Question about Homelite Mighty Lite Lawn Trimmer
Homelite lawn trimmer
Has 1,2,3 settings for carby wont run on no1 setting & wont idle
3 Suggested Answers
  • 4 Answers
SOURCE: Homelite gas trimmer will not run without half choke and throttle
did you try fresh gas
Posted on May 31, 2009
moretons
  • 155 Answers
SOURCE: Homelite Mighty Lite Lawn Trimmer Magneto Air Gap setting 25cc
Normall setting is 10 thou but if there is no play in the crank bearings you can set at 8 thou
Posted on Jul 26, 2009
My homelite trimmer is very hard to start back after used for a while. What is the problem actually?
coil failing when hot or the spark plug same reason
carby fuel vaporizing in combustion cylinder
rings loosing compression due to age of trimmer
Homelite Trimmer Parts
Oct 24, 2016 | Homelite Garden
How do i adjust my idle crew
The idle screw isn't as important as the low/high setting on the carb. Start with one turn out on both low and high side settings.
Aug 30, 2014 | Homelite Garden
Homelite mighty lite wont stay running
the problem is in the carburetor most likely, it may be cleaned and adjusted, if not it will likely need a new carb
May 31, 2010 | Homelite Mighty Lite Lawn Trimmer
Hi i need the settings for a carb on a gas trimmer Homelite model number sh2025ub24ra it also has a number em0865201 on it. homelite 02-98 is on it also. any help sould be great. it just wont stay rinning...
Turn the set screws all way in.
Back them out 1 1/4 turn start it up let it warm up then adjust them in up to 1/8.
Depending on how it runs.
Apr 25, 2010 | Garden
Hi i need to know what the fuel mixture settings are on a homelite 26 cc whipper snipper 5 months old i dismantled the carby to clean it .now it starts but wont keep going
starting position for screws marked H and L is 1 and 1/8 turns out from carby for both ...Do not screw in tight otherwise damage to screw will occur
Apr 10, 2010 | Homelite Mighty Lite Lawn Trimmer
It runs normally at high revs but dies on idle
the units came out with EPA carb's some have idle screw adjustment and preset high jet, or the other way depending on the unit. try and change the fuel, use only high octane fuel for 2 cyc no ethanol with fresh oil mix, run for about 5 to 10 min's. if your carb has adjustment screws set your low side idle screw but still change the fuel.
Sep 03, 2009 | Homelite Mighty Lite Lawn Trimmer
Stihl FS85 Stalls when warm and gas is given will still idle
Make sure the carb settings are correct. Screw both tuning screws all the way in and then turn ot anticlockwise the following settings H 3/4 of a turn, L 1 full turn. (this is set to the standard setting)
Jul 10, 2009 | Homelite Mighty Lite Lawn Trimmer
Jun 23, 2009 | Homelite Mighty Lite Lawn Trimmer
Hard to start
Hello judy_keough2:
>>The Following is the Instruction File for Setting the Air Mixture Screws. Any Input is Appreciated. The Procedure is the Same for 1 or 2 Mixture Screws, Just Use the Instruction File and Skip Over the Section with the Missing Mixture Screw ( Usually the H Mixture Screw).
>>Now Setting the Air Mixture Screws:
>>****Turn the Idle Air (L) and Main Air (H) Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Set the Throttle Full Open, Start the Engine.
>>Turn the Main Air (H) Mixture Screw Clockwise Until Proper Revs are Obtained. **Carefully Use your Finger and Move the Governor Arm to Rev the Engine (on Chainsaws and Trimmers Use the Trigger to Rev the Engine) Until you Reach Max RPMs (on Chainsaws and Trimmers, the RPMs are Not Set to MAX. Set to Max and then Reverse the Setting Screw 1/4 or 1/2 Turn. If the H Mixture Screw is Set too High; the Engine will be Starved for the Oil in the Gas and Damage the Piston and Jug/Cylinder) and the Engine is Running Proper at Full Throttle Up a Grade and for Chainsaws and Trimmers they Do Not Bog DOwn Under a Load. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs.**
>>Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required.
>>Now Set the Idle Air (L) Mixture Screw so there is No Hesitation when Rapidly Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 14, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
122 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
