Question about Kenmore 43042 Front Load Washer
How do i take female locking part out to get the brokn male part
I need to get the broken male part out of the female part in the machine and am wondering how i would go about doing that?
  • 15,935 Answers
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
Maytag washer agitator is lifting from male portion during wash cycle
6_21_2012_6_30_07_pm.jpg6_21_2012_6_30_37_pm.gif6_21_2012_6_31_00_pm.gifyou must examine every part, may be the drive shaft the bolt is broken you need to replace and dissasembly the machine. God bless you use the logic sense
Jun 21, 2012 | Maytag Washing Machines
How Do I Access Door Catch Inside Machine Body
Hi Steve
Having taken off the top and runners you will need to take off the front control panel then the main front of the machine.
There are two screws on the top, two on the bottom and four on the front (one may be hidden behind the appliance sticker.
There then should be enough room to access the couping without removing the door.
Give it a play first as it probably will just need resetting and you will save yourself a tenner on a new part.
Good luck
Cheers
ian
Co
Nov 14, 2011 | Hoover VHC391 T-80 Dryer
PROBLEM CODE-'LE'
Locked motor error. Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly. Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable. Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective.
Jul 25, 2010 | Kenmore 24032\24036 Top Load Washer
Drum wont rotate
Code LE is a locked motor Error and it is caused by:
• The connector (3-pin, male, white) in the MOTOR
HARNESS is not connected to the connector
(3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors
(3-pin, male, white) in the MOTOR HARNESS
and 4-pin, female, white connector in the MAIN PWB
ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR
ASSEMBLY and MAIN PWB ASSEMBLY is cut (open
circuited).
• The hall sensor is out of order/defective.
If you need a service manual for that you can find on Here.
Lg WM-2277HW
I hope this helps.
Randy
FixYa Support Team
Jun 08, 2010 | LG WM-2277HW Front Load Washer
Code is reading LE
LE LOCKED MOTOR ERROR
The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to the connector (3-pin, female, white) of STATOR ASSEMBLY. • The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is bad or unstable. • The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited). • The hall sensor is out of order/defective.
Jul 15, 2009 | LG WM-2277HW Front Load Washer
LE error
LE
Locked motor error
* The connector (3-pin, male, white) in the motor harness is not connected to the connector (3-pin, female, white) of stator assembly
* The electrical contact between the connectores, (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main PWB assembly is bad or unstable. Or the motor harness between the sator assembly and main PWB assembly is cut (open circuit).
* The hall sensor is out of order/defective.
Jul 15, 2009 | LG WM2688HWM TROMM SteamWasher
Displays LE
Locked motor error (LE)
Possible Causes
* The electrical contact between the connectors, (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main PWB assembly is bad or unstable. Or the motor harness between the sator assembly and main PWB assembly is cut (open circuit).
Jul 12, 2009 | LG Washing Machines
Washer front loader
Does your model have a Male Female latch, where the femal receptor of the male plug is plastic?
Regards,
Worldvet
Sep 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Lg washing machine trips out and displays le on screen. WM2277HS
LE= Locked Motor Error
Here are the causes
circuited).
Aug 17, 2008 | LG Washing Machines
Kenmore 43042 Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
