Question about Necchi Sewing Machines
How do i thread the bobbin on my necchi 539
I have a necci 539 sewing machine. I am brand new to this whole sewing business. My bobbin was loaded for me and I was sewing until I figured out that my bobbin was out of thread. I put another bobbin in that was already threaded but I cannot get my bobbin thread to catch with the top needle. I am so frustrated right now...any help out there?
  • 66 Answers
Take out your bobbin and turn it the other way
Posted on Feb 03, 2009
Necci 752 manual is needed.problem with threading and stitching
Hm, I'm not able to locate a manual but may be able to offer some suggestions.
Remove the top thread from the machine.
AVOID OLD OR BARGAIN BIN THREAD!
Use the same thread in top and bobbin.
Be sure to use a brand new needle--needs to be compatible with the thread and fabric of the project..
ALWAYS RAISE the presser foot and rethread from the beginning.
Set the top tension to the midway point.
Verify the bobbin is loaded and threaded correctly and it turns the correct direction.
Pull the bobbin thread up through the fabric before taking the first stitch. It also helps to hold both thread tails in your left hand when taking the first stitches.
Test your machine and tweak the top tension until the top and bobbin threads meet in the middle of the fabric. (Increased top tension will pull the bobbin thread up. Decreased top tension will allow the bobbin thread to pull the top thread down.)
How to Thread Necchi Sewing Machine
How to Thread Necchi 535FA 535 534FB 534 Sewing Machine and Bobbin Case (not your model, but the threading and basic instructions will be similar or the same as your machine)
How to thread Necchi model 535 FA sewing machine now with captions
Mar 18, 2018 | Sewing Machines
How do I wind a bobbin?
Actually, $10 for a manual is probably a valuable investment. It will not only help you with threading & winding the bobbin but also with maintenance and care of your machine and as well as how to use your machine. Similar brand machines thread and wind the bobbin in the same manner. So, even finding a similar Necchi and the bobbin winding method should be helpful.
Necchi bobbin wind Google Search
Oct 17, 2016 | Necchi 3101 Mechanical Sewing Machine
I have a Necchi sewing machine The bobbin thread is way loose. What should I do
Start out with a brand new needle.
Be sure the machine is threaded properly. Also, the presser foot MUST be raised before threading so the thread will seat properly in the tension disk.
The standard setting for the upper tension is the midway point between the high and low number.
If the bobbin thread is still way too loose, you can try adjusting (tightening) the bobbin case tension. If that does not fix the problem, you can probably try purchasing a new bobbin case for your machine as the old one may be broken or worn.
adjust bobbin tension Google Search
Jan 27, 2016 | Necchi Sewing Machines
Necchi sewing maching adjustments
try a new needle
rethread the machine top and bobbin
try adjusting the top thread tension
make sure the bobbin is inserted into the bobbin case correctly
Mar 23, 2015 | Necchi Sewing Machines
How do i thread an old Necchi 539 sewing machine, and insert the bobbin?
try youtube for a video
or these sites for a manual
sewingpartsonline.com
ebay
sewusa.com
sew4less.com
a1sewingmachines.com
Apr 17, 2012 | Necchi Sewing Machines
Necchi 215A Sewing machine Could anyone help I have a Necchi 215A which will not catch teh bobbin thread, I have tried a new needle and checked the bobbin is loaded and fitted correctly. The needle passes...
Make sure the bobbin has a 3-5 inch thread tail
Then make sure the top thread has a 3-5 inch tail
Then hold the top thread tail with your fingers (away from the needle)
& use the hand wheel on the right hand side of the machine to slowly
Lower the needle in the bobbin area & see if the bobbin thread will pick
Up that way
Sep 26, 2010 | Necchi Sewing Machines
Threading the bobbin- Necchi 535FA
Hi - I have a 510 Necchi sewing machine - how do a fill the bobbin?
May 04, 2010 | Necchi Sewing Machines
Sewing Machines Logo
604 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
