Question about Lexmark X642e All-In-One Laser Printer
Lexmark x642e MPF Reset maintenance counter - Lexmark X642e All-In-One Laser Printer
    Problem Solver:
  • 10 Answers
Power printer off. When printer is powered off, hold down the check button and the right arrow button and hold these down while powering printer back on. Hold the buttons down for 10-20sec....
When printer is finished you are at the config menu. Hit down once, and you will see reset maint counter. Hit menu twice... and you will see resetting...
Then hit back twice to get to the main menu and use your up/down arrows until you see exit config menu. Hit enter and it will reboot printer back to the regular menu.
Posted on Mar 11, 2009
2 Suggested Answers
  • 412 Answers
SOURCE: Lexmark x642e MPF Reset maintenance counter
80 Scheduled Maintenance Message
The 80 Scheduled Maintenance error appears when you first power on the printer. The printer will still work even though it is in a maintenance condition. To clear the message temporarily and continue using the printer, simply press the Go button on the printer's screen. (For details on scheduled maintenance procedures, refer to the User's Guide for your printer.)
This message appears when the printer maintenance counter determines that maintenance is due. For a list of the part numbers of maintenance kits for most of the printers that require them, click here.
Note: The printer will still operate even if you do not have the kit replaced, but you may experience some print quality problems.
You are required to purchase the maintenance kit and have it replaced even if the printer is still under warranty. Some maintenance kits can be installed without the assistance of a technician. However, some warranties cover on-site installation of the maintenance kit by a technician AFTER you have purchased the kit. For more information on the warranty terms for the maintenance kit, click here.
Source: Lexmark KnowledgeBase
Posted on Mar 09, 2009
Lexmark 463de maintenance reset
To reset the maintenance page counter to zero:
1. Touch Reset Maintenance Counter from the Configuration Menu.
2. Reset Maintenance Counter appears in the header.
3. Touch 100K Kit or 600K Kit. Yes and No appear in a menu.
4. To cancel the reset operation, touch Back or No. All other button presses are ignored.
5. To initiate the reset operation, touch Yes.
Dec 03, 2012 | Lexmark "x463de multifunction laser...
Reset fuser x658de
To reset the maintenance page count to zero:
1. Touch "Right Arrow" to select Reset Maintenance Counter from the Configuration Menu.
2. Touch Yes to reset the counter, or touch No to exit without resetting the counter.
Sep 14, 2012 | Lexmark X658DE All-In-One Laser Printer
Reset x658de maintanance kit
I installed a maintenance kit (fuser, charge roller, transfer roller & pickup rollers) in my Lexmark x642e and I'm still getting light horizontal lines approx. every inch or so thru the page
Have you tried a different cartridge? Was there much spilled toner inside the printer? If you go into menus, and then help menu you can print a print defect guide that you can line up on your print and it will tell you exactly which part is causing the issue.
Mar 06, 2011 | Lexmark X642e All-In-One Laser Printer
HOW TO RESET LEXMARK X642E FUSER KIT COUNTER
Hit the menu button or the Key Button
Go into the configuration menu
Touch the arrow that says "Reset Maintenance Counter"
Select the Yes button. as you can not manually change the page count number.
It will reset the counter for you.
Oct 15, 2010 | Lexmark X642e MFP Laser Printer
How reset the printer maintenance counter for the lexmark t642
Here's an article in the Lexmark website on 80 Scheduled Maintenance" Message Appearing on a Lexmark T640, T642, T644, or an X64xe Series Printer. Included in this article are instructions on Resetting the maintenance counter to zero. Just click on this link: http://bit.ly/9pzU7R. Read thoroughly and follow the instructions carefully. Scroll down for the instructions on resetting the maintenance counter.
NOTE: RESETTING THE MAINTENANCE COUNTER SHOULD ONLY BE DONE ONLY AFTER REPLACING A NEW MAINTENANCE KIT.
Jun 29, 2010 | Lexmark T642 Laser Printer
Lexmark T642
There is a great video that shows step by step how to install the fuser, transfer roller, charge roller, pick up tires and then reset the 80 Scheduled maintenance message
Apr 03, 2009 | Lexmark T642 Laser Printer
Cant find counter on my lexmark x642e can any one help, I have no manules .thanks
Maintenence counter is in Configuration Mode.
Power on the printer while holding down the 2 & 6 buttons. Continue holding buttons for 20 seconds. You will find the counter in Maintenence counter and can reset it there.
Feb 22, 2009 | Lexmark X642e All-In-One Laser Printer
Lexmark 640
This one is easy...
Turn printer off
Before powering on, hold down the button with a check mark on it and the directional button to the right of it..
Power printer on, still holding down said buttons...
wait 15-20 seconds and release... when the printer finishes booting up it will be in config mode
(if you get the error 80 scheduled maintenance, hit the go button)
hit the down button once... you will see then reset maint counter. Hit the menu button ... you will see something to the effectof reset with a check mark next to it..
Hit the menu button again and you will see it say reset. Then hit the back button till you get back to the main menu and use your up/down arrows until you find exit config menu. Hit menu and it will reboot itself right back to the regular screen.
Hope this helps,
Feb 19, 2009 | Lexmark X642e All-In-One Laser Printer
Hi~
You can reset the maintenance count by going to the Configuration Menu.
Step 1: Turn off your X64x printer
Step 2: Hold the 2 and 6 buttons while the printer is off
Step 3: Turn on the printer but don't release the buttons yet. Keep holding those buttons for about 10 secs
Step 4: On your Operator Panel, you should see "Configuration Menu"
Step 5: Scroll down and look for "Reset Maint Count" and select it.
Step 6: Exit Config Menu and powercycle your printer (turn it off then back on)
Hope this is helpful... =)
<<ichtuscheeky>>
Jan 30, 2009 | Lexmark X642e All-In-One Laser Printer
Lexmark X642e All-In-One Laser Printer Logo
1,927 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
