Question about Whirlpool LER5644J Electric Dryer
Home whirlpool dryer
Hello. The power went out and since the dryer won't turn on. There is no fuse in the power cord or relay in the back. What else could be a posibality to check in order to fix it? Thank you.
    Problem Solver:
  • 8 Answers
How old is this dryer and what is the model number
email this and i will see what i can do
stewsappliance@rogers.com
if the dryers not to old it could be the little white fuse sencer on the back by the thermostate good luck
rate my help
Posted on Feb 12, 2009
Dryer has power but wont start
Hello there and welcome to fixya
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. To determine if the door switch has failed, watch the part testing video at the bottom of this page. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.) To determine if the thermal fuse has blown out,
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Apr 05, 2012 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
My whirlpool cabrio dryer has an error code "PF" What does this mean?
The PF error code means power failure. IF the dryer was running and the power went off that display would show. I am assuming your power didtn go off yet the dryer trought it did, so the things to check is for a good tight connection on the power cord at the back of the dryer, a possible loose connection on the wall outlet where the cord plugs into ,or even a weak circuit breaker.
Good luck,
Gene
Aug 13, 2011 | Dryers
Whirlpool lec9000pw1 dryer. There is no power. Power to the dryer is fine. Thermal fuse is fine (not open). Any other ideas of what could be problem?
hello,
their are several things that could prevent the dryer from running
1) door switch
2) burnt connection on terminal block where cord attaches to
3) timer
4) push to start switch
Jul 31, 2011 | Whirlpool LER4634J Electric Dryer
I have a whirlpool dryer that won't start. I am renting and the owner doesn't know the model number. The power to the house went out and everything came back on except the dryer. I checked the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 06, 2011 | Whirlpool LGV4634JQ Gas Dryer
We moved into our new home, we connected the washer and dryer, the dryer was working fine, our dryer is a whirlpool dryer and it electric, it a duet, the model number is GEW9260PW0 the dryer was working...
sounds like the element could have went out. if you cant take the dryer apart you should call a service co. always disconect the power before working on it.
Dec 23, 2010 | Whirlpool Dryers
I changed the power cord b/c i moved and it had a different recepticle. Now dryer will not turn on.
3 wire or 4 wire plug,,,,,on a 4 wire the green gose to the cabnet,,,check the fuse box of the home it is a common issue www.myabcspace.com/washerwizzards
May 15, 2010 | Whirlpool LER5636P Electric Dryer
Went to push the dial in to start and it won't
first make sure you have power to the dryer.if you have power to the dryer than put your ear to the timer and see if you hear the timer running.if the timer is running than you nead to unplug the dryer and pull the dryer away from the wall so you can remove the vent hose and the back panal and the power cord cover.next look down and to the left and you will see a white plastic thermal fuse.remove the wires from the fuse and use a meter to see if the fuse is closed.if it is not replace the fuse and replace the back and power cord cover.plug the dryer in and check unit out.
Jan 10, 2010 | Whirlpool LER4634J Electric Dryer
Dryer won't start, is it the start relay switch or something more complicated
First verify 220 volts of power to the terminal where the cord attaches. If voltage is OK,remove the rear panel and locate the thermal fuse on the left of the exhaust vent. It is 1 and 1/2 inches long by 1/2 inch wide and white in color. Turn off the power to the dryer. Remove the wires from the fuse. Check the fuse with a volt/ohm meter set for ohms. No reading is a bad fuse. If you get a reading,check the door switch for continuity.
Nov 05, 2009 | Whirlpool LER5636P Electric Dryer
My dryer turned on for 1 second and went off. checked the plug, it was burnt, replaced cord and outlet just in case. dryer will still not turn on. Checked door switch and power to cord both are fine. ...
Yes there is a little white fuse behind the back panel take the 9 to 11 quater inch screws out and you will see a white fuse down below check continuity on it or connect the wires.
Note whirlpool parts surplus is not liable for any damage.
Apr 11, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool LER5644J Electric Dryer Logo
46 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
