Question about Car Audio & Video
I have a orion xtr2250 car amp without the wireing harness so i have made the wires longer so they are comming strait out of the amp.i want to know what wire is what
    Scholar:
  • 125 Answers
For information on your amplifier including wiring schematics got to this address:
http://www.orioncaraudio.com/Support/
and enter in your amplifiers information all files are in PDF form so get adobe acrobat reader its free download at download.com
Posted on Feb 04, 2009
Resistor going to my pto clutch burnt out
Your going to have to call the factory/customer service and find out what the resistor size is.Got Radio Shack and get a couple of them and solder one in.You don't want to run it strait without the resistor,could burn up something MORE important.Like the clutch.You can get Husqvarna online help too.Try Husqvarna.com.This new stuff can be a pain at times,but gotta havit.Rigger
Aug 28, 2012 | Cars & Trucks
Car Power Amp not truning on for 60 to 120 seconds in cold weaher
could be internal problem with the amp, but there is a possibility it is something else. Are there other amps in your car? Do they turn on quickly? If this is the only amp, try the following:
- disconnect turn-on lead from amp (blue wire?)
- turn on stereo (volume normal or low)
- use small piece of wire to connect 12V terminal to turn-on terminal.
you can just touch the wire to the terminals - paper clip will work, too.
- if the amp still takes forever to power up, then the problem is internal to the amp.
- if the amp powers up right away, the problem could be in the turn-on output from your head unit. You can resolve this by using a relay, or by using the ACC output from the ignition (red wire at radio wiring harness) to turn on the amp.
Jun 28, 2010 | Orion Car Audio & Video
1996 ford probe passenger electric window no longer works.
you blew the fuse for your radio.you cannot put a hot wire to a ground that is why the fuse blew.you could have broken a wire connector for the door,windows etc.the headlight switch wire harness is probably melted this happens a lot on Ford products,the head light draw so much heat they melt the wire harness plug that goes on the back of the headlight switch.
Jul 25, 2009 | 1996 Ford Probe
Wiring h2 2ohm sub
ASSUMING YOU HAVE AN AMP FOR THIS SUB, CONNECT LEFT AND RIGHT JACKS, RED AND WHITE TO BACK OF STEREO RUN TO AMP AND THEN FOR A TWO CHANNEL AMP YOU JUST BRIDGE THE TERMINALS SO LEFT + ON CHANNEL ONE AND RIGHT - CHANNEL TWO
May 03, 2009 | Orion H2 15.2 Car Subwoofer
How to wire 2 dvc subs to a orion 2150sx ? dont know the wire colors or how to hook um to my amp.
what impedence are the voicecoils?
Dual 4 - Dual 2 - Dual 1 ??
Orion SX / GS / HCCA amp Wiring guide:
Orange = Right Positive
Black/ Orange = Right Negative
Yellow = Left Positive
Black/ Yellow = Left Negative
Blue = 1+1
Bridging of SX or HCCA Amps:
1. Use the Orange wire for Positive.
2 Use the Black/ Yellow wire for Negative
3. Push "in" the Mono Button
That amplifier is only 4ohm mono stable - so assuming the subs are dual 4 ohm voicecoils...
First wire both in Parallel Independently So each subwoofer is now a 2 ohm load. (combine + and + - and- on both subwoofers)
Now Take a positive on one voicecoil of sub #1 and attach to amplifier+(orange)
Take a - on that same subwoofer and attach it to a + on the OTHER subwoofer.
Finally, take a - from the second woofer to the amplifier -(black/yellow)
Now you have a 4 ohm load on your bridged channels.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 23, 2009 | JBL 1200GTi Car Speaker
Old schoool orion amp 250-hcca
Wiring Codes for SX and HCCA
Black/Orange = Right Negative
Black/Yellow = Left Negative
Blue = Remote Turn On
You can remove the bottom of the amp and the colors can be deciphered as to which goes to which pin in the plug. Go to this link on AmpGuts for a reference.
http://www.ampguts.realmofexcursion.com/Orion_HCCA250/
And here is a link where you can buy a new plug on ebay for $25.
http://cgi.ebay.com.my/ws/eBayISAPI.dll?ViewItem&item=110093583828&indexURL=
Dec 05, 2008 | Orion Car Audio & Video
Orion 250G4
Generally to bridge an amplifier you need to insert the positive wire from the sub to the positive wire on the first channel. And then insert the negative wire from the sub to the second channels's negative terminal.
Apr 22, 2008 | Orion HCCA 225G4 Car Audio Amplifier
Orion 275g4 Hcca amp
this actually could be your amp...try turning the gain down slowly and you will hear the bumping either stop or become morelike music background thanmusic foregroud. i had this problem with an older amplifier and i fixed it by getting a larder power/ground wire size and decreasing the gain a little.
Sep 03, 2007 | Orion HCCA 275G4 Car Audio Amplifier
Car Audio & Video Logo
95 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
