Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire front loader control board
You just informed me that it needs to be replaced because of the E 23 code. Is this something that I can replace and if so what is the part # for this product?
Thanks
Mike
  • w goodall Feb 04, 2009
    my front load washer is showing an e 23 message what does this code mean
  • 640 Answers
Ok you have to look it up ,,im getting different part numbers on different sites,,and prices,,its best to do some shopping but i will give you a start..appliancepartpros.com part AP3889795.sear.com part #134523106..prices very,,onthejob
Posted on Feb 03, 2009
I have a front loader frigidaire washer and shows a code ESE... what does the code mean?
This is a communication error between the machine control board and the motor control board. The actual error is E5E not ESE. Anyways, there isn't a way to test between the two parts to see which is faulty so check the wiring plugs on the motor control board and make sure they are secure, if so then replace the motor control board. If that doesn't correct it, then replace the machine control board. From experience, 90% of the time the motor control board is the part at fault
Jan 11, 2017 | Frigidaire Washing Machines
I got an error code e5e from frigidaire front loader
Hello barnessursula - Typically error code E5E indicates that there is a communication problem. Base on the intensity of the issue, I suggest contacting a professional technician to accurately repair the unit. Technician will need to check the wiring between the main control board and the speed control board. Depending on the diagnoses and if the wiring is bad, it has to be corrected. However, if the wiring is good the main control board will need to be replace or if the problem is not corrected, the speed control board will need replacing.
Dec 15, 2012 | Frigidaire ATF6000ES Front Load Washer
My fridgidaire model #LTF2940ES3 is giving me an error code E47 what is this
Very likely the problem is a bad door lock. It is very common problem with Frigidaire front loaders. You have to measure the resistance of the wax motor in the door lock assembly (the orange piece on the right side of the picture). I don't know why Frigidaire call it PTC. Very confusing. The normal reading should very close to 1500 Ohms. Otherwise verify all wires from the door lock assembly to the control board and, if everything is fine, replace the control board.
showpartimage.aspx?forumimg=ap4455026
If the door switch is bad, replace with this part.
If the control board is bad, replace with this part.
Oct 15, 2012 | Frigidaire ATF6000ES Front Load Washer
Code 62 on frigidaire front loader washer
Disconnect the plug from the drive motor and measure the resistance of pins 4 and 5 in the motor. If reading is between 105 and 130 ohms, replace the Speed Control Board. If the meter reads outside 105 and 130 ohms, replace the motor.
Sep 02, 2012 | Frigidaire GLTF2940ES Front Load Washer
Getting E20 error code on frigidaire front loader. It's 6 years old and has had one main panel board replacement already. Is this the same problem?
You are experiencing a pump issue. Typically a professional is needed to :
1. Check the drain hose for restrictions. Restriction, correctproblem. No restriction, go to step (2).2. Start the washer and checkfor 120VAC at the drain pump.Zero, replace the Main Control Board. 120VAC, remove the pump and checkit for blockage. If blocked, remove the restriction, if not, replace the pump.
Jul 28, 2012 | Frigidaire GLTF2940ES Front Load Washer
E-23 error code on Frigidaire 3577kro
Drain pump relay on board failed or wire off pump
Jul 22, 2012 | Frigidaire GLTF2940ES Front Load Washer
I have a Frigidaire front loader. Model ATF6000ES1. We got error code 23. The tech manual in the machine said it's the pump relay. Check wiring or replace control board. We checked the wiring to the...
An E23 error code on your Frigidaire Washer indicates a failure of the drain pump relay. Depending upon the model, your washer may be under warranty for up to 25 years, so check your warranty's status before attempting any repairs yourself.
Yor previous diagnostic its right; are you replace the control board... OK (other cases need replace it two times). Are you check the pump relay and wires, and this its OK, good.
Are you check and clean internally the pump and filter? So try cleaning it yourself, it is easy even with basic skill. You will need a star screwdriver, a scare-screw driver, pliers.
Remember, better have the machine empty before doing anything, because you'll be working on the drain line.
Hope this helps.
Jun 22, 2011 | Washing Machines
Affinity front loader ATF7000FGO E23 ERROR
E23 error code means the drain pump relay on the control board failed or wire off pump. You already replaced control board so check the wire at the pump and make sure it's secure.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/134879700.pdf
<a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
Feb 25, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire ltf6000es1 error codes
im playing catch up...but if your getting e23,,you have a defective control board,,,replace,,the pump relay on the board is shot...
Feb 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
Mar 19, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
149 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
