Question about O2 ICE Cellular Phone
O2 ICE OPEN TO CLEAN
I HAVE OPEN MY O2 ICE, I HAVE CLEAN, AND NOW IT'S DON'T RUN. ONLY ON/OFF. I CAN PUT ONE CODE TO RUN? IT'S AN ASSISTANCE DEFENCE?
  • alex_top Feb 03, 2009
    I think to must resert my o2 ice, the connectors is ok.. i don't know how.. i have lost my o2 program insallation. Help! again please.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 158 Answers
There must be something wrong with your installations... check the connectors... there could be some lose connection pal...
Posted on Feb 02, 2009
  • Rodolfo Atun Feb 03, 2009
    sir.
    in that case, i sugest that you check the connectors again, also check for the moist that may have develop on the space between the ic's. also fit it properly on the housing andmake sure to render proper tightness of the screws.
P0430 code
P0430 is a catalytic converter efficiency code . You need a catalytic converter . OR run 4 0r 5 bottles of a product called cat-a- clean . One bottle per tank full , may clean it up.
Mar 29, 2016 | Cars & Trucks
Free unlock code for o2 ice
You can get the unlock code for an O2 ICE from www.prounlocking.com at affordable cost with easy unlocking guide.
Aug 10, 2012 | O2 02 ICE Mobile Phone
Odor coming from disposer
Hello, Tell your husband to wash his feet some place else, OK. it needs to be cleaned. Don't put you hand in it, OK. On the top in sink remove the rubber flapper and clean it with soap water and vingear. Put about four large cups of ice and tuirn on the disposer. The ice clean out any stuff that in the chopping blades. Mix up a sink of water, soda and a little clorex in the disposer sink then let the sink drain and turn on the gargage disposer then let it run while water is running into it. Do a cleaning procedure once or two a month. couple of lemons, Clorex, baking Soad, this stuff will work great. It will make you disposer smell like fresh spring day but tell you husband to keep his feet out of the kitchen sinks. GB...stewbison
Sep 24, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I put a brand new o2 sensor in and still have the same code
HI. Usually when you receive the same code after replacing the O2 sensor, this will confirm that the original O2 was not the issue. This will be a shorted or open connector or wiring harness at the affected O2 sensor that was replaced. If possible, you can confirm this by using a multimeter. Use the meter to test the connector contacts that connect to the O2 that you replaced. I'm sure that harness or connector may be open or the ground in that particular connector is bad(open circuit).
Jul 24, 2010 | Cars & Trucks
I have code 406 what does it mean?
on youe veicle you have to follow procedures to check O2 sensors
voltage to high more than 3.7 volts
circuit shorted or O2 sensor is no good thats for code 138
code 171 contaminated O2 sensor
406 is your EGR system shorted open thats whats probably causing your O2 sensors to contaminated fix the EGR and clean passage way to intake
May 07, 2010 | 2004 Dodge Caravan
Replaced both sensors in a 2004 Pontiac Grand Prix P0135 P0141
A code P0135 may mean that one or more of the following has happened: = O2 Heater element resistance is high
= Internal short or open in the heater element = O2 heater circuit wiring high resistance = open or short to ground in the wire harness.
What to do; = Repair short or open or high resistance in wiring harness or harness connectors.
= Replace oxygen sensor (cannot repair open or short that occurs internally to sensor)
A code P0141 may mean that one or more of the following has happened:
Same as above: mentioned in P0135.
What do do is the same as above, so i am leaning towards and faulty wire harness since you have replaced both O2 sensors. Make sure the wire harness has no break in it or crushed connection clips. The other thing to look for is a bad fuse that is used to heat up the O2 sensor. It may not say O2 sensor on it, it may piggy back off something else so check all the fuse and make sure the O2 has a good ground and not corroded. Good luck and hope this helps.
Jun 25, 2009 | 2003 Honda Accord
O2 sensor problem, running rich. Please help
was the code for rich or lean? may try cleaning mass air flow sensor. it is in the air intake tube and has a flat wire connector. take out of tube and take four torx bolts out and clean with mass air flow cleaner or brake cleaner and put back in when dry. or it could be a bad wire on the o2 harness. look for chaffing or broken wires in harness by o2. also could be the exhaust system has a slight blockage. could also be some other things but try these first.
May 07, 2009 | Chevrolet Silverado 2500 Cars & Trucks
My 2002 Ford Windstar van is giving the code ''PO174 System lean bank 2''. Usually runs bad when it is damp, raining or winter, but never stalls out. This time (winter) check engine light on. Van has...
Sounds like it could be a bad Oxygen sensor on that bank. check for vacuum leaks first but since it is only on 1 side of the motor is most likly a O2 sensor.
get the engined scanned and look at the reading from that O2 sensor. But if you have more then 100k and it has never been replaced then I would juts replace the front 2 o2 sensors as they are only good for 100-120k. You don;t need to replace the rear O2 sensors only the front 2.
Mar 27, 2009 | 2002 Ford Windstar Cargo
Ice does not dispense through door of kenmore elite side by side
take ice bucket out, dump ice, clean with hot water and let dry ,,,, put ice back in and try it ,,, bucket is most likely frozen up thru ports
Nov 28, 2008 | Kenmore 53642 / 53644 Side by Side...
O2 ice phone turns on but wants a password?
contact your retailer about the phone password... they know the password for sure..
Nov 25, 2008 | O2 ICE Cellular Phone
O2 ICE Cellular Phone Logo
70 people viewed this question
Top O2 Cell Phones Experts
Computer Repairing
Computer Repairing
David Burbee
David Burbee
ivan georgiev
ivan georgiev
Are you an O2 Cell Phone Expert? Answer questions, earn points and help others
