Question about Briggs & Stratton 11HP 6200W Es Generator
Have a problem with a BS600-W-1 generator
Will not start and has no spark. put in a ne plug and still nothing have a new start switch. new filters new gas
  • 24 Answers
With your model number I could see if it has a low oil safety switch I have seen them go bad (check your oil level )
With all wires un plugged from the coil you should have spark
if not coil is bad .
Use another spark plug to test for spark, ground the side of the plug by holding it against some-ting metal on the engine , spark
plug wire hooked to the plug. leave a spark plug in the cylinder
head so gas wont fly out and hit the test spark plug catching fire (seen it done).
Good luck
Posted on Feb 06, 2009
Clarke 2200kw generator will not start Have changed spark plug checked flters put in fresh petrol
are you getting spark , is the on switch on , some people forget to do this
Jan 19, 2015 | Electrical Supplies
Free onan generator manual
i have a onan model5.5 HGJAB-1038C GENERATOR IT SHOWS CODE 14 IT WILL START FOR 15 SECONDS AND WILL STOP -- I HAVE REPLACED THE FILTER, NEW FUEL PUMP. NEW SPARK PLUGS- CLEANED CARB AND STILL NOTHING I AM IN MEXICO AND NO SERVICE PEOPLE I NEED A SERVICE MANUEL FOR THIS UNIT--THANKYOU PLEASE
Jan 12, 2014 | Computers & Internet
Generator back firing from inlet manafold
Your symptoms are from running lean. Foam air filters put debris in carb jets. Check all the carb passageways and jets. Always start with a new plug.
Nov 29, 2013 | Electrical Supplies
My miller 225 welder will crank but not start, no spark, i tried jumping the oil psi sensor. what do i do next?
I had a problem like this a few days ago try taken of the air filter to were u can see the choke it may not be opening rite just cause it opens don't mean itsnot opening rite get a small spray bottle put gas in it and as u start ur welder spray the choke with with the gas a lil if it starts turn ur switch to run for while it workd for me if that don't maybe change the spark plugs
May 20, 2012 | Bobcat Miller 225 Welder Generator 907209...
It started but when i pluged in ti it it quit. has not started since. checked plug and it was loaded with gas. install new plug and tried. check spark and it appears eratic. pulled air filter off and it is...
sounds like the float is stuck, how long has it ben setting around? try some carburetor cleaner. spray the carburetor down. empty the fuel tank put fresh fuel with fuel treatment. you may have to remove the spark plug, pull starter string a couple of times to clear out cylinder make sure spark plug is dry put back in and try to start the generator.
Dec 10, 2009 | Briggs Stratton H7159 & Stratton® 5500,...
Gen. wont start been stored since 03 bought new used twice
As for checking for a spark, remove the plug from the engine, plug in to lead, then rest it somewhere convenient, with the threaded end to ground. (ie touching the chassis or frame)
The low oil indicator may be on the side of the engine, but I'm not certain.
If you discover that the spark is good, it could be a timing problem.
If there is no spark, it's probably the magneto.
I hope that helps.
Jul 24, 2009 | Coleman Powermate Premium Plus 6250W...
Honda eu2000 generator starts but no power to panel
You probably need to do a tune up. Change the spark plug, oil, air filter, and you may also need to add new fuel.
May 28, 2009 | Electrical Supplies
Wont start
Hi
Check the spark at the plug,the compression and carburation.Check and clean the gas and air filters.Disassembly thr carb and clean it with compressed air.Change the gas from gas tank and start the engine.
best regards savumihai71
Dec 20, 2008 | Coleman Powermate Powermate 5000W...
Just won't start
check the spark plug after a failed attempt to start. If dry, then no fuel is entering engine.
Did you leave old fuel in carb? if so, your carb probably is dirty: old gasoline deposits varnish, gum, and you will need to dissassemble carb and clean it.
Nov 14, 2008 | McCulloch 13HP 338 Cc Portable Generator #...
Briggs & Stratton 11HP 6200W Es Generator Logo
465 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Craig Butler
Craig Butler
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
