Question about Frigidaire FRT21G4B Top Freezer Refrigerator
Accumulation of water in bottom of fridge
I have a Frigidaire Gallery FRT21NGJ top freezer refrigerator. (no ice maker or water dispenser) Water accumulates in the bottom of the fridge under the produce bins and once it reaches capacity, leaks all over the floor. There is a little dispenser at the back of the fridge, just under the freezer. It looks like some type of overflow, however, it is always full and the water is always frozen. I am not sure if the leak may be coming from there - I don't actually see anything dripping.
Any ideas as to why this is happening or what parts I may need to replace? Any suggiestions/ideas most welcome!
  • 2,976 Answers
You probably need a new door deal for the freezer. When you cet too much condensation in the freezer, it drains down the back of the refrigerator section during the defrost cycle. Check under the produce bins for a drain. If you don't have one, you're not alone. I used to have have to wipe mine out every other day until I finally replaced the seal.
Posted on Feb 02, 2009
I have a 16 year old Frigidaire Gallery Side by Side FRS20ZSH fridge/Freezer. We get water to the filter but not to the door dispenser or the automatic ice maker. Help please?
this could be one or two problems :
fridge door that dispenser is in is not shutting all the way any longer and the safety switch is not allowing anything to come out of dispenser , or the valves in the bottom of fridge are bad (16 years it's time to go too) these valves are not expensive and not hard to replace , just remember to turn water supply off 1st see your local or internet parts supplier to obtain them
Oct 28, 2015 | Frigidaire Refrigerators
My ice maker works but does not dispense water or ice through the door?
frozen water supply chute to icemaker, frozen water lines in door, unplug for 8 hours with doors open and this may fix your problem.
fridge may be set too cold
38 f fridge and 0 f freezer
May 03, 2015 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire gallery side by side won't send water to ice maker tray, but will to water dispenser
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
Jan 24, 2013 | Frigidaire FRS3R5EMB Side by Side...
Water puddle on floor from inside refrigerator could it be defrost heateris bad? water accumulates in the bottom of freezer and freezes seems to come out of evaporator/fan location
unkink the drain hose...I just opened up the back of my Frigidaire Side by Side counter depth to find the drain hose was bent and collapsed coming right out of the bottom of the freezer and the pan was dry as a bone. It doesn't look like my drain hose has ever drained a drop of water. The freezer bottom is full of ice And the rust and chipping paint under the bottom of the freezer door along with the mysterious puddles of water every morning means the drain system definetely never worked. Frigidaire should be responsible for this. This, along with the ice maker rebuild I had to do,... after ice was spilling all through the fridge. I actually had warrantty left on that one and called customer support in India to find out I could make the repair myself. Yep I had to do it. Frigidaire you failed.
Jun 12, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery Professionaly series broken ice maker
If you hook up the water to the fridge, that means you connected the water line to the 'Water Inlet Valve' of the machine. There should be a two wire harness connected to the water valve back. Look for that....
But please note following...
Some water valves in fridges are complicated with one harness for water dispenser line valve and another harness for ice maker water line.
Also seeing a disconnected wire harness does not mean it is for the water valve. May be most likely. But be careful sometime there are test wire harness for technicians to get power readings for components.
Oct 25, 2017 | Frigidaire Professional Side By Side...
Freezer side of a side by side water in the bottom
the drain is clogged.take a hair dryer and un thaw the drain
Dec 18, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
Apr 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
There is a water leak inside the freezer
You need to remove the bottom two baskets, or more to make space. Using a hairdryer, defrost the back area. You should be able to locate a drain hole in the center below the freezer coils. This drain hole is connected on the outside to a drainpipe which has a p trap and often gets blocked up. You need to force water down the drain hole. You can use a turkey baster or similar type of plunger filled with water. Once you have cleared the blockage pour hot water till it runs freely. Hope this sorts your problem, don't forget to rate me.
Mar 11, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
Jan 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire FRT21G4B Top Freezer Refrigerator Logo
438 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
