Question about Lands Phones
Unable to un night switch line #1
I have NEC NDK 9000 and when I came in this morning I pressed line #1 to type in #21# but am unable to get a line out - I have tried on all three extensions and unplugged the system - but still nothing
    Genius:
  • 1,847 Answers
Try reset the phone by going into the menu. then try again.
Posted on Feb 02, 2009
I have a NEC Dterm80 I need to program a button on the phone to be my handset button so I may be able to use my handset. I dont what to have to call a DeltaCom tech in to program.
First and foremost we need to know what system you have. Then we can proceed with how to program the button.
NEC Elite 48, 192, IPK 1
First pick the button you want to program. Lets say button 13 in this example. Next check to see if that button is programmed by pressing Feature and that key. If that key says Vacant then it is available for use.
Next you will need to hit "Feature and 4" on that station to find the port #. Port # is Tel 10 for example. That means port 10 is where your extension resides.
Now type in "Feature, #, 0 *, 8974". The phone should say Program Mode. Now look at the Line Keys. These are the keys right above the # pad. Count from left to right 4 keys. Hit Line Key 4 and then type 12 on the dial pad.
Now that we are in key programming we need to enter the port of your phone. Make sure the blinking cursor is on the far left. If not press * to move to the left. Now enter 10 (port 10 or Tel 10) on the dial pad. The cursor should be right near the L. If not then press # to move to that position on the right. Remember * will bring you back to the left and # to the right.
This is where you are to enter the key #. In our example it is key 13. Dial 13 on the dial pad. Next we are going to change the key to a headset key by pressing "Recall, Line key 3". It should say H Set on the right. Now that you have the proper key set you need to hit transfer to write the programming. Remember to try and find a key that is not programmed, this will ensure that you don't undo any programming that is already in place.
Any other system other than the NEC 48, 192 or IPK 1 will not work.
Nov 17, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Wharfedale LCD3210HDAF blank screen
Wharfedale LCD3210HDAF this tv was working fine the night before .. when i turned it on in the morning the screen came on then instantly went blank .. although the sound is fine i am unable to get any on screen including menu an volume information and of course can any one help ??
Oct 27, 2009 | Televison & Video
We had a power outlage last night and this morning my oven display says F5E1 and "door locked" - unable to clear either. Any advice?
HI. This is a self cleaning latch error code. Follow the procedure below to address this issue further.
1. If door latched:
A. Disconnect power from unit.
B. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
C. Replace door switch.
D. Re-apply power.
E. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
B. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
C. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Oct 21, 2009 | KitchenAid KEBC107 Electric Single Oven
Unable to save to contacts folder and unable to copy from sim to contacts folder, pls help my contacts folder is empty and i can't save nor copy to it. using bold 9000.
To add your SIM contacts to your BlackBerry Address Book.
1. Press the 'Menu' key.
2. Highlight 'Contacts' and select (press the trackball).
3. Press the 'Menu' key.
4. Highlight 'SIM Phone Book' and select (press the trackball).
5. Press the 'Menu' key.
6. Highlight 'Copy All to Contacts' and select (press the trackball).
To add your Black Berry Address Book contacts to your SIM.
3. Highlight the contact you wish to move and press the trackball.
4. Highlight the number and then press the trackball.
6. Highlight 'Copy to SIM Phone B...' and press the trackball.
7. Press the trackball and highlight save and press the trackball again.
hopes it helps better.
Jun 12, 2009 | RIM BlackBerry Bold Smartphone
VOICE MAIL INACCESSABLE - PHONE JUST RINGS
Voice mail was down. Called a service tech.
May 29, 2009 | NEC DTU 8D-2 Corded Phone
Onida stand by problem
sir my onida tv 21'' ineed un lock
Nov 07, 2008 | NEC PlasmaSync 42MP3 42 in. Television
Pass word de nec versa c200
help me coman decodes le bio fermes pas mot de pass mon portable c'est nec versa c200
I am unable to enter system's Bios utility setup due to my inability to get across the unravel the password used.
Jun 04, 2008 | Computers & Internet
I have a NEC NDK 9000 PABX fault after relocating phone lines,1 extension is not working and the other 2 are, I have noticed there is a red light flashing on one of the cards and am assuming there is a...
Each PABX or telephone system needs its own driver as each system has its own output format for the SMDR port. Therefore the MonTel system must have a suitable driver (technically a receiver) for each type of PABX that it can support.
http://www.netwiz.com.au/appnotes/1872.htm
May 10, 2008 | Lands Phones
Adding/Changing Name to NEC multi-line phone
On an NEC Elite you must enter system programming to change the name of the extensions. Unless you have a PC connection to the system this is somewhat complicated. If you would like me to step you through the system programming, please contact me @ 850-326-0394.
May 21, 2007 | NEC Electra Elite 32D-1 Corded Phone
Lands Phones Logo
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
