How to connect an dvd to old tv
Is it possible to connect an dvd to an old tv?
The tv only has an Ant. input (coax)
I also have a vrc. I tried to set that up. Coax cable from ANT. out to ANT In on the tv.
Tried to tune the channels to find anything, but without success.
Maybe it just wont work on my tv?
The tv works with turn-buttons, maybe I do something wrong for searching the channels.
It can also setup only 12 channels and its like impossible to see which channels it's on.
I hope somebody can help, it's for a school project.
grtz
  • angelo_welle Feb 04, 2009
    I just figure it out.
    After a long search. I needed tot set the tv to the U channel an set the frequentie on 75 UHF.
    I jused the vcr player as rf modulator and now can see dvd.
    thanx greets, i'm happy now
    Problem Solver:
  • 15 Answers
They make a small box called an RF modulator. It takes the audio/video signals and turns them into a signal the coax can read. You can pick one up at electronic stores. There usually about 15-25 $.
Posted on Feb 03, 2009
The VCR works fine but I only get audio with the DVD
  • Are you using an AV cord between your VCR and TV or a standard coax? If you are using a standard coax then first make sure the tape is functioning properly. Next try a new coax and if the problem persist there might be an issue with the coax output/input on the VCR or TV itself.
  • If you are using the AV inputs (red,white and yellow) you want to remember that the red and white are for audio and the yellow is for video. So in this case you want to
  1. Make sure the tape is functioning correct. Old tapes that have seen their better days will produce audio but no video and vice versa.
  2. Check the connection of your yellow AV input (audio). Make sure it goes from the same output on your VCR to the same input on your TV as the audio cords are running to.
  3. If this checks out then try a different audio cord and see if this fixes it.
  4. If not then try using a different output on the VCR and input on the TV all together.
  5. At this point it is possible one of the AV audio jacks are bad either on the VCR or on the TV.
Regards, Tony
Apr 22, 2011 | Apex Digital ADV3800 DVD Player/VCR
How do I hook up a vrc/DVD player. There are no outlets on the set.
I assume you mean that there are no composite or component inputs on the TV. If it has a coax (antenna) input, you will need an RF modulator. These convert video inputs and output the signal via a coaxial cable.
This type of converter can be found in some stores that sell electronics equipment and online.
I hope this helps .
Mar 27, 2011 | Fisher PC-19R90 19" TV
How do i use the ant. passthrough on tv2 in dual mode w/ dish dvr625
ANT. passthrough for an ant. connected to your 625 receiver will only work on tv 1. The only way to do this is to RF modulate your tv 2 coax to an RCA and hook the RcA cable to your tv2. then use another ant. to connect coax allowing you to pick up dish programing on an input and then going to the channels to enjoy local over the air programming.
Nov 26, 2009 | DISH Network DVR-625 DTV Receiver /...
Crackling noise / loud static when tv is attached to antenna
Pick one:
RFI (Radio Frequency Interference) from nearby electrical/ electronic device.
Antenna misaligned to transmitter.
Antenna coax impedance mismatch.
Faulty connections.
Faulty antenna.
TV tuning.
If the OLD TV worked OK on same antenna it sounds like TV tuning or ANT socket/wiring loose.
Try:
Auto-tune TV with ant plugged in.
Get TVF (TV fundi) or friend to help align antenna.
Maybe a large bird sat on it.
Check coax for sunburn / deterioration. Renew if XX.
Oct 11, 2017 | Televison & Video
Help
Hi and welcome to FixYa,
Offhand, the easiest connection method would be to use a short RF patchcord to connect the RF out of the DVD/VCR to the ANT/CABLE/RF IN of the TV. Set the TV to Channel 3. To continue able to receive ant/cable channels, the cable input should go to the ANT/CABLE/RF IN of the VCR/DVD.
Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 16, 2009 | Sharp 27R-S50 27" TV
Connecting magnavox dvd/vcr player DV220MW9 to a 40 year old TV
What type of Inputs do you have on your TV. (ANT IN, S-Videio, RCA Video,RCA Audio)
If you only have a ANT In or RF Coaxial hook up you will need a RF Modulator
Jan 03, 2009 | Philips Magnavox DVD/VCR Dual Player
VCR/DVD
Initially, it would appear that the only INPUT possible is through the RF connector. Should this be the case, a workaround would be to connect the RF OUT of a VCR to this RF/ANT/Cable IN of the TV, set the TV to Channel 3. An RG59 patch cable would do the job. Should you want to connect a DVD, connect the Video/Audio OUTPUT of the DVD to the Video/Audio INPUT of the VCR. Incidentally, the regular cable/ant should be connected to the RF IN of the VCR.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 12, 2008 | Emerson TC1325 13" TV
Connecting coax to my DVD/VCR combo
For the DVD portion, you need to use either composite, component, or possibly S-Video or HDMI. DVD players do not utilize coax, since they do not incorporate tuners. However, since you have indicated it is also a VCR, it should have a coax input/output for that. perhaps it is a player only and doesn't have a tuner? But I have never heard of this in a combination unit. At any rate, if it truly does not have a coax input, then you will have to leave the coax connected directly to your TV and use the above mentioned connections between the home theater, TV, and DVD/VCR unit. Audio between the DVD/VCR and home theatre, and video between the DVD/VCR and TV
Sep 04, 2008 | Televison & Video
Hooking up a dvd/vcr player
The easiest way to connect the unit is via coax. You can come out of your satellite receiver via the "Out to TV" on the back of the receiver to the "In from Ant" on your DVD/VCR combo. You can then connect another coax from the "Out to TV" on the DVD/VCR combo to the "Ant/Cable" input on the back of you TV. Make sure the satellite receiver and the vcr are both modulated to the same channel, normally channel 3.
Dec 31, 2007 | Emerson EWF2004 20" TV
New VCR Old TV
Hi This problem has been around for some time when connecting a DVD player to an older tv, and now has become a problem with newer VCR's. You must purchase a device called an RF Modulator which will allow you to connect to the older tv. We sell them at our shop for $30.00 but I have seen them quite often for $65.00 and up...so it pays to shop around. Good Luck
Sep 27, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
