Question about Texas Instruments TI-Nspire Graphic Calculator
My screen will not work
When i turn my nspire on, both sides of the screen are dark blue and the rest of the screen is blank no matter what buttons i press. i have tried to switch batteries but i beleive my problem is with the screen itself. please help me out.
when the loading screen comes up there are black lines going up and down the screen and the loading bar is barely visible.
  • 1 more comment
  • Anonymous Feb 04, 2009
    i would fix that if i could see what i was typing on my keyboard
  • bwilliams917 Feb 25, 2009
    Seems to be the same problem. If hooked to the TI-NSpire Computer Link, I can get a screen shot which shows the calculator is on, but I can't see anything on the screen itself. Tried adjusting the contrast, using the reset button, and the hard reset key combination with no change in what I can see.
  • Anonymous Apr 29, 2009
    I am having the same problem with my TI-Nspire screen. It has come on once and it is not the contrast. It looks like the screen is dying.
Mine had a problem like that, just that the screen had become blue. I later found out that someone had gone to the contrast mode and made my screen that way. I am sure we have the same problem, but you can try and see. Wish you luck.
Posted on Feb 03, 2009
  • CatCode Feb 14, 2011
    Has anyone found a solution for this because i have the same problem at the moment
My toshiba at200 table 10.1 wont turn on
1. When you press the power button to turn it on, do you see any thing on screen, like the toshiba boot up screen or something like that. Or is it completely blank (black color) always.
2. Can you see a faint image of your desktop (try to see it in dark place with flash light). This is important to confirm.
3. Also, when you press power button, do you see the LED lights on laptop blinking or solid green (which ones are in blinking/solid) and do hear any sound ? Or do you feel that your laptop doesnt even try to boot.
4. Can you hear any Beeps when you try to turn on the computer. If yes, what is the sequence of those beeps.
Continued......
If you answers are -
1.
blank
2.
no image
3.
only the satellite light is blue, the powercord is blue and the battery is blue
4.
no noise
Please do the following carefully and let me know result :
1. Shutdown and Unplug your laptop.
2. Remove the battery from the laptop.
3. Wait 2-3 minutes
4. Now press ON (power button on laptop) for 1 minute
5. Then release the finger and wait one more minute.
6. Now plug in the power cable (dont insert battery yet) and press ON button.
7. Did your screen start working now ? (do you see windows loading)
Jan 04, 2015 | Video Game Consoles & Games
How to I adjust the brightness of the ti-nspire touchpad?
To increase the contrast (brightness) of the screen of a TI Nspire with Touchpad, press the CTRL blue key and hold pressure. Then press the Plus button. Release both keys when contrast is adequate.
Mar 09, 2013 | Office Equipment & Supplies
The calculator crashed two times several days ago while I was using it. It worked fine the following day, but after that the screen became very dark. So dark that I need a flash light shining at it to see....
I will address one part of the question only: I will avoid the speculations.
How to change the screen contrast
  1. (TI-Nspire with native keyboard): With the TI-Nspire keyboard in place,
  2. Press the ON button to turn calculator ON.
  3. Press and HOLD the Control key [CTRL]
  4. Press [+] to darken the screen
  5. Press [-] to lighten the screen (Your case)
  6. Stop when contrast is adequate.
  • TI-Nspire with TI84PLUS keyboard: With the TI84PLUS keyboard in place
  • Press the ON button to turn calculator ON
  • Pres the [2nd] key and RELEASE it
  • Press the [UpArrow] of the NavPad to darken
  • Press
Feb 15, 2010 | Texas Instruments TI-Nspire Graphic...
I had not used the calculator in a year. I replaced the batteries. The calculator will not turn on.
Here are some quick tests.
  1. Verify batteries are correctly inserted (I have to rule this out) and that the polarity diagrams are respected.
  2. Try to turn the calculator ON with the TI-Nspire keyboard and with the TI84Plus keyboard.
  3. With the TI84Plus keyboard in place, try to adjust the contrast of the screen by
  • pressing the [2nd] key and releasing it.
  • Then press [UpArrow] to darken the screen if it is too light OR the DownArrow if screen is too dark.
If you fail to get any meaningful response from the calculator, put the TI-Nspire keyboard in place/ Make sure you do not press the ON key (put the slide cover to protect screen and keyboard) and press the RESET button on the back of the calculator. For that, use a straightened paper clip.
If all fails, I suggest you reinstall the Operating system. The procedure is detailed in this article.
Feb 09, 2010 | Texas Instruments TI-Nspire Graphic...
My nspire is not turning on. i press the on button, but the screen is just blank.
Here is what the TI knowledge base says about a calculator failing to turn on
For the TI-Nspire™ Family:
  1. Remove thekeypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) andremove at least 1 battery from each column of batteries. After 2-5seconds, reinsert the batteries and turn the unit on. This will causethe unit to reboot the operating system.
  2. Remove the keypad(for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove atleast 1 battery from each column of batteries. After 2-5 seconds,reinsert the batteries and LEAVE THE UNIT OFF (do not turn on and thenback off). Hold down [Home] [Enter] [P], and while holdingthese keys, press [On]. The device will boot up as in the previousreset, but will display a menu with the following options. Please tryoptions 1, 2, 3, and 4 in that order. ** The [Home] key is located atthe top right of the TI-Nspire keypad and has a picture of a house onit.
Note:TI-Nspire family model options 2 and 4 above require that the OS be installed. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above.
1. Cancel - The most non-intrusive reset option; no changes are made, the unit restarts.
2. Delete Operating System – The operating system will be deleted without deleting any documents.
3. Delete Document Folder Contents – This will delete the user’s documents, but will not delete the OS.
4. Complete Format – This will delete the OS and all documents for a total erase of memory.
Hope it helps you solve the problem.
Oct 18, 2009 | Texas Instruments TI-Nspire Graphic...
Blue screen red lock
I dont have a clue what happened...
The screen is blue and has a little red lock on the upper left hand side...
remote only works to turn it on...no other buttons work.
Help please!!!
Apr 01, 2008 | Insignia IS 20" TV040919 TV
Will not turn on
When holding the power button, to turn on the device, the screen pixelates dark and then goes blank. If I continue to hold the power button the screen will continue to pixelate dark and then go blank. In the end, the device still will not turn on.
Dec 18, 2007 | Garmin GPSMAP 180 GPS Receiver
Screen on Toshiba M35x S149 Laptop blank/flickers
Ok, from the beginning. Can you do a cold boot and get into the bios? (is there an image on the screen then)
Secondly, can you connect to an external monitor and see an image?
Did it do this only when it was heading in to hibernation? If so, it sounds like the power management needs some adjustment.
If there's no image on the external monitor, you may have a video/motherboard problem, or it still could be the operating system/power management.
It all depends on if you have video in bios.
Let me know.
Good luck
Nov 10, 2007 | Toshiba Satellite M35X-S349 Notebook
Texas Instruments TI-Nspire Graphic Calculator Logo
1,180 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
