Question about Universal Remote Control Bravo AV-HR0703 LCD Monitor - 7" Widescreen ¿ Headrest / Universal Mount ¿ Remote Control ¿ Dual Inp... Car Video Player
Need code for bravo 13 in 1 remote control
Hi have borrowed a small old portable sharp tv 37-AM-23H with only 3 channels tuned in. There is no panel to manually tune tv so i'm guessing a remote control will do it. I have a Brava 13 in 1 remote control but have lost the codes. If I get the code for a sharp tv will I be able to tune into the other two channels? Currently only recieving BBC 1 BBC2 and ITV 1. I do also need the code for a sharp TV.
Many thanks
J
Remote control
If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Feb 26, 2014 | Nesa Vision Car Audio & Video
Apex dt502 digital tv remote was lost
Go to Remotes.com - Or - you can call 1-800- remotes to get a replacement. The new recommended replacement remote sells for $19.95 and has a large red mute button on it. The old one is no longer available unless you wish to do a good web search or try ebay.
Feb 02, 2014 | Car Audio & Video
Screen working white no video
if u can post me in georgian lenguage..and if not..post me in russian or in english.... or let me see video ok?
Aug 09, 2013 | Universal Remote Control Bravo AV-HR0703...
Need unlock region free code for Portable DVD player Polaroid-PD0742
I did it for my PDM 0742.
Turn it on.
From the remote control push 1379.
It will show region 1 on the screen.
Push enter to change it to 9 (region free).
Push stop.
It is done.
Good luck.
Sep 07, 2008 | Car Audio & Video
Unlock region codes for portable dvd player - panasonic DVD LS80
1. Press the Menu button on your remote control 2. Press the 5 button on your remote control
3. Press the 7 button on your remote control
4. Press the 5 button on your remote control
5. Press the 3 button on your remote control
6. Press the 8 button on your remote control
7. The currently selected region will be indicated on the TV.
8. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 9 button for multi-region playback
9. Press the Menu button on your remote control
10. Press the Menu button on your remote control
Tested with Region 1 DVD's on my UK player (Region 2 bought from Comet)
Aug 04, 2008 | Car Audio & Video
DDX7017 CODE
hi i need help with my ddx7017 code but i have the remote control please help me with the code thank,s
Jun 01, 2008 | Kenwood DDX7017 Car DVD Player
Sharp TV switches to "input 2"
There's an option on the menu to tuen 'demo mode' on and off. If it's set to on, that's your problem. It will be switching input sources every 2 minutes or so. Switch this off and it'll be ok again.
Feb 13, 2008 | Dual XDVD8181 Car Video Player
Dual xdvd710
If you can find a separate tv tuner with remote the run it through the unit rear input. But stand alone tuner is rare if it even exist. Search Ebay to see if you can find one. There is another way by hook up a small portable tv with video/audio output and use an adapter from RadioShack to send the signal to rear input of the unit, but picture and sound quality is only as good as the reception of the tv. Goodluck.
Feb 10, 2008 | Dual XDVD8181 Car Video Player
Car Audio & Video Logo
868 people viewed this question
Top Universal Remote Control Car Audio & Video Experts
xxxxxx xxx
Are you an Universal Remote Control Car Audio and Video Expert? Answer questions, earn points and help others
