Question about Epson Stylus Photo R1800 InkJet Printer
Epson R1800 printing only purple monochrome
My Epson R1800 is printing only purple, not just a purple cast, pure purple monochrome. I am printing from a mac book pro, OS 10.4.11. I have never gotten the drivers to work in every application, but can usually print from Photoshop and Illustrator fine.
This is happening whether I print a color photo or a b&w photo. It does print fine using black ink only. I've tried to change every setting and paper type and no matter what I get these purple prints. Anyone know what gives?
Also if anyone is using the same equipment, what settings do you use — on the printer and in application (color profiles) — to get it to match your screen?
  • rm_design Feb 03, 2009
    Fixed.
    I followed directions in manual and cleaned print heads. Deleted all drivers, cleared printer utility, reloaded. Prints lost the purple, but were still too dark, an ongoing problem from my macbook pro. So, I now am opening pictures in colorsync, and setting the profile to my display profile and saved as .psd from colorsync. Then printed that from photoshop. Worked beautifully.
3 Suggested Answers
  • 110 Answers
SOURCE: Epson Stylus Photo R1800 Won't Print Colors Right!!!
If you updated your mac then what happens is a generic driver (GIMP/CUPS) got installed. Do the following:
To remove any previous Epson printer driver files and get a good working install of the latest download for the Intel Duo Core, do the following:
REMOVE FILES
1. Double click on the MAC HARD DRIVE.
2. Double click on the LIBRARY folder.
3. Double click on the PRINTERS folder.
4. Drag the EPSON folder to the trash can.
5. Close any open windows.
6. Double click on the MAC HARD DRIVE.
7. Double click on the LIBRARY folder.
8. Double click on the RECEIPTS folder.
9. Delete any "Epson" receipts. Close back to desktop.
10. Open the OS X "Printer Setup Utility".
11. Select the "Printer Setup Utility" menu at the top of your screen and click "Reset Printing System...". Confirm resetting.
12. Close all open windows and restart your computer.
DOWNLOAD
If you have not done so already, use the following steps to obtain the download for the new Intel Duo Core driver:
1. Go to http://support.epson.com
2. Select Printers then Inkjet then your printer model.
3. Under "Drivers and Downloads" select Macintosh.
4. Download only the driver marked for the Intel Duo Core system.
Printer Driver v3.0aAs
Intel-based Macs with OS X (v10.4.4 or later)
epson11769.dmg - 12.4MB - posted on 02/06/06
Installation instructions:
1. Double-click on the "epson11769.dmg" file and follow prompts to create an "epson11769_r1800_printer_driver_30aas" disk image on your desktop.
2. Open the disk image. Double-click the "SPR1800Series 30a" installer icon to begin the installation.
3. Follow prompts to complete installation. Restart Mac once the install is complete.
Do the following to add the printer once the new downloadable Intel Duo Core driver has been downloaded and installed properly:
1. Connect printer.
2. Open Printer Setup Utility.
3. Click ADD.
4. Ensure you are on the Default Browser window.
5. Highlight printer as it appears under Printer Name.
6. For "Print Using" select "Epson Stylus R1800" if this automatically appears on the list. If this does not appear, select OTHER (not "Epson" - which links you to GIMP drivers, which we don't recommend or support). NOTE: if you are using a firewire connection, the printer name may appear as a letter only - ie "E" for "Epson". This is normal.
7. A new window opens where you can Browse to the hard drive location of:
HD > Library > Printers > Epson > Inkjet Printers
(This location contains all the Intel Duo Core Epson driver plugins, be they resident or downloaded.)
8. Highlight/Select the plugin for your printer model in the Inkjet Printers folder, then click OPEN.
9. Use the up/down arrows at the end of "Print Using" again to (re)select the printer's name, which will now appear at the TOP of the "Print Using" list.
10. Click ADD. The new downloaded driver will now be added on the list.
11. If there are other printers on the list, ensure the Epson is made default before testing.
When you are working with a printer model which supports borderless and/or roll paper printing options, you will be able to select these options in the program you are printing from as you set up your print job.
1. Once you have an image or file open, go to File > Page Setup.
2. For "Format For" select the Epson printer name (rather than "Any Printer").
3. Select the appropriate Paper Size. If your printer supports different layout features, each paper size will have several different options. For example, the 4x6 paper size will have an arrow pointing right which offers choices of 4x6 Borderless, 4x6 Standard-Minimize Margins, etc. Pick the paper type plus layout/margin option you want to use here.
4. Click OK on Page Setup. You are now ready to print.
Posted on Aug 22, 2008
  • 2678 Answers
SOURCE: I cannot match the print
Not an uncommon problem. Monitors are normally adjusted to what the viewer considers the ideal FOR THEIR viewing which has not relation to what the image is actuall like-hence the mismatch in what you see and what the print looks like.
Have a read here and see if it works.
http://www.northlight-images.co.uk/viewing.html
Posted on Aug 23, 2010
Epson R1800 On Print Preview of a photograph
I print with the R1800 as well as the 24" 7880 in my studio. Whenever the "preview" shows less than the whole image I intend to print it is generally either the orientation (portrait/landscpe) is set incorrectly or the Paper size selected is incorrect for the size of the print.
Hope this helps
nickerjo
leaningpalmstudio.com
Mar 01, 2010 | Epson Stylus Photo R1800 InkJet Printer
My epson R1800 printer sometimes ejects the paper to soon
I solved this problem by wedging a piece of cardboard in the slot next to the on-off switch. This stop the printer from cycling during the printing due to vibrations.
Feb 17, 2010 | Epson Stylus Photo R1800 InkJet Printer
I have inherited an Epson R1800 printer that guzzles magenta and cyan inks like crazy. Am I doing something wrong?
No, If you are printing any coloured output this will be normal depending on the actual colour content and what most people don't realise is that unless your text is pure black then it will be printed using the color carts as well and not the black ink cart.
Oct 15, 2009 | Epson Stylus Photo R1800 InkJet Printer
RE: "Epson CD print" software download for R1800
r1800 doesn't support cd printing. Maybe that's why you can't find the disc??????
Jun 06, 2009 | Epson Stylus Photo R1800 InkJet Printer
Light purple cast to black and white prints
Known issue. Use QTR to print bw prints. Works great on my Epson 2200.
http://www.quadtonerip.com/html/QTRoverview.html
Dec 06, 2008 | Epson Stylus 2200 InkJet Photo Printer
Epson R1800 pauses during printing
If you give to the printer a big file to print, you will overfill the buffer. So it will make a stop to refill, and during this pause the ink become dry on limit. The r1800 is A3 printer 300dpi, so a 50MB file is enough to plain quality.
Try to put your file in 8 bit mode, flatten it and put it to the print size in 300dpi.
Nov 18, 2008 | Epson Stylus Photo R1800 InkJet Printer
R 1800
where can i get a print head for my epson R1800 printer?
Mar 04, 2008 | Epson Stylus Photo R1800 InkJet Printer
Color image imported is way off
TIP : always set image on RGB, printer drivers or programmed to convert RGB to CMYK then sending it to the printer. printers understand CMYK only.
Jan 17, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson R1800 and Imac intel
Not sure about this as Mac's are not my bag. Try removing the driver and software you installed. reboot your PC and make sure the printer has gone from the list. Reistall the latest driver you downloaded from Epson and try it again.
Apr 24, 2007 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
305 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
