Question about Kenmore 19365 Computerized Sewing Machine
Kenmore sewing machine
1 Error
  • Anonymous Apr 11, 2009
    how to replace the needle in my kenmore 150
  • 136 Answers
Contact sears
Posted on Jul 12, 2009
3 Suggested Answers
SOURCE: Kenmore sewing macine cams #1 (26841) and #2 (26842)
I have the set and will be posting on Ebay this week
Posted on Jul 13, 2009
  • 980 Answers
SOURCE: Kenmore 2142 sewing machine won't zigzag.
Before you put the cam in did you make sure the machine was set on straight stitch and then select zig zag?
Posted on Nov 06, 2009
My kenmore 19001 has an error #1 what does this mean
Usually the manual will list common error codes under the troubleshooting section. You can probably also contact Kenmore Support.
Apr 28, 2016 | Kenmore Sewing Machines
My machine shows an error number E1what is it
The error code 1 indicates the fuse on the A board has blown. The fuse should be replaced with a part number 000182177 fuse. The original fuse is a 2.5 amp fuse and the replacement fuse is 3.15 amps.
You should take the sewing machine to a Sears service center or a retail store for repair.
Sep 11, 2012 | Kenmore Sewing Machines
Getting E-1 and E-error messages after bending needle.
it means the machine is out of order
mine does that,,I usually just have to turn it off for a few minutes & that normally clears it
Dec 02, 2010 | Kenmore 19233 Computerized Sewing Machine
Error 1 message will not leave
Hi - first, check your manual to see if the error is described somewhere. Follow the instructions. If the manual tells you to take the machine in for repair, try a couple things first.
Often when your needle starts to shudder, the thread is caught on something somewhere along the sewing path. Turn off your machine, change your needle, take all of the thread out of the machine and rethread it. Then remove your bobbin to make sure that there is nothing stuck in the bobbin case, or in the area where you insert your bobbin into the machine. Look around the sewing area to see if something looks out of place.
After you insert a new needle and rethreaded your machine, and before you turn the machine back one, try using the wheel to make a few stitches manually. Watch your sewing thread to make sure it is feeding evenly. If the needle does not move up and down correctly, or if you hear a grinding or bumping sound, you probably need to take the machine to be repaired. Otherwise, turn your machine back on. If the error message is gone, try sewing slowly for several inches - if all seems well, increase the speed a little at a time. If anything seems off to you while you sew - stop sewing immediately and look very carefully to see if you can find a problem.
Dec 20, 2008 | Kenmore 19365 Computerized Sewing Machine
Error 1
This problem sounds like it is related to a fuse, You will need to call your local Sears store, find out what your service options are and have then replace the fuse. This should be covered under the 2 year electrical warranty
Jul 26, 2008 | Kenmore 19233 Computerized Sewing Machine
E1 Error
check the solution what I already wrote.
Aug 10, 2006 | Kenmore 19233 Computerized Sewing Machine
Kenmore 19365 Computerized Sewing Machine Logo
87 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
