Custom Paper Wizard" tutorial in the Help Center of PrintMaster® 17 for additional information. The tutorial can be accessed in the manner shown below.
  1. Launch PrintMaster® 17.
  2. Click Help on the menu bar and select Help Center.
  3. Click the View or Print Tutorial icon (light bulb).
  4. Under Choose a Category, click Program Tutorials.
  5. Under Choose a Topic, click Using the Custom Paper Wizard
Top Riverdeep Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Riverdeep Computer and Internet Expert? Answer questions, earn points and help others
