Question about Mr. Coffee CGX20 12-Cup Coffee Maker
Our Mr Coffee maker has slowed down since new, it's a 4 cup size
Our Mr Coffeemaker has slowed down a lot. It is a 4-cup size, 700 Watts.
  • 257 Answers
Hi, Don't have much to work with here so I will do the best I can, I am going to assume the water where you live has scale or calcium which builds up in the coffee maker over time. Go to your grocery store and buy some cream of tartar which you can find in the spice section, it is a white water soluble powder. Dissolve about a teaspoon full in a pot of your coffee water, put in a filter with nothing in it and cycle the water through the coffee maker, if it is really scaled up do this a couple of times, discard the filters which probably will have some little white and yellow chunks in it and this should speed her back up. Good Luck!
Posted on Feb 03, 2009
  • Jim London
    Jim London Feb 04, 2009
    Hi, I hope I solved your problem, Please rate my response, your
    favorable ratings help others that may have the same or similar
    problem. Thank you!
Slow dripping and ground cup is extremely hot
Have you tried cleaning your coffee maker? If not just fill half of the carafe with white vinegar and let it brew. Keep basket in during cleaning but no filter needed. After running the vinegar through the brew cycle, fill the carafe with plain water and run fresh water through about 3 to 4 times. I do this every 4 to 6 months. I have a light on my coffee maker that lets me know when I need to clean it. I hope this helps.
Feb 27, 2015 | Mr. Coffee 12-Cup Programmable Coffeemaker
Coffee plate not hot
That's not a lot to go on. But, I'm going to presume the obvious has been checked and say that the warming plate's heating element has gone bad. This is not a serviceable part. So, it is time to replace your coffeemaker.
Oct 23, 2011 | Mr. Coffee JWX27 12-Cup Coffee Maker
The red light on my coffee pot is on and will not go off. I have run cleaner thru the regular cycle now what? Its a 12 cup programmable Mr. Coffee.
I know this sounds like a pain but it takes a while toget that silly light to stop. Decalcifying your MR. COFFEE® Coffeemaker Minerals(calcium/limestone) found in water will leave deposits in your coffeemaker andaffect its performance. It's recommended that you regularly remove these depositsusing MR. COFFEE® Cleaner or vinegar. MR. COFFEE® Cleaner is available at manyretail stores or by calling the MR. COFFEE® Consumer Service Department at 1-800-MR COFFEE(1-800-672-6333). 1. Follow packageinstructions to prepare one batch of MR. COFFEE® Cleaner. Pour the mixture into the water reservoir. Before decalcifying,remove the water filtration disk from the machine. NOTE: 4 cups or 20 fl. oz. of undiluted, white householdvinegar may be used as a substitute for the cleaner. 2. Place an emptyMR. COFFEE® 10-12 cup basket-style paper filter or MR. COFFEE® permanent filter into the filter basketand slide the brew basket in place. 3. Place theempty decanter back in the unit. 4. Press theCLEAN button until the CLEAN indicator light turns on (Figure 9). For your convenience the cleaning cycle isautomatic. The entire cycle will take 45-60 minutes to complete. During thecleaning your coffeemaker will: a. Slow brewapprox. 3 cups of cleaning solution. b. Pause for 30minutes (the CLEAN light will remain on to alert you that the process is active). c. After 30minutes, your coffeemaker will brew the remainder of the cleaning solution. d. When complete,the CLEAN light will turn off and your coffeemaker will turn off. 5. Discard the cleaning solution and rinse the decanterthoroughly with clean water. 6. Fill the water reservoir with clean, fresh water. 7. Place the empty decanter back on the coffeemaker. 8. Remove and discard the paper filter usedduring the cleaning cycle. If a Mr. Coffee® permanent filter was used during cleaning, remove it andrinse it thoroughly before replacing it in the filter basket. 9. Begin brewingand allow the full brew cycle to complete. 10. Repeat steps 5 through 9 one more time.
Mar 31, 2011 | Vacuums
This morning when my wife went to make coffee. The clean light came on. we couldn't get it to shut off. She went through the clean cycle.The light came back on again. What should we do ?? Mr. Coffee...
