Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Printer says paper jam then please wait. Then it will not do anyt
My Kodak 5300 says paper jam then please wait comes on screen and will not allow me to do anything.
  • Anonymous Mar 29, 2009
    Exact same problem. But there is no paper in the paper paths the the error message about the paper jam is false. And the "please wait" screen stays for the 1 hour I waited. No buttons work, not even the power off button.
    Champion:
  • 320 Answers
Well! the machine says that there is some paper in the machine, start by taking different itrems out such as the paper tray, look in the doc feeder and so on, good kuck
Posted on Feb 03, 2009
Kodak 5300 AIO Paper Jam
Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 09, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Sep 15, 2009 | Kodak ESP 5 Printer
Kadak Easy Share 5300 printer. Screen reads "Please wait"-stuck
Try this one
Take out the inks and printhead
Leave the cartridge door open, then unplug the power cord from the back of the printer while the access door is open
Close the cartridge door once the cord is unplugged
Reconnect the powercord, turn on the printer, then your printer will look for your printhead "Printhead missing or not installed correctly..."
Then put everything back. make sure it will snap in to place. Then print a calibration page, then scan it. This is just over writing the error message.
Thanks Josh - Kodak Tech Support
Aug 12, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kadak Easy Share 5300 printer. Screen reads "Paper Jam Clear Jam
Try this one Take out the inks and printhead Leave the cartridge door open, then unplug the power cord from the back of the printer while the access door is open Close the cartridge door once the cord is unplugged Reconnect the powercord, turn on the printer, then your printer will look for your printhead "Printhead missing or not installed correctly..." Then put everything back. make sure it will snap in to place. Then print a calibration page, then scan it. This is just over writing the error message. Thanks Josh - Kodak Tech Support
Kodak 5300 AiO Printer will not work due to paper jam
Looks like the sensor for paper jam is causing you problems.
Worst thing is that Kodak discontinued the whole 5xxx series because of all the problems those printers had.
I don't know if you will be able to fix the problem through Kodak support, I guess you will have to give them a call.
Good luck,
Milan
May 19, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
How to clean photo jam at my kodak all in one printer 5300 aio ?
if there is a paper jam then open the rear access door and look for any paper or piece of paper stuck in there if not then try and roll the roller slowly to check for paper jam........if you still cannot find the paper then open the front access door as if you are trying to replace the ink cartridges and look inside if you can see any paper stuck in there or not........if still no paper restart the printer after 30 seconds and check if still getting paper jam or not............if yes then contact Kodak tech support.......
Jan 30, 2009 | Kodak EasyShare Thermal Photo Printer
Paper jam
Paper jam means that the rotation of the roller is not smooth, either because you are not inserting the paper correctly or there is something stuck in the printer. What you have to do is open the back cover of the printer and check the roller and clean it. Then if still paper jam is there, then it's manufacturing problem. Contact manufacturers.
Dec 10, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have seen this when I have stored/used my printers in a humid location - in my case, my basement home office. The paper edges curl enough to interfere with the grippers and/or cause paper jams.
Make sure you have new, dry paper (perfectly flat) in the tray and try again. If this solves the problem, you may want to try to relocate your printer to a dryer location.
Good luck.
DigiChick
Jun 02, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printer jam...i took the back off i see no paper jamed anywhere. I removed the paper and reinstalled it still the light come on saying there is a printer jam
To resolve this issue please do the following:
1. Open the printer access door(the gray part)
2. remove the cartridges
3. remove the printhead, to remove it press the release latch located on the upper left edge of the printhead where you put the black ink
4. Then close the printer access door WITHOUT the printhead and the cartridges.
5. unplug the printer and wait for 30 seconds and plug it back
6. it will give you a missing printhead error
7. install the printhead first, close it and then it should give an error missing cartridges. install the cartridges and if you no longer have the error upgrade the firmware by going to www.kodak.com/go/downloads
I hope that helps. If not contact kodak technical support for further troubleshooting.
Apr 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Paperjam then no power
unplug it..both cables..wait around 1 min..try it again. got backup?
Feb 10, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
239 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
