Question about Danby 7 cu. ft. / 198 liter Chest Freezer Diplomat DCF718W
Older Danby Freezer Lid will not stay open on its own
Springs from hinge were on floor behind freezer, not sure how they should go back in so lid will stay open. Springs were only parts I found on floor.
  • 750 Answers
Hello ddelahay
Welcome to Fixya
My name is Huum,
At this site you can enter your model number and get diagrams and order hinges to replace your broken ones
This should allow you to fix your problem.
http://www.pcappliancerepair.com/
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Posted on Feb 03, 2009
Vulcan deep freeze 300litres (chest type)
Parts should be sold at your nearest refrigerator parts supplier.
Jan 31, 2014 | Vulcan Freezer EXTWARRANTY-GCO2D Extended...
Lid on chest freezer will not securely close Model #FCM 7DAA WH Serial #RTI63278 Mfg 81998
Remove lid, squeeze hinge back into shape and refit, adjusting screws in rear of hinge bracket as you do.
May 19, 2012 | GE Freezers
Water coming out of the lid of a Kenmore 5 cu. Freezer
Funny. We just spent an hour trying to figure out the same problem with our Kenmore. It is the third or fourth time that we've noticed water on the floor under the freezer, but the first time that we've been able to track it to the lid.
The only thing that makes sens to me is that this problem may be happening when our freezer has a frost buildup around the top of the unit which doesn't allow the lid to close perfectly snug. I'm thinking that this causes a bit of melt in whatever frost may be inside the lid from regular air circulation around the unit. It runs out the back of the lid when it opens.
Check that there is no frost around the rim of the freezer that may be causing a slight (it only takes a very small opening to allow warmer air to circulate under the lid) irregularity in the lid seal.
Jul 06, 2010 | Freezers
Both springs on lid broken. Lid won't stay up.
Whatever is on the shelf (parts that have not sold yet) is your best bet. Someone in the USA has to have em cause it hasnt been that long out of business.
here's one place to start ( i couldnt get thru)
AJ Madison
1416 38th Street
Brooklyn, NY 11218-3614
Phone: 800-570-3355
718-532-1800
Phone: 800-570-3355
718-532-1800 Fax: 800-570-7805 E-Mail: sales@ajmadison.com Appliance
Parts Store:
800-378-5177
Appliance parts store:
1800- 378-5177
hope this helps
Mar 30, 2010 | Woods Chest Freezer C1501W3
Chest freezer lid wont stay open without holding it open, its a Westinghouse 25 to 30 years, is there any adjustment that would solve the problem?
the hinges are bad and need to be replace
go to sears.com and click on the parts link
there enter the complete model number or call them if you want 1-800-252-1698
check to see if hinges are still available
hope this was helpful
Mar 07, 2010 | Kenmore 12.8 cu. ft. / 362 liter Chest...
I am defrosting my chest freezer and have the lid open and water is continuing to drip out of the lid. Why?
condensation has frozen inside your lid and now is defrosting and driping out. Reason : there is a air leak in the lid
Jan 09, 2010 | Frigidaire 12.8 cu. ft. Chest Freezer...
Re: danby upright freezer 20.1 cubic ft., model #
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Oct 13, 2009 | Freezers
Chest freezer lid repair
if your freezer has the sping etc in each of the hinges, then yes take them off. If your freezer has a torshon bar type spring, DO NOT take the hinges off, as you will not get it back together
i have always replaced liners with the door attached. The lid of the freezer is going to bow out of shape when you remove all the screws and take the old lining off, so you need to replace the lining and leave the screws loose so you can realine the door bit by bit.
it is a bastard of a job, and i wish you all the best.
May 01, 2009 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Chest freezer lid
Vacuum is caused by contraction of air. If your temperatures are being maintained the difference in how easily the lid opens and closes is not a point to worry about. If the lid wont shut after it is opened you do have a problem. If the lid is staying open at one corner try, with the lid open give it a slight twist pulling on the corner that is not closing fully. This action should spring the lid back to its original sealing position.
Jun 12, 2008 | Freezers
Danby 7 cu. ft. / 198 liter Chest Freezer Diplomat DCF718W Logo
239 people viewed this question
Top Danby Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Michael Van Der...
Michael Van Der...
Are you a Danby Freezer Expert? Answer questions, earn points and help others
