Heating problem with one split in a double split system
I have a double split system and until yesterday the heater was working perfect. Now in one room in heating operation the indoor fan doesn´t start (operation indication lamp ON). Cooling and Healthy Dehumidification operation work properly. In the other split all operations are working normal. What could be the problem? May be the main PCB ASSEMBLY?
Thanks in advance
  • kpemge Feb 24, 2009
    First of all sorry for me late reply but I was on holiday. Pyldrvr your were right it was the capacitor. Thank you very much.
  • Chris Parrish May 11, 2010
    which fan does not start the small one on top (if it has one ) or the main blower? how old is it? does it have spark ignition or a glow coil?
  • 56 Answers
Either the board or capacitor have failed. If the motor is HOT the motor could also be the problem. in oder to tell if it is the board you will have to check to see if there is power coming fromthe board at the place where wires hook up. If power is there then it is either the motor or cap.
Posted on Feb 12, 2009
Have a Silverstorm split aircondtioner lost remote cant get cooling in summer periods.
split air cons come in both configurations and are mostly in the last few years with inverter systems
you can get cooling only or cooling and heating systems
some brands only have the cooling only on the smaller units ( 8000 btu units)
Sep 09, 2016 | Heating & Cooling
Front heat blowing out cool air. Just flushed the system yesterday and got the air out and still nothing
With the vehicle up to operating temperature feel of the heater hoses going to the front heater core. if only one hose is hot then you either have a plugged up heater core or an air bubble trapped in it not letting water circulate. You might try loosening the top hose and try to burp the air out of it. Of might have to remove the hoses and try to blow compressed air through it backwards to free up the blockage.
Nov 24, 2015 | Cars & Trucks
Why does my direct double side wall furnace need cleaning and how can I do this
gas pressure needs to be check
and heat exchanger needs to be inspected for any splits or holes, basic clean up dust and debris.
Jun 13, 2014 | Cozy (W352E) Heater
Split AC whole unit turnig off at each compressor start up!
Dirty coil wash outside unit with water and change indoor unit filter
Jun 08, 2017 | Heating & Cooling
Is a split a/c alc and a heating or heat pump?
a split system can be gas or can be a heatpump. a split system is when the condenser coil compressor and outdoor fan is outside. the other half is in the house close to your air filter .that well be your air handler. eletric heater. or gas burner .and indoor fan motor would be. i hope that helps you.
Apr 15, 2010 | Cfm Daikin R410a Split System Air...
Fedder split unit
Your heat strip is burnt out . You will need a tech to come out and replace this heater strip due to the complexity of installation
Dave
Jan 06, 2010 | Fedders C48ACD1VF Split System Air...
LG split system cooler/ heater heater not working
This could be a problem with the interconnecting wiring or a control board problem with either the indoor or outdoor unit. I would have these issues looked out.
Hope this helps
Mat
May 28, 2009 | LG LSC091PMA Split System Air Conditioner
LG split system heater cooler. the heater is not working and fan outside is working
I would check to see if the tech accidently left his jumpers on the unit to keep it running while adding freon. I know it sounds like a simple thing. But all techs have done it at one time or another and that will cause this problem. Due to the fact that you just had freon added there is not a reason anywhere that would cause you no heat unless something was hit when this was being done then something electrical fried
Heating problem 1995 dodge caravan
is there any antifreeze or coolant in the system at all? how could it freeze up?? somethings missing here
Nov 24, 2017 | 1995 Dodge Caravan
No heat
Please make sure that the correct mode setting has been selected. Depending on model you will see the mode button has four little icons. A star/crystal, a teardrop, a sun (circle with lines out going) and a sort of triangle. You press this button until the correct icon appears on the display, it should be the sun icon.
Aug 07, 2008 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
89 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