I know this sounds like a pain but it takes a while to get that silly light to stop.
If you have problems call the 1-800 number below.
Decalcifying your MR. COFFEE® Coffeemaker Minerals (calcium/limestone) found
in water will leave deposits in your coffeemaker and affect its performance. It's
recommended that you regularly remove these deposits using MR. COFFEE® Cleaner
or vinegar. MR. COFFEE® Cleaner is available at many retail stores or by calling the MR.
COFFEE® Consumer Service Department at 1-800-MR COFFEE (1-800-672-6333).
1. Follow package instructions to prepare one batch of MR. COFFEE® Cleaner. Pour the
mixture into the water reservoir. Before decalcifying, remove the water filtration disk
from the machine.
NOTE: 4 cups or 20 fl. oz. of undiluted, white household vinegar may be used as a
2. Place an empty MR. COFFEE® 10-12 cup basket-style paper filter
or MR. COFFEE® permanent filter into the filter basket and slide
3. Place the empty decanter back in the unit.
4. Press the CLEAN button until the CLEAN indicator light turns on
(Figure 9). For your convenience the cleaning cycle is automatic.
During the cleaning your coffeemaker will:
a. Slow brew approx. 3 cups of cleaning solution.
b. Pause for 30 minutes (the CLEAN light will remain on to alert
c. After 30 minutes, your coffeemaker will brew the remainder of the cleaning
solution.
d. When complete, the CLEAN light will turn off and your coffeemaker will turn off.
5. Discard the cleaning solution and rinse the decanter thoroughly with clean water.
8. Remove and discard the paper filter used during the cleaning cycle. If a Mr. Coffee®
permanent filter was used during cleaning, remove it and rinse it thoroughly before
9. Begin brewing and allow the full brew cycle to complete.
Mar 27, 2011 | Microwave Ovens
What can I use to clean my Mr. Coffee 12-cup coffee maker?
The standard way to clean a coffeemaker is t run white vinegar through it then run straight water through it. That is one of the few things that will clean without leaving a residue. Good luck.
Jan 05, 2010 | Mr. Coffee FTX24 12-Cup Coffee Maker
How do I use the self-cleaning option
According to the manual for IS series Mr. Coffee for programmable models:
1. Prepare one batch of Mr. Coffee coffeemaker cleaner. Pour the mixture into the water reservoir. Remove the water filtration disk from the machine.
4 cups or 20 oz. of undiluted, white household vinegar may be used as a substitute for the cleaner.
2. Place an empty paper filter or permanent filter into the filter basket and close.
3. Place the empty decanter back in the unit, centered on the warmer plate.
4. Press SELECT button until the red CLEAN indicator light is illuminated. For your convenience the cleaning cycle is automatic. The entire cycle will take 45-60 min to complete. During the cleaning your coffeemaker will:
  • Slow brew approx. 3 cups of cleaning solution.
  • Pause for 30 min (the CLEAN light will remain on to alert you that the process is active). At the end of the pause period your coffeemaker will beep.
  • After 30 mins your coffeemaker will brew the remainder of the cleaning solution.
  • When complete, the CLEAN light will turn off and your coffeemaker will automatically beep and shut off.
5.Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean fresh water.
7. Place the empty decanter back on the coffeemaker, centered on the warmer plate.
8. Remove and discard the filter used during the cleaning cycle and replace it with a fresh paper filter. If a permanent filter was used during cleaning, remove it and rinse it thoroughly before replacing it in the filter basket.
9.Begin brewing and allow the full brew cycle to complete.
Repeat steps 6-9 one more time.
Nov 23, 2007 | Mr. Coffee FTXSS23GTF Coffee Maker
Need Instructions
Dear PB, Head over to the Mr. Coffee website and look here - http://www.mrcoffee.com/manuals.aspx. Somewhere in there it should have the manual online for it. --j.
Jun 19, 2007 | Mr. Coffee Classic 12-Cup Coffeemaker -...
Mr. Coffee CGX20 12-Cup Coffee Maker Logo
285 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
