Question about Black & Decker B2250 Bread Machine
How do I set the dough setting on the machine
  • 21 Answers
Once you have your ingredients in the pan and the bread pan in the machine you close the lid and plug it in. Now you need to push the menu button until # 8 displays in the left hand side of the display screen. This is the setting for the dough cycle. The cycle time will display to the right of the cycle number, they will be in bigger numbers than the dough cycle number. The time is 1:30 for a 1.5 lb loaf and 1:40 for a 2 lb loaf. Now you need to select the crust colour and the loaf size. Now press the start button and the cycle will start. I have included the link to the owner's manual in case you don't have one. I hope this helps you. Good luck!
Carol.
http://www.useandcaremanuals.com/pdf/B220,B2250984.pdf
Posted on Apr 15, 2009
My wilbilt machine didn't have manual book . I make a dough in it but didn't cook I put on white bread setting What time I should put in d time I started it or what
You must have an indicator on the machine for what kind of bread to make, Put ingredients in and press the loaf setting of your choice and the machine should to the rest.
Your machine or any machine, does NOT cook the dough. You have to do that after you shape into a loaf or buns.
Nov 07, 2017 | Kitchen Appliances - Others
I got a wilbilt bread machine didn't have a book manual My machine didn't cook d dough
It won't COOK the dough. The purpose of that setting is so that you don't have to do the kneading and when the dough is ready you have to make what you want out of it and YOU bake it in the oven.
How do I put a delay start in the dough setting on a B&D B6000c bread maker
You can not in any machine use a timer delay on the dough setting. Sorry.
Feb 18, 2015 | Kitchen Appliances - Others
I don't know what setting to use for what bread or dough
need you to email me the model # for your black and decker, so I know which owners manual to check
Feb 04, 2013 | Black & Decker Bread Machine
Breadmaker beeping on dough setting not starting
Your machine is designed to do that. It is telling you that the oven chamber is too hot for a new batch of dough rise properly. Always open the lid of your machine after bakin and let it cool for at least 30 mins before attempting to make dough or bread.
Feb 03, 2013 | Morphy Richards Kitchen Appliances -...
Pasta roller squeaks when dough is not going through
The others had good solutions but I thought I would add mine as well.
I put vegetable oil on both outer edges of a folded paper towel that fits the entire width in the narrower roller settings of the machine. I run it through 3-4 times as if it were a piece of dough. It takes away the squeaking.....at least until it is needed again.
Dec 30, 2010 | KitchenAid Pasta Roller / Cutter Set
My ABM 6000 machine was accidentally unplugged near the end of the rise cycle. Can it be set to finish. When I restarted it it began kneading the dough again.
If you feel your dough has risen enough (look at your cycle times and estimate how long it was into the rise) and if so you could set your machine to the "bake" cycle and then click the timer button in 10 min. increments until it is set to bake the right amount of time. Maybe this will work. Hope it does!
Oct 28, 2010 | Welbilt Kitchen Appliances - Others
First time use. set machine to dough and pressed
Hi, Keep the bread pan out of the machine and start a kneading cycle. Look through the lid window and see if the motor shaft is turning. If no...then the belt fell off. If the motor spins, check to make sure the paddle spins freely. Keep pan out and turn paddle by hand. If no then the bearing is frozen. If that's ok..make sure you inserted the pan correctly into machine. If everything checks out then it's a faulty machine. Before you do anything send it out for warranty service. Usually it's warranted for a year. Hank
May 12, 2010 | Black & Decker B2250 Bread Machine
When you want to make only dough the dough senting does not work
The dough setting has a 20 minute delay before the paddles start to move. The manual say's "for most programs, there will be a 15-minute delay before mixing cycle begins"
Nov 07, 2009 | Black & Decker B2300 Bread Machine
Why my dough is tearing when i try to make ravioili?
You have to let the dough rest about 30 min. to 1 hour before passing the pasta in the roller. Also if you put some flour on both side of your pasta for the first passing through the machine it works well.
Jul 21, 2009 | CucinaPro Cucina Pro 150-25 Pasta Ravioli...
Black & Decker B2250 Bread Machine Logo
304 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Irene Tulloch
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
