Question about Omron Hj 720ITC Advanced Pocket Pedometer
Need manual for Monitor #713-C
Need information on how to work monitor
  • 3 Answers
Pedometersaustralia.com/UserFiles/.../File/HJ720ITE Mtrc Ped Aus.pdf
Not sure if the above pdf will work for your model or not but I hope this is helpful.
Posted on Feb 12, 2009
How do you get the monitor to work? Won't turn on.
A lot of the times the bike has to be pedaled for the monitor to power up, even with batteries. If you provide your model and serial number and contact our Technical Support Team we would be more than happy to try to help you figure things out :) by chat at www.sportsmith.net or by phone at 888-713-2880
Jul 29, 2015 | Exercise & Fitness
CRT acer 713 DRIVER
can you give us detailed problem with your monitor so i can give and help you out and solved the problem with your monitor.
Nov 05, 2012 | Acer AC 713 17" CRT Monitor
Monitor pop menu keeps displaying in the middle of the screen
There should be a button on the front or bottom of the monitor that will make the menu disappear. Try pushing the buttons--the left button is the most likely one. var fctb_tool=null; function FCTB_Init_db8f26077d264d4aa210f465db5a34e2(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_2cf9d8ce2058411c818233e09481c710(t) { fctb_tool=t; start(fctb_tool); }
Dec 17, 2010 | Acer AC 713 17" CRT Monitor
Out of range
acer ac 713 crt monitor picture incorrect (left&right)
Nov 22, 2008 | Acer AC713 17" CRT Monitor
Resistor
LG 500G MONITOR
The problems is this set powersupply indicator led is blinking
Jun 12, 2008 | Acer AC713 17" CRT Monitor
Acer AC713 drivers problem
If you know the brand / model of the motherboard, just download the drivers from the manufacturers website!
Mar 06, 2008 | Acer AC 713 17" CRT Monitor
Monitor green where it should be black
resolder some components on the boards inside your monitor especially on the CRT neck board.
check also your monitor cable connection to the System unit.
also check if your video card was fully intact on the board.
Nov 28, 2007 | Acer AC 713 17" CRT Monitor
Monitor problem
you will have to take it to tech as there is a possibility it is loose from inside or print loose inside. if it is ok then you will have to check circuit connected to menu control ckt or control itself is defective. hope this will help.
Sep 21, 2007 | Acer AC 713 17" CRT Monitor
Flashing monitor
the ram itself is not related to your problem, but check the VGA lead connections at both ends and see if the connection is loose and also check the power cable. Other than that it may be the monitor circuitry or CRT itself thats the problem and after warming up the problem goes away, so a repair may be needed or a replacement monitor.
Jul 13, 2007 | Acer AC 713 17" CRT Monitor
Omron Hj 720ITC Advanced Pocket Pedometer Logo
116 people viewed this question
Top Omron Sport & Outdoor - Others Experts
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you an Omron Sport and Outdoor - Other Expert? Answer questions, earn points and help others
